:: View topic - EF81
EF81
Reply to topic     Forum Index -> Non Czech Languages Here
vdragoslav
Phone: C75, E71
170.64 SMM
PostPosted: Wed Nov 03, 2010 7:19 pm    Post subject: EF81 Reply with quote
Helo people!
I bought an used EF81 "containing" a problem: all java apps downloaded via built-in browser are un-transferable to the microSD or un-sendable via BT, for example.
Every application works just fine instead.., but I need to free memory without losing stuff.
What could be the cause? :-? What should I do to solve this?
P. S. A fresh situation: I can't access camera any more. Is it because of the broken-became flat cable?
View user's profile Send private message Send e-mail Yahoo Messenger
15518.64 SMM
PostPosted: Thu Nov 04, 2010 10:01 am    Post subject: Reply with quote
Hello vdragoslav! Try to find and use application BMC - brew mobile commander. I think it could help you, but I am not sure.
I do not know also exactly, how it is with sending via bluetooth. But when you try BMC, transfering files to memory card sholuld be possible. With a camera - yeah, broekn cable is the most probably reason....
vdragoslav
Phone: C75, E71
170.64 SMM
PostPosted: Wed Feb 20, 2013 6:30 pm    Post subject: Reply with quote
Something got in the way...
Now (actually it started at least an year ago) I have a problem concerning the battery... :-?
Please have a look here: http://www.youtube.com/watch?feature=player_detailpage&v=0a1E42Fan2Y
then here: http://www.youtube.com/watch?feature=player_detailpage&v=o2gg6Zp-AVk
and tell me why is this happening!?..?
Actually, if I extract the accumulator even during the charging and, after a few seconds, I put it back, it is charged for a while, especially if it is warmed up in front of a radiator; but after a few minutes EF81 shows on the main display "Wrong battery! Please check or replace".
Of course, it doesn't stay charged and frequently doesn't allow the phone to charge it without firstly force-charging it with a 12-24V power charger for a few seconds, noticing the currnt on an ampermeter...
http://dfiles.eu/files/bpyzk8gko
Phone: nyní S75
96233.80 SMM
PostPosted: Wed Feb 20, 2013 10:07 pm    Post subject: Reply with quote
I have same problem with EF81. I bought 2 unoriginal battery and with both battery is same problem. In the display is "Wrong battery! Please check or replace". I will have 2 original battery early. I hope that the problem disappears. Pray
Have you the original or unoriginal battery?
vdragoslav
Phone: C75, E71
170.64 SMM
PostPosted: Thu Feb 21, 2013 8:47 am    Post subject: Reply with quote
Thank you for your quick answer! :>
I only have the original battery.
Now I thank you for actually warning me on those unoriginal accumulators!
I intend to buy soon one of these:
1. http://www.ebay.de/itm/ORIGINAL-BenQ-Siemens-EF81-Li-Ion-Akku-EBA-160-Siemens-EF-81-Batterie-NEU-/270980301056?pt=DE_Handy_PDA_Akkus&hash=item3f17af4100&_uhb=1#ht_9282wt_247
2. http://www.ebay.de/itm/Akku-Li-Ion-fur-BenQ-Siemens-EF81-EF82-ersetzt-EBA-160-/230792253151?pt=DE_Handy_PDA_Akkus&hash=item35bc4a4edf&_uhb=1#ht_1138wt_985
3. http://www.ebay.de/itm/AKKU-fur-BENQ-SIEMENS-BENQSIEMENS-EF81-EF-81-Li-ION-EBA-610-/290813565629?pt=DE_Handy_PDA_Akkus&hash=item43b5d6dabd&_uhb=1#ht_938wt_644
4. http://www.ebay.de/itm/Akku-Batterie-Accu-fur-BENQ-Siemens-EF81-EF-81-EF82-EF-82-EBA-610-1200-mAh-/330862288994?pt=DE_Handy_PDA_Akkus&hash=item4d08ede062&_uhb=1#ht_1673wt_1135
So please tell me which one is suitable for our EF81s!? :-?
If you have other solutions, maybe betterr and cheaper, I'd like to know!
So share your experience, please! :>
Or this is not about the battery? Then the firmware should contain a problem, isn't it?!?
Phone: nyní S75
96233.80 SMM
PostPosted: Thu Feb 21, 2013 9:56 am    Post subject: Reply with quote
I have Arrow this new battery and I have problem with her.
Cheaper original battery is here. I will have new original battery for the same price from Slovakia.
You don't buy battery yet. I will have new original battery next week and I will tell you if it works Smile If the original battery will not work, it's probably a bad software in phone.
How do you long use your original battery?
vdragoslav
Phone: C75, E71
170.64 SMM
PostPosted: Thu Feb 21, 2013 11:18 am    Post subject: Reply with quote
All right! I see... :-? Did you already order the battery?!? For there's a solution here as well: http://allegro.pl/benq-siemens-ef-81-nowa-bateria-ef81-i3047289881.html
Of course I will wait paciently for your advise! :> Thank you!
I can't say I really used mine, because I bought the EF81 at the second hand... :">
So if I remember well, it didn't last more than an year; this was in the begining of 2010 or so... But worse than the battery is the camera now: it simply stopped working and blocks the menu until I long press the red button. I think I'll sell EF81 for parts, because I alread had a bad experience with it, despite of STAR WARS stuff in it. :">
Phone: nyní S75
96233.80 SMM
PostPosted: Thu Feb 21, 2013 2:44 pm    Post subject: Reply with quote
OK. I ordered battery yesterday. Battery should come to me next week Smile
Your battery may be bad, if you have one long. We'll see if the new battery will be good.
I don't know how to repair camera. You have firmware 58 on the phone?
144510.50 SMM
PostPosted: Thu Feb 21, 2013 6:35 pm    Post subject: Reply with quote
Maybe I'm wrong, but in my opinion, this force-charging is (even when done more than once) nothing good for the battery's health Think .
About the camera issue, try to flash the fw, but maybe there'll be a problem with NVitems Think
vdragoslav
Phone: C75, E71
170.64 SMM
PostPosted: Fri Feb 22, 2013 6:53 am    Post subject: Reply with quote
I am aware that this malfunction oould have the origin in the so called force charging. I actually believe it IS the cause due to the greater complexity of the EF81 compared to the same area of the diagram of an S-Gold telephone (if I remember well the category of CX, M, SK... 65).
So you say the faulty.., out of service battery is the only reason for thi behavior? :-? And if I replace with a new one the problem will disappear? Or the "wrong battery" destroyed something in the phone circuitry?
Phone: nyní S75
96233.80 SMM
PostPosted: Mon Feb 25, 2013 6:39 pm    Post subject: Reply with quote
Hi, new battery came me today Smile I charge battery and everything works. I'll try it for a long time and I'll see. But now it is OK. The problem was probably just in a bad battery. I recommend you buy only original battery Cool
nhuff90
9.30 SMM
PostPosted: Wed Apr 03, 2013 8:34 am    Post subject: Reply with quote
AppGeeker wmv mov video converter
http://www.ilikemall.com/how-to/convert-wmv-to-mov-mac.html
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
