RedkinG kolemjdoucí
86269.90 SMM
Posted: Thu May 13, 2010 8:46 pm Post subject: Problems with SXG75 prototype, need help. |
Hi to all Siemens Fans!
I have Siemens SXG75 Prototype (white color, IMEI starts with 004400) and some functions are not working, so I need your help.
There are no pictures, music in phone and I can't go into music player and file manager, same as in camera and video capture.
Also GPS application won't start.
HERE IS VIDEO SO YOU CAN SEE THE PROBLEMS.
http://www.youtube.com/watch?v=iTKEE0JZD2A
Is this hardware problem or is there solution to fix this phone?
...sorry for English.
THANKS! _________________ Siemens
A50, A55, A65
C45
ME45, MC60, M75proto
SL10, SL45i, SL55, S65, S68, SX1 Leather LE, SXG75proto, SL98proto |
black brewmaster
 Joined: 01 Mar 2007 Posts: 490 Location: Slovensko Phone: SXG75 51754.60 SMM
Posted: Fri May 14, 2010 11:52 am Post subject: |
Only bad software ... _________________ Siemens A55 fw 09
RedkinG kolemjdoucí
86269.90 SMM
Posted: Fri May 14, 2010 3:45 pm Post subject: |
black wrote: | Only bad software ... |
So what exactly should I do? Flash phone with 26FW? _________________ Siemens
A50, A55, A65
C45
black brewmaster
Posted: Fri May 14, 2010 5:11 pm Post subject: |
Yes. Flash FW and customization. But be carefull! Flash FW for prototype. If you flash FW for normal (not prototype) sxg75, you can brick your sxg! _________________ Siemens A55 fw 09
RedkinG kolemjdoucí
86269.90 SMM
Posted: Fri May 14, 2010 5:21 pm Post subject: |
black wrote: | Yes. Flash FW and customization. But be carefull! Flash FW for prototype. If you flash FW for normal (not prototype) sxg75, you can brick your sxg! |
I tried to flash and now sxg is in factory test mode .
EDIT: With QPST and NV item from http://spssoftware.cz/?view=zabava/sxg75/opravasxg sxg is running again but same problems as in first post...
EDIT2: Where I can find correct FW for prototype sxg? _________________ Siemens
A50, A55, A65
C45
Straces badatel
1013.16 SMM
Posted: Fri May 14, 2010 7:01 pm Post subject: |
Do not use FW for serial SXG75, you will kill your SXG75!!
Because prototypes have Samsung chip with only 64MB (type:MMSZ or MMTZ).
Against serial SXG75 have Toshiba with 128MB (type: MMTO)
I dont know about prototype firmware. I know only FW: 12, 22, 26 for serial.
But what version Firmware do you have?? (*#06# -> SVN).
Dont you want to make whole dump memory for me??
And maybe there is possible way to update (through OBL Multi-image).. _________________ MC60 -> CX65 -> SXG75 FW22 + IMS 700 + 2GB RS-MMC + DCA-110 + DCA-540 + pouzdro + BikeHolderkit..
Dell Axim x50v ( WM6.1 )
Siemens SG75 (FW 13.609.13)
Benq-Siemens SL91 (Onyx)
Benq-Siemens EF82
LG GW620 (Firedroid Mod 2.3.7) |
GgDag siemensmaniak
 Joined: 03 Jul 2004 Posts: 3548 Location: Taliansko Mobil:HTC One
Posted: Fri May 14, 2010 7:37 pm Post subject: |
Kedze mas FW26 staci spravit customizaciu a je to. prelozte mu to niekto do eng  _________________ Siemens->HTC Sensation ->HTC Sensation XE ->HTC Evo 3D White->HTC Evo 3D Black->HTC One X Black->HTC One X White->HTC One silver->HTC One Black |
RedkinG kolemjdoucí
86269.90 SMM
Posted: Sat May 15, 2010 3:21 pm Post subject: |
GgDag wrote: | Kedze mas FW26 staci spravit customizaciu a je to. prelozte mu to niekto do eng  |
Please look video at 0:13. I put 26FW. _________________ Siemens
A50, A55, A65
C45
RedkinG kolemjdoucí
86269.90 SMM
Posted: Sat May 15, 2010 4:28 pm Post subject: |
Straces wrote: |
And maybe there is possible way to update (through OBL Multi-image).. |
How to do that?
I have MMTO?
I flashed phone with NV intems and now I have 22FW and different IMEI...still same problems as in video. _________________ Siemens
A50, A55, A65
C45
Straces badatel
1013.16 SMM
Posted: Sun May 16, 2010 8:27 pm Post subject: |
OK, it seems you dont have prototype you have serial SXG75 with white cover. You should use FW from Siemensmania, Flash update - FW 22 or FW 26.
What numbers had your original IMEI?? (00... or 35...).
If you want more help you should write me to ICQ: 236442546  _________________ MC60 -> CX65 -> SXG75 FW22 + IMS 700 + 2GB RS-MMC + DCA-110 + DCA-540 + pouzdro + BikeHolderkit..
Benq-Siemens EF82
kraze1984 začátečník
155.88 SMM
Posted: Mon May 17, 2010 1:10 pm Post subject: |
He has a proto, his original IMEI starts with 0040.
Maybe you have a 64Mb flash, than the customisation needed just cannot be flashed, as you hav only 7 Megs or so of filespace for files, whereas a new customisation takes around 23 Megs.
To be sure on size and type of flash chip check with QPST Gang Flash Image Application, I don't remember now on details, will post later.
There is one workaround - copy the backup of needed files directly to the fs with BREW Mobile Commander 2.0.
Ask somebody on the forum regarding backup of files. |
RedkinG kolemjdoucí
86269.90 SMM
Posted: Mon May 17, 2010 4:29 pm Post subject: |
Thanks for helping me out!
SXG is definitely a prototype; behind battery is 0044... IMEI and "not for sale" but in *#06# I have IMEI starting with 35... ? maybe because I changed NV items or...?
Brew Mobile Commander in phone info says that IMEI is 35...
@kraze1984 Quote: | There is one workaround - copy the backup of needed files directly to the fs with BREW Mobile Commander 2.0. |
I found this http://spssoftware.cz/?view=zabava/sxg75/opravasxg
Obsah adresáře SXG75 root (root.rar) systémové soubory velikost 3,2 MBytu
But did not help...
QPST Gang Flash Image Application>Flash Device
A50, A55, A65
C45
GgDag siemensmaniak
Posted: Mon May 17, 2010 4:32 pm Post subject: |
nechapem preco nenahra customizaciu. Vsak tam je jeho cely problem.  |
RedkinG kolemjdoucí
86269.90 SMM
Posted: Mon May 17, 2010 5:19 pm Post subject: |
From this page I inserted this:
Obsah adresáře SXG75 brew\mod (brew.rar) pouze důležité soubory velikost 6.4 MBytu
And now GPS is working , but other functions still don't work. Is there full backup of sxg? _________________ Siemens
A50, A55, A65
C45
155.88 SMM
Posted: Thu May 20, 2010 2:14 pm Post subject: |
Before my proto died, i have made a filebackup of the files to HDD. It was with English, Russian and Ukrainian only, and without custom themes, sounds, java, and graphics. If I find it, I will post it  |
