re5pekt začátečník
 Založen: 25. 11. 2004 Příspěvky: 64 Bydliště: Jandova 14, OSTRAVA
Zaslal: ne únor 20, 2005 7:52 pm Předmět: c55 a "call-list" |
Nevíte náhodou o nějakém patchi, co by zapsal všechny hovory a jejich délku do nějakého txt souboru. U s55 je na to tento patch kód: | ; Call Logging v3b
; Author: Chaos, converted to S55v20 by ACiD [mrp]
; Firmware: S55v91
; Homepage: www.gsm-dev.com
; new: Better Log Format by ACiD [mrp]
; - added an ',' between each information
; - changed Type into "In", "Out", "Missed"
; After installing the Patch Information about Calls are stored in a:\calls.txt
; Format: "Date, Time, Type, time of calling, Number"
; (Type: Out = Dialed, In = Incoming, Missed)
; Examples:
; 21.01, 14:56, Out, 00:54, 112
; 21.01, 14:57, In, 00:32, 112
; 21.01, 15:00, Missed, , 112
; Hint:
; Dialed numbers with time 0:00 will not be logged.
23AC76: DA6322A6 DA7B0095
003B9400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 001F1C1F1E1F1E1F1F1E1F1E1F000000
003B9410: FFFFFFFFFFFFFFFFFFFFFFFFFF 613A5C63616C6C732E74787400
003B9500: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 26F03000F0F088C088D088E0D7400700
003B9510: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F10C163D06D7500700F6F15A14F6F1
003B9520: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C14D7500700F2FE5A14F2F1E2003D03
003B9530: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48E6EA907A96D7700D00F3F8BC04F3F9
003B9540: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BE04F3FAC004F3FBC2040D1329813D11
003B9550: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F83B0029913D0DE7F9170029A13D09
003B9560: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 29B13D01E1CBC0BD06FD0014D740EE01
003B9570: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A9AD26F13C009DEAF12ACA009696E7F2
003B9580: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2E00CA00BC96F12BCA009696CA00B296
003B9590: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F129CA009696E7F23A00CA00BC96F128
003B95A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB7ACA00B296D7500700F2FE5A14F2F1
003B95B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E2002D2A48E69D06E7F24900BB7FE7F2
003B95C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6E009D08E7F24F00BB79E7F27500BB76
003B95D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F27400BB73BB6DD7400700F2F4DE33
003B95E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400700F2F4E200E7F2FF00092126F4
003B95F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C009DFC06F43C00BB4EE7F23A00BB5E
003B9600: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F128BB49BB569D14E7F24D00BB57E7F2
003B9610: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6900BB54E7F27300BB51E7F27300BB4E
003B9620: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F26500BB4BE7F26400BB48BB42BB41
003B9630: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400700F2F45C1447F891003D03E7F2
003B9640: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2B00BB3CE6F5300FE6FE083CE6FE6014
003B9650: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D0ED7400700998EF128612B012ABB2E
003B9660: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F1287C41612B412B2D02012ABB272991
003B9670: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9DF0E1D2BB23E1A2BB2198E098D098C0
003B9680: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88F0DA6322A698F0F0E020FE2D01BB19
003B9690: FFFFFFFFFFFF 06F03000DB00
003B9696: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F32F00093127F20A009DFC07F23A00
003B96A6: FFFFFFFFFFFFFFFFFFFFFFFF 8810F123BB089810BB06CB00
003B96B2: FFFFFFFFFFFFFFFFFFFF E7F22C00BB02E7F22000
003B96BC: FFFFFFFFFFFF B92F08F1CB00
003B96C2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F08EF09F26F01000F0E066FEFF3FF2FF
003B96D2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 02FE88F088E006FE080088F088E0E6FD
003B96E2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF EE01E6FC1014E6FE0101E6FF8001DAD2
003B96F2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ECAD46F4FFFF3D0306F008000D17ECF4
003B9702: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0C4E00DE00EE02FDAD242AFF0D866FD
003B9712: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF3FF2FE02FEF0F9FCF8F0C8DAD292AF
003B9722: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 080498D098E0F0C8DAD2D4AF06F01000
003B9732: FFFF CB00 |
_________________ kuchi*cz |
