:: View topic - "run MIDP-TCK" a "Run CLDC-TCK"
Reply to topic     Forum Index -> Siemens
Seten
3061.00 SMM
PostPosted: Mon Dec 13, 2004 6:16 pm    Post subject: "run MIDP-TCK" a "Run CLDC-TCK" Reply with quote
Vie niekto co to je v netmonitore-java- "run MIDP-TCK" a "Run CLDC-TCK". SL45i
Ked to spustim tak ma zacne pripajat a to dost dlho. Ked to vypnem tak prestane ale po par sekundach zacne zas. Mne to pripaja na nejake
+4681100123
Kopiruje to data cez net a bere to aj na kredite. Robi to cez ETA.
SX1 , SL45i, SL45i.
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Mon Dec 13, 2004 7:50 pm    Post subject: Reply with quote
taky sem to zkousel, snazi se stahnout nejake aplikace ale pravdepodobne uz na dane adrese nejsou... mozna nejake testovaci Question
Koupím Siemens, který nemám.
Seten
3061.00 SMM
PostPosted: Thu Dec 16, 2004 7:27 pm    Post subject: Reply with quote
Quote:
Ashwin Rao, a Staff Engineer at Sun, has written an overview of the Siemens Mobility Toolkit, a tool to develop and test applications specifically targeted for the Siemens M50, a handset device based on the popular SL45i phone. The phone utilizes the JavaTM 2 Platform, Micro Edition (J2METM).
The M50 belongs to the Connected Limited Device Configuration (CLDC) group of devices. The CLDC is a JavaTM platform specification targeted at devices that are resource constrained, and with a memory limitation between 60-512 KB. The CLDC provides for a minimum set of features, exposed as Java APIs and corresponding tools, for basic cross-platform interoperability. The Mobile Information Device Profile (MIDP) sits on top of the CLDC and provides another set of core component APIs.
There are also the Siemens-specific APIs, called the Siemens Extensions. The M50 handset architecture has enhanced features distinguishing it from the common MIDP architecture, including specific architectural improvements and components with advanced functionality. The APIs addressed in the Siemens Extensions enable developers to take advantage of these unique feature sets and architectural improvements, and create applications that enhance user experience with the mobile device.
Siemens Mobility Toolkit Components and Applicability
The Siemens Mobility Toolkit (SMTK) comprises all the components required to develop, package, deploy and test applications targeted for the M50 platform, including:
The Precise Phone Emulator
API Packages for the emulator itself
The Preverifier tool
JavadocTM software-based API documentation for the CLDC, MIDP and Siemens Extension APIs.
While the SMTK may also be used as a standalone tool, when used in conjunction with SunTM ONE Studio 4, Micro Edition (formerly ForteTM for Java 4, Micro Edition), it provides a powerful, highly productive development environment. Sun ONE Studio 4 Micro Edition comes preconfigured with the J2METM Wireless Toolkit, and code templates for MIDlet development. The graphical user interface, provides click-and-go development tools to compile, preverify, package and test. Default emulators are also provided. With the SMTK installed, development against the Siemens Extensions is enabled, providing an opportunity to create unique applications and test them using the M50 emulator.
Currently in a beta version, the SMTK can be downloaded (registration required) from the Siemens Developer Village. An outline of the installation and configuration procedure is available on the Web site. There are also details of working with the SMTK, debugging applications, and deploying to the emulator.
Trosku som hladal
SX1 , SL45i, SL45i.
Reply to topic     Forum Index -> Siemens All times are GMT + 1 Hour
