:: View topic - EDGE connection problem happened to all EDGE models
eboy442000
26.04 SMM
PostPosted: Fri Jan 06, 2012 2:36 pm    Post subject: EDGE connection problem happened to all EDGE models Reply with quote
Hi, 1st post here from probably the only user of Siemens mobile in Hong Kong.
I use Siemens mobile as a modem to connect the computer to internet, but I find out that whenever the connection speed is over 160kb/s the phone stop responding in 1-5mins.
I have tried Siemens EDGE models s75, SL71, EL71, C81. All are having the same problem. Does anyone have a solution? Thank you!!!
I have search throught the internet and cannot find a solution.
14311.82 SMM
PostPosted: Fri Jan 06, 2012 10:01 pm    Post subject: Reply with quote
Years ago I have used Siemens modem of mobiles for connections PC to internet. I have solved some similar problem with service center, that consulted it with Siemens Center, but I newer knew why modem of mobile was asleep - stoped. I did some special logs.
I used modem by Bluetooth and I recovered that I set "recovery" interval on the site of PC to minimum = 1 min., default was 10 min, so this problem was solved. But each modem may stop after certain time, so I setup that PC starts automatically after 1-3 sec when modem stoped.
eboy442000
26.04 SMM
PostPosted: Sat Jan 07, 2012 5:22 am    Post subject: Reply with quote
Thank you so much for your reply. Where can i set the recovery time?
My Siemens modem not only stop responding, it hangs, and i have to take out the battery and switch on the phone again. Did you have the same problem?
Probably the only Siemens mobile left in Hong Kong.
AF51
CX65, C81, CF110
EF81, EF91
M65
s35, S45, S65, SK65, S75, SXG75, s68, s81
SL75, SF71, SL91
SX66
P51
