vdragoslav kolemjdoucí
 Založen: 01. 02. 2006 Příspěvky: 11 Bydliště: Iasi, Romania Telefon: C75, E71 170.64 SMM
Zaslal: st listopad 03, 2010 7:19 pm Předmět: EF81 |
Helo people!
I bought an used EF81 "containing" a problem: all java apps downloaded via built-in browser are un-transferable to the microSD or un-sendable via BT, for example.
Every application works just fine instead.., but I need to free memory without losing stuff.
What could be the cause? :-? What should I do to solve this?
P. S. A fresh situation: I can't access camera any more. Is it because of the broken-became flat cable?
Naposledy upravil vdragoslav dne pá únor 22, 2013 7:22 am, celkově upraveno 1 krát |
rattle-snake všeználek
 Založen: 01. 04. 2008 Příspěvky: 613 Bydliště: Varnsdorf
15518.64 SMM
Příspěvky na SM: 460,- |
Zaslal: čt listopad 04, 2010 10:01 am Předmět: |
Hello vdragoslav! Try to find and use application BMC - brew mobile commander. I think it could help you, but I am not sure.
I do not know also exactly, how it is with sending via bluetooth. But when you try BMC, transfering files to memory card sholuld be possible. With a camera - yeah, broekn cable is the most probably reason.... _________________ Siemens mobile stále s námi!
Zaslal: st únor 20, 2013 6:30 pm Předmět: |
Something got in the way...
Now (actually it started at least an year ago) I have a problem concerning the battery... :-?
Please have a look here: http://www.youtube.com/watch?feature=player_detailpage&v=0a1E42Fan2Y
then here: http://www.youtube.com/watch?feature=player_detailpage&v=o2gg6Zp-AVk
and tell me why is this happening!?..?
Actually, if I extract the accumulator even during the charging and, after a few seconds, I put it back, it is charged for a while, especially if it is warmed up in front of a radiator; but after a few minutes EF81 shows on the main display "Wrong battery! Please check or replace".
Of course, it doesn't stay charged and frequently doesn't allow the phone to charge it without firstly force-charging it with a 12-24V power charger for a few seconds, noticing the currnt on an ampermeter...
http://dfiles.eu/files/bpyzk8gko |
mucasco všeználek
 Založen: 17. 11. 2006 Příspěvky: 694 Bydliště: okr. Pardubice Telefon: nyní S75 96233.80 SMM
Příspěvky na SM: 310,- |
Zaslal: st únor 20, 2013 10:07 pm Předmět: |
I have same problem with EF81. I bought 2 unoriginal battery and with both battery is same problem. In the display is "Wrong battery! Please check or replace". I will have 2 original battery early. I hope that the problem disappears.
Have you the original or unoriginal battery? _________________ Používám: C35i --> M55 + QuickPic --> S75 --> E71 --> SK65 --> C81 --> S75
Rádio s tanečními hity 90. let |
mucasco všeználek
Zaslal: čt únor 21, 2013 9:56 am Předmět: |
I have this new battery and I have problem with her.
Cheaper original battery is here. I will have new original battery for the same price from Slovakia.
You don't buy battery yet. I will have new original battery next week and I will tell you if it works If the original battery will not work, it's probably a bad software in phone.
How do you long use your original battery? _________________ Používám: C35i --> M55 + QuickPic --> S75 --> E71 --> SK65 --> C81 --> S75
Zaslal: čt únor 21, 2013 11:18 am Předmět: |
All right! I see... :-? Did you already order the battery?!? For there's a solution here as well: http://allegro.pl/benq-siemens-ef-81-nowa-bateria-ef81-i3047289881.html
Of course I will wait paciently for your advise! :> Thank you!
I can't say I really used mine, because I bought the EF81 at the second hand... :">
So if I remember well, it didn't last more than an year; this was in the begining of 2010 or so... But worse than the battery is the camera now: it simply stopped working and blocks the menu until I long press the red button. I think I'll sell EF81 for parts, because I alread had a bad experience with it, despite of STAR WARS stuff in it. :"> |
mucasco všeználek
Zaslal: čt únor 21, 2013 2:44 pm Předmět: |
OK. I ordered battery yesterday. Battery should come to me next week
Your battery may be bad, if you have one long. We'll see if the new battery will be good.
I don't know how to repair camera. You have firmware 58 on the phone? _________________ Používám: C35i --> M55 + QuickPic --> S75 --> E71 --> SK65 --> C81 --> S75
NoviS řád zlaté antény
 Založen: 01. 08. 2008 Příspěvky: 857 Bydliště: Praha Telefon: EF81 144510.50 SMM
Příspěvky na SM: 115,- |
Zaslal: čt únor 21, 2013 6:35 pm Předmět: |
vdragoslav napsal: |
Maybe I'm wrong, but in my opinion, this force-charging is (even when done more than once) nothing good for the battery's health .
About the camera issue, try to flash the fw, but maybe there'll be a problem with NVitems  _________________ A52 -> M65† -> SXG75† -> SK65 -> S75 -> SX1 -> SK65 + S75 -> SL75, SK65, S68, S65, EF81... prostě pořád nějaký SIEMENS
->MOJE SBÍRKA<- |
Zaslal: pá únor 22, 2013 6:53 am Předmět: |
I am aware that this malfunction oould have the origin in the so called force charging. I actually believe it IS the cause due to the greater complexity of the EF81 compared to the same area of the diagram of an S-Gold telephone (if I remember well the category of CX, M, SK... 65).
So you say the faulty.., out of service battery is the only reason for thi behavior? :-? And if I replace with a new one the problem will disappear? Or the "wrong battery" destroyed something in the phone circuitry? |
mucasco všeználek
Zaslal: po únor 25, 2013 6:39 pm Předmět: |
Hi, new battery came me today I charge battery and everything works. I'll try it for a long time and I'll see. But now it is OK. The problem was probably just in a bad battery. I recommend you buy only original battery  _________________ Používám: C35i --> M55 + QuickPic --> S75 --> E71 --> SK65 --> C81 --> S75
nhuff90 kolemjdoucí
Založen: 03. 04. 2013 Příspěvky: 1
9.30 SMM
