:: View topic - C81 + update firmware
Goto page 1, 2, 3  Next
Reply to topic     Forum Index -> Třída C
jkl2n
PostPosted: Thu Jul 27, 2006 6:25 am    Post subject: C81 + update firmware Reply with quote
chcel by som sa opytat ci je mozny update firmwaru C81 aj cez Bluetooth, alebo len cez datovy kabel. Diky
Marking
PostPosted: Thu Jul 27, 2006 2:55 pm    Post subject: Re: C81 + update firmware Reply with quote
Jenom pres datovy kabel
silvo košík
PostPosted: Thu Jul 27, 2006 8:12 pm    Post subject: Re: C81 + update firmware Reply with quote
a co ten system vzduchom cez egprs(polozka menu sprava zariadenia)???
ma to niekto odskusane,lebo mne vzdy vypise ze:momentalne nie je k dispozicii nova ver.skuste neskor-pritom nova ver. uz je Think
destinqo
PostPosted: Wed Aug 02, 2006 1:17 pm    Post subject: Reply with quote
zdravim.
ten update mi vobec nejde. napise:
kontrola-profil provider
mate c81 na akciu?
qyxik
PostPosted: Fri Aug 04, 2006 11:14 am    Post subject: Variant A971 Reply with quote
Pokial mate c81 z Orange(teda c81f) a mate tam variant A971 ako ja,tak zatial budeme mat s update firmwaru asi smolu.Ak som to spravne pochopil,tak je to nejaka verzia priamo orange firmwaru.Najskor nas problem vyriesi novy fw-winswup,alebo snad cakat kedy operator a nie benq-siemens pre nas pripravi novu verziu fw.Ak sa mylim,tak ma prosim opravte,pripadne poradte ak viete viac.
jjsan
PostPosted: Sun Aug 13, 2006 12:14 pm    Post subject: Reply with quote
no ja mam tiez tu A971 a palim tam A970 a ide to uplne bez problemov takze v tom problem nevidim. a dost to pomohlo
jjsan
PostPosted: Sun Aug 13, 2006 12:15 pm    Post subject: Re: C81 + update firmware Reply with quote
ma to niekto odskusane,lebo mne vzdy vypise ze:momentalne nie je k dispozicii nova ver.skuste neskor-pritom nova ver. uz je Think[/quote]
no neviem aky mas datovy program ale stahovat 20mb je podla mna dost a na SK to aj tak nie je. v cechach to funguje ok
qyxik
PostPosted: Sun Aug 13, 2006 12:20 pm    Post subject: Reply with quote
Applause to nechapem,mne napisalo chybna verzia softweru a dalej ma to nepustilo,mohol by si prosim dat blizsie info?
qyxik
PostPosted: Sun Aug 13, 2006 3:18 pm    Post subject: Reply with quote
Skusil som este raz vsetko mozne poprepinat a ponastavovat,ale bohuzial nic nepomohlo.Stale pise chybna verzia sw.Proste je to soft pre c81 a nie c81f.Ak to slo(ako napisal jjsan),tak potom nie na c81f Shame on you Je tu niekto komu sa do c81f podarilo dostat novy soft?kazda rada bude dobra Think
jjsan
PostPosted: Sun Aug 13, 2006 6:02 pm    Post subject: Reply with quote
takze vypis z mobilu:
Vyrobok: C81F
datum vyroby: 2006-06-03
verzia software: 40
zakladna linka: m75i14#main_1.0_V79.24.1
Verzia FFS: C81F_2_sk-Orange-G_39_0358
Variant: A971
prepalovanie firmware pomocou USB datoveho kabla zakupeneho v cechach a firmware stiahnuty zo stranky vyrobcu (verzia prec C81F variant A970)
pises ze si nastavoval a prepinal vselico mozne, ale nechapem kde a co sak to len pripojim a spustim
qyxik
PostPosted: Sun Aug 13, 2006 7:18 pm    Post subject: Reply with quote
No ja som skusal vypnut dobijanie cez usb a podobne veci.Snazil som som sa najst ten soft na www.siemens.sk,ale akosi sa mi nedari.Skor ako mi zacnes znovu nadavat,pomohlo by urobit gesto pre hlupakov ako som ja a dat sem link alebo aspon priblizny navod ako postupovat.Budem zaviazany a myslim ze nielen ja.
jjsan
PostPosted: Mon Aug 14, 2006 8:10 am    Post subject: Reply with quote
Code:
http://www.benq-siemens.com/cds/frontdoor/0,2241,sk_sk_0_142300_0_xcs%253A130989_xcp%253A140743_pd155171%253A160608,00.html#anchor155171
neviem kto ti nadava ale ja nie. tu si to stiahnia mas. ja som to prepaloval uz aj so zapnutym aj vypnutym dobijanim a obe zbehli ok
qyxik
PostPosted: Mon Aug 14, 2006 4:51 pm    Post subject: Reply with quote
Uz som to uspesne prepalil mne aj zene,dakujem.Ja som to hladal v sekcii "sluzby zakaznikom" a az potom som prisiel na to ze je to v sekcii "mobilne telefony a prislusenstvo" a necerti sa musel som ta trosku podpichnut,aby si ten link hodil cim skor.este raz dik. Very Happy
jjsan
PostPosted: Tue Aug 15, 2006 1:40 pm    Post subject: Reply with quote
to som rad len keby to aspon trosku pomohlo by bolo lepsie
destinqo
PostPosted: Wed Aug 16, 2006 10:25 am    Post subject: Reply with quote
takze prepalit firmaware na v.40 nema ziaden zmysel?
Reply to topic     Forum Index -> Třída C All times are GMT + 1 Hour
Page 1 of 3
