delpierwin badatel
 Založen: 27. 12. 2007 Příspěvky: 146 Bydliště: Sukabumi, Republic of Indonesia
519.20 SMM
Zaslal: pá leden 16, 2009 9:38 am Předmět: M65@CX70v56 Windows 7 Edition v1.0 |
Following my black diamond project, here i am presenting :
Siemens M65@CX70v56 Windows 7 Edition v1.0
Still based on M65@CX70xp: Beyond the Limit! by Mas Qunto, Jan-08, added some feature @ BlackDiamond , Jan-09, Now Windows 7 Edition, Jan-09
Capture Picture :
Patch List :
------------------- Main Patches -----------------
01. API v14
02. AudioHook v3
03. Function Library v70418
04. Big Function Library v71117
05. WAV ADPCM All Freq.
06. Mainscreen Dispather v3.1
07. Elf Loader v2.3
08. Master Patch v14
09. Cut Heap
10. Pictures add-on v5.1
------------------ Independent Patches -----------------
11. Open closed EEPROM Block
12. Open Disk Forever
13. Java Acceleration
14. Show File Extension in card Explorer
15. Disable some messages
16. Remove Softkey from mainscreen v2
17. No start sound in Video rec
18. Disable Aircraft Check
19. Change disk names in menu
20. Change delimiter in menu
21. AutoRedial forever with selected pause
22. Video rec 1 min
23. Setup illumination by 5%
24. Smooth scrolling of long names
25. Smooth illumination turn-on
26. Compress jpeg with maximum quality (100% instead of 75%)
27. Keypad Acceleration
28. Enable Developer Menu
29. Call list saving when SIM is changed
30. Enable Band Selection
31. Enable Built-In WV Client (ICQ AIM)
32. Goto mainmenu from anywhere by pressing ###
33. re-enables "Hide ID for next call"
34. Show current time during call v1.1
35. SVS, SMS view shortcut
36. Disable MMI logging
37. Disk selection menu © SiNgle
38. Toggle HandsFree without question
39. Delete Read-Only Files from Card-Explore
40. Disable AUMA And UDIAL Debug
41. RMWKL Read Message when Key Locked
42. DSFS Directly Send Flash SMS V1.1
43. Change some *#06@ info
44. Turn phone ON while offline charging v1.0
45. Mark Files by Left SoftKey in Card-Explorer
46. No SIM Card Phone Operation
47. Add Elf-Folder to the MyStuff
48. Remove the comma between name and surname in address book
49. Disable ringtone "Net found" (3beep)
50. Enable Vibra With Plugged-In Cable
51. Turn on by Alarm clock
52. Disable Retarget Exit
53. Show Hidden Files In Card-Explorer By Default © 1nvisible
54. Change dialing ringtone "No connection" © B-727
55. Disable More Nasty Debug © benj9
56. Change sw version to XX
57. Disable ASP
58. Disable displaying "netsearch" [!]
59. Vibra on/off when keypad locked/unlocked
60. Start elf on a shortcut
61. MyStuff = Disk Menu
------------------ MP-Patches -----------------
01. Date at the bottom of maincsreen as "We, 11 May"
02. Mainscreen Changer v1.3
03. Music Progress Bar Changer
04. Change Illumination Turn Off Time
05. Keylock Beep
06. Short Vibra at connect
07. Drop Call On Certain Time
08. BlackList v3 beta
09. Missed Events Indicator v2.1 CX70 Ed.
10. Extra Info on ProgressBars
11. TextInfo on The Mainscreen
Change Language Pack:
01. SuperFonts
Download Link :
M65@CX70v56 Windows 7 v1.0
Bugs :
So far so good
Update History :
v1.0 (16-Jan-09)
As first release
Thanks _________________ SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM |
kylo rozumbrada
 Založen: 01. 01. 2008 Příspěvky: 309 Telefon: S65 30.30 SMM
delpierwin badatel
519.20 SMM
Zaslal: pá leden 16, 2009 10:54 am Předmět: |
Thank You Kylo, since patching activity became less, let's start to move on  _________________ SiemensXP | My Blog
Cherokee007 redaktor
delpierwin badatel
519.20 SMM
Zaslal: so leden 17, 2009 3:23 am Předmět: |
Thank You, about S75, i think it will be long time to wait, since i sell it
Maybe You can help me doing some portation for S75 Cherokee007, i had all material You need  _________________ SiemensXP | My Blog
delpierwin badatel
519.20 SMM
Zaslal: ne leden 18, 2009 3:03 am Předmět: |
Appreciate it a lot my friend, please check pm, thank You  _________________ SiemensXP | My Blog
Ozzelot začátečník
 Založen: 11. 08. 2012 Příspěvky: 36
325.10 SMM
Zaslal: ne září 23, 2012 3:11 pm Předmět: |
I'm terribly sorry for writing into a 3 year old topic, but I really wish for a reupload  _________________ "Dokud bude tenhle blbej svět, budem křičet SIEMENS IS NOT DEAD!" -(autor ať se mi prosím přihlásí, napíši ho sem)
Tuna Siemensů, DCA-510, 500, 540; tuna SE, DCU-60 a 65
Hlavní zařízení: Nokia N900 (další po letech), Nexus 7 II
V čem se dá softwarově hrabat, v tom se softwarově hrabu. V čem ne... V tom se hrabu taky.
Linux... Is my life <3 |
black brewmaster
Zaslal: út září 25, 2012 11:42 am Předmět: |
I might have this tuning burned on some backup DVD. Unfortunatelly I'm not at home, so I will check it at the weekend. _________________ Siemens A55 fw 09
Ozzelot začátečník
325.10 SMM
Zaslal: st září 26, 2012 8:45 am Předmět: |
black: Thank you very much. Could you possibly try checking if you don't have the Black Diamond (HTC style) tuning, too? _________________ "Dokud bude tenhle blbej svět, budem křičet SIEMENS IS NOT DEAD!" -(autor ať se mi prosím přihlásí, napíši ho sem)
black brewmaster
Zaslal: st září 26, 2012 10:24 am Předmět: |
I should have it too. _________________ Siemens A55 fw 09
black brewmaster
Ozzelot začátečník
325.10 SMM
Zaslal: so září 29, 2012 5:53 pm Předmět: |
Oh, black, many thanks! Gonna download it right away! Maybe it'll help me forget the problem I have with a SE W580i But that's a kinda different story  _________________ "Dokud bude tenhle blbej svět, budem křičet SIEMENS IS NOT DEAD!" -(autor ať se mi prosím přihlásí, napíši ho sem)
