:: View topic - zalohovanie
zalohovanie
Goto page 1, 2  Next
1bubko2
PostPosted: Thu Feb 24, 2005 7:28 pm    Post subject: zalohovanie Reply with quote
ked si davate zalohovat mobil zalohuje sa vam vseko mne nie.nabehne mi taka hodne dlha tabulka a tam mi vypise co sa nezalohovalo a je toho pomerne dost zrovna to co som chcela zalohovat.co s tym?
Think Think
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 1:37 pm    Post subject: Re: zalohovanie Reply with quote
Think Think
Přes co? a co zálohuješ?
dantm
PostPosted: Fri Feb 25, 2005 3:06 pm    Post subject: Reply with quote
Pred zalohovanim zkus nabootovat telefon se shiftem to je ta sipka nahoru - pak se pry nespusti nic pri startu a pujde vse zalohovat
1bubko2
PostPosted: Fri Feb 25, 2005 10:22 pm    Post subject: hmm Reply with quote
no ja to zalohujem cez v SDS a mam to cez kabel. ako sa to ma s tym shiftom nabootovat?
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 10:25 pm    Post subject: Reply with quote
To s tím Shiftem sem taky nepocopil Think
Jak si to myslel Question Think
1bubko2
PostPosted: Fri Feb 25, 2005 10:30 pm    Post subject: asi tak Reply with quote
no presne co ako s tym shiftom
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 10:34 pm    Post subject: Reply with quote
Někdo by to moh tady vysvětlit ! Dancing
1bubko2
PostPosted: Fri Feb 25, 2005 10:36 pm    Post subject: xi Reply with quote
len ci sa niekto taky najde Laughing
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 10:37 pm    Post subject: Reply with quote
Snad jo a jestli to nebudu vědět tak to neva
1bubko2
PostPosted: Fri Feb 25, 2005 10:40 pm    Post subject: no Reply with quote
no tebe neva ale ja si to potrebujem zalohovat
Embarassed
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 10:44 pm    Post subject: Reply with quote
Jako to sem napsal asi blbě, protože záloha je potřeba vždycky Shame on you Shame on you
1bubko2
PostPosted: Fri Feb 25, 2005 10:58 pm    Post subject: tak to ano Reply with quote
tak to je svata pravda len keby to islo
Xfantasy
(člen klubu SM)<br>všeználek
PostPosted: Fri Feb 25, 2005 11:22 pm    Post subject: Reply with quote
Pokud při zapnutí SX podržíš Shift až dokud ti nenaběhne operátor,tak se ti nezpustí aplikace které nejsou orig v symbianu.Takže ti nic nebude bránit v záloze tím,že je to načtený v paměti.
Fakt to funguje.Vždy když chci udělat zálohu,nebo načíst,tak to musim takto zpustit.....................
C35i;ME45@S45i;CF62
Gwin
0.84 SMM
PostPosted: Fri Feb 25, 2005 11:32 pm    Post subject: Reply with quote
Měl by se držet od vypnutí až po zapnutí.
1bubko2
PostPosted: Fri Feb 25, 2005 11:36 pm    Post subject: ok Reply with quote
vyskusame ,, uvidime!! wink
Goto page 1, 2  Next
Page 1 of 2
