:: View topic - SXG75 (ne)ma signal
SXG75 (ne)ma signal
PostPosted: Sat May 22, 2010 7:06 pm    Post subject: SXG75 (ne)ma signal Reply with quote
Mam taky problem s mojou SXG. Signal ma ale neukazuje ho Sad Nestretol sa niekto s tym? Prehral som uz FW spravil custom nahral NV a neviem co este a problem pretrvava stale.
Dole davam screen
http://img638.imageshack.us/i/screenuy.png/
1961.18 SMM
PostPosted: Tue May 25, 2010 2:06 pm    Post subject: Reply with quote
http://www.siemensmania.cz/forum/viewtopic.php?t=34493
8392.80 SMM
PostPosted: Tue May 25, 2010 3:44 pm    Post subject: Reply with quote
Mi pomhlo při této chybě to 000000 menu a tam tuším položka netvork / domain preference / CS+PS , Ale tento postup jsem musel opakovat po každém zapnutí Mr. Green
PostPosted: Wed May 26, 2010 8:21 pm    Post subject: Reply with quote
sberatel to co si dal je uplne iny problem.
EINEX u mna je problem v SIM karte. Uz som prisiel na to
1961.18 SMM
PostPosted: Wed May 26, 2010 9:00 pm    Post subject: Reply with quote
No tak jsem se spletl, i to se stává, díky za info
PostPosted: Fri May 28, 2010 3:39 pm    Post subject: Reply with quote
Takze problem sa vyskytol aj pri inej sim karte po 2 dnoch.
Problem ale bol v tom ze ja nepouzivam PIN kod a vtedy neukazoval signal aj ked tam bol.
Cize stacilo zapnut kontrolu PIN a problem vyrieseny Smile Ake jednoduche Mr. Green
