Nueng kolemjdoucí
Založen: 05. 02. 2005 Příspěvky: 6
Zaslal: pá únor 18, 2005 12:49 pm Předmět: Need schematic cable for flash X65 and new phone |
Need schematic cable for flash X65,SX1,SL55,.......New siemens Phone
SURE AND EASY!!!!!!!!!!!!!!
I got this Picture
http://www.mobile-files.ru/forum/attachment.php?s=&postid=166938
(username: hanni76 and password: hanni)
but I want to ask some question
It can use with SST,X65Flasher,winswup and XXX.Xbz?
I want to use it with there
Flasher and upgrade firmware
should I install usb driver ? where the driver
Please help me |
jdobry rozumbrada
 Založen: 22. 01. 2005 Příspěvky: 381
Zaslal: pá únor 18, 2005 1:18 pm Předmět: equvalent to DCA-540 |
Add http://www.mobile-files.ru/forum/attachment.php?s=&postid=166938
This cable is eqivalent to DCA-540 cable with same limitation. This mean, that you can use only MCM software and oficial SW update.
Not exist way, how to use SST,X65Flasher,winswup, EEPROM tool and etc.
You must use DCA-510 cable for it, or MA-8730-C, or MA-8720-C with modification (disconnect pin 1 on connector, use switch) |
Nueng kolemjdoucí
Zaslal: so únor 19, 2005 11:41 am Předmět: |
where i find its (schematic of cable ) |
