:: View topic - Dotaz na kompatibilitu kabelu
Serifus
805.58 SMM
PostPosted: Tue May 13, 2008 9:53 pm    Post subject: Dotaz na kompatibilitu kabelu Reply with quote
Zdravím! Bude kabel určený pro A38, A58, AF51, E71, E81, EF51, EF71, EF81, EF91, EL71, C81, M81, P51, S68, S81, S88, SL91 kompatibilní pro SXG75?? Díky předem.
C35i ---> SXG75 Smile
d[E]sann
Phone: EL71
2352.42 SMM
PostPosted: Tue May 13, 2008 10:20 pm    Post subject: Reply with quote
Ne nebude Wink... Má to jinačí koncovku. Kompatibilní bude s DCA-510 i DCA-540
PostPosted: Wed May 14, 2008 6:23 am    Post subject: Reply with quote
SXG75 podporuje iba DCA-540 ale niektoré prototypy aj DCA-510
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Wed May 14, 2008 9:11 am    Post subject: Reply with quote
kdyz clovek spravne nastavi SXG75 tak i produkcni kus bude behat s DCA-510 (muj pripad, s DCA-540 mi prestal fungovat)
Koupím Siemens, který nemám.
PostPosted: Wed May 14, 2008 12:58 pm    Post subject: Reply with quote
to som nevedel... das link na navod?
BEZY
81.16 SMM
PostPosted: Wed May 14, 2008 1:04 pm    Post subject: Reply with quote
je to jedna z možností v 000000>SIO Config>port mapper>data
po nastavení na 510 ovšem nebude fungovat BMC, QPST ano
http://www.bezysoftware.net
Brew Mobile Commander 2.0
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Wed May 14, 2008 3:01 pm    Post subject: Reply with quote
UART1 je komunikace telefonu pres DCA-510 a USB je pres DCA-540
kraze1984
155.88 SMM
PostPosted: Thu May 15, 2008 3:53 pm    Post subject: Reply with quote
Thank you for the information.
So, there seem to be logically to make some changements in language pack...
