:: View topic - pomoc,nejde zapnout ef 81
Reply to topic     Forum Index -> BREW -> Siemens EF81/EF82
easiders
88.76 SMM
PostPosted: Mon Jan 19, 2009 12:02 pm    Post subject: pomoc,nejde zapnout ef 81 Reply with quote
cawec,mam ef81 a nejde vubec zapnout,kdyz to dam do nabijecky rosviti se napis benq-siemens a nic vic,nefunguje ani prepnuti do dm,pls poradte,kabel mam dca 140
2*Siemens S75,Siemens MT50,Benq S81(kill),IMS 700
PostPosted: Mon Jan 19, 2009 1:47 pm    Post subject: Reply with quote
pripoji sa k pc?
easiders
88.76 SMM
PostPosted: Mon Jan 19, 2009 7:39 pm    Post subject: Reply with quote
ne
isaac12
38.84 SMM
PostPosted: Wed Feb 18, 2009 8:05 pm    Post subject: Reply with quote
mam ten isty problem ale k pc sa pripojim .co dalej? telefon je dost teply. mne sa to stalo pri update FW na ten rusky asi hodinu pisalo ze downloading a nic dalel.co teraz?
PostPosted: Wed Feb 18, 2009 9:03 pm    Post subject: Reply with quote
dm mod funguje?
isaac12
38.84 SMM
PostPosted: Thu Feb 19, 2009 4:23 pm    Post subject: Reply with quote
sorry ze sa pytam a to je aky mod ten dm mod?
PostPosted: Thu Feb 19, 2009 4:58 pm    Post subject: Reply with quote
do dm modu sa dostanes tak, ze zapnes mobil tak, ze stlacis # a ten cerveny telefon. Mobil by mal ukazovat benq-siemens. Potom pripoj mobil a skus prehrat fw.
isaac12
38.84 SMM
PostPosted: Thu Feb 19, 2009 5:55 pm    Post subject: Reply with quote
dik ale uz som zystil co to je. ale problem je vtom ze ho nenajde nic. prave som si zohnal na nete DCA-140 myslim ze ten kabel pomoze. ak nie tak kde najdem testpoint na EF81?
PostPosted: Thu Feb 19, 2009 7:02 pm    Post subject: Reply with quote
ak ti mobil ide do dm tak by to malo ist.
Ak nie skus:
* Preinstalovat ovladace a odinstalovat MPM
Ak nie skus iny pc
Test point na EF81 nie je. Iba JTAG ale ten netusim ako sa robi.
// EDIT: pre doplnenie v dm mode nefunguje ani BMC ani MPM iba prehravanie fw
isaac12
38.84 SMM
PostPosted: Thu Feb 19, 2009 7:12 pm    Post subject: Reply with quote
[praveze do toho dm ho neviem ani za B...a dostat vsetko som asi na trikrat preinstaloval a vistu sami nechne davat nanovo. nevies nahodou kde by som to nasiel? myslim ten jtag Hardware?
PostPosted: Thu Feb 19, 2009 7:48 pm    Post subject: Reply with quote
O tom JTAGu som ani ja vela info nenasiel. Skus sa opytat na allsiemens.com alebo na multihandyhacking.de
Nejake info(sice na sxg) JTAG tp
http://kraze1984.narod.ru/sxg75/HW/dsheet/sxg75_pinout.jpg
http://kraze1984.narod.ru/sxg75/HW/dsheet/sxg75_tp.jpg
isaac12
38.84 SMM
PostPosted: Thu Feb 19, 2009 8:05 pm    Post subject: Reply with quote
skusim sa tam opytat zatial dik. este sa ozvem ako som dopadol
1961.18 SMM
PostPosted: Tue Aug 31, 2010 3:43 pm    Post subject: Reply with quote
Upgrade na tento ruskej mi proběhl bez chyby.
Telefon 2. EF81 mi zamrznul, když jsem použil originální firmware siemens 48CZ ze SM.
Reply to topic     Forum Index -> BREW -> Siemens EF81/EF82 All times are GMT + 1 Hour
You cannot attach files in this forum
You cannot download files in this forum
