:: View topic - Je to na reklamaci ?
stinger.
PostPosted: Tue Feb 22, 2005 9:15 pm    Post subject: Je to na reklamaci ? Reply with quote
Uz jsem se tady o tom zminoval.Ale zacina me to cim dal tim vic list na nervy! Proste vcera se mi mobil sam prepl o hodinu nazpet (nevim jestli nebylo tim ze sem mel nastaveno automaticke zjisteni casu)
A porad se radi spatne ty smsky.Proste mi za den dojde pres 50 sms a je to pohazeny jak chce e je uplne jedno jestli mam nastaveno tridit podle stavu nebo casu Sad
Kamosovi to nedela a fw mame oba 25.Takze me to docela hodne stve:(Ale zase bez nej byt mesic...to nevim.
Poradte prosim...
JenaM
5904.88 SMM
PostPosted: Tue Feb 22, 2005 9:31 pm    Post subject: Reply with quote
na reklamaci asi ne ale skus prehrat FW!!!
koscik
5862.50 SMM
PostPosted: Tue Feb 22, 2005 9:44 pm    Post subject: Re: Je to na reklamaci ? Reply with quote
Poradte prosim...
S timhle bys na reklamaci nepochodil...
JenaM
5904.88 SMM
PostPosted: Tue Feb 22, 2005 9:46 pm    Post subject: Reply with quote
no to asi ne ale kdyz zajdes do servisu tak jim rekni bud tvuj problem a nebo radsi jen at ti prahraji FW!!!!!
koscik
5862.50 SMM
PostPosted: Tue Feb 22, 2005 9:48 pm    Post subject: Reply with quote
Jojo to udelej- 100% software zalezitost
JenaM
5904.88 SMM
PostPosted: Tue Feb 22, 2005 9:51 pm    Post subject: Reply with quote
nic vic poradit nemuzeme...sand ti novej FW pomuze!!!
stinger.
PostPosted: Tue Feb 22, 2005 9:57 pm    Post subject: Reply with quote
diky moc !! Mel sem tam fw 16 a prehral na 25 takze jedine prehrat znovu.
Tel se snazi dat sms od stejnych odesilatela k sobe Wink
Stanley497
PostPosted: Tue Feb 22, 2005 10:48 pm    Post subject: Re: Je to na reklamaci ? Reply with quote
Poradte prosim...
a to jak se ti prepl nazpet tak to je tim ze mas nastavene spatne casove pasmo nevm jestli jsem spravne pochopil otazku
