Fijo666 rozumbrada
382.24 SMM
Posted: Sun Jun 08, 2008 10:47 am Post subject: SMSzipper v. 2.1.16 |
SMSzipper v. 2.1.16
Info + download
Beneath SMS compression and known functions such as forward, reply, setting marks, or delete and restore messages, SMSzipper adds some features formerly unknown to SMS communication that will improve your SMS experience.
It's not just SMS compression - or protecting SMS in your inbox with a passwort - there is simply more than that, see below!
Using SMSzipper allows you to send and receive SMS that destroy themselves after a defined time - we call them selfdestruction SMS! The sender specifies a SMS lifetime and on the receiver side SMSzipper silently discards the message after time's up. The lifetime is transferred with the SMS - at no additional cost.
You can define a time in the future at which the SMS is shown in the receivers inbox - a scheduled SMS! Just set time and date, send the message, and the receiver will see your greetings in his inbox at exactly the time specified - even without network connectivity and at no addtional cost. The time is submitted within the SMS.
Last but not least, you can even use a subject with your SMS, as known from email conversation - that makes it very easy to identify a thread within your SMSzipper inbox! The subject is also sent within your SMS and it does not limit your SMS size in comparizon to a traditional SMS - you may even type more!
Features
send up to 480 characters in one single SMS
receive compressed SMS
recommend SMSzipper to your friends by traditional SMS
save your messages as SMS drafts - to finish them later
set labels to your received SMS
protect SMS in your inbox by a password
access your phonebook if sending SMSzipper messages
settings dialog to control application behavior and features
send nomal SMS to users who do not use the SMSzipper
The commercial version of the SMSzipper even allows to encrypt your SMS with a Pre-Shared-Key and AES!
Priamy odkaz na stiahnutie _________________ N95, 2GB SD fw 30.0.015 + hack sw
SX45i + 32MB MMC
kylo rozumbrada
MatejP pisatel
54.46 SMM
Posted: Wed Oct 22, 2008 2:47 pm Post subject: |
Jak to čtu, tak to vipadá celekem nadějně, asi to otestuju, bude s tim určitě zajímavý pracovat.....  |
