egro badatel
 Joined: 04 Mar 2004 Posts: 127 Location: Piestany,Slovakia
Posted: Wed Mar 23, 2005 11:06 am Post subject: kabel DCA-5 |
Pri pripojeni kablu mi v mobile pise:
Acc: plugged in: DCA-5 DSP P.:0023/0011 ROM
to dca-5 je vlastne dca-500??? _________________ Ericsson A2628 -> Siemens C25 -> Siemens C45 -> Siemend MC60 fw.10 3,5MB + patche -> Siemens CXT65 (fw.16>50) 30 servisnych + kopec grafickych patchov
DCA 510 (prerobeny z DCA500)
Eurotel SK>T-Mobile SK |
kesu čestný člen
14913.56 SMM
Posted: Wed Mar 23, 2005 3:02 pm Post subject: Re: kabel DCA-5 |
egro wrote: | Pri pripojeni kablu mi v mobile pise:
to dca-5 je vlastne dca-500??? |
a ten kabel ti normálně funguje? _________________ http://www.gpsmaps.ic.cz - 50 GB zkalibrovanych map pro TrekBuddy a OziExplorer CE (Celá ČR - 1:100k,50k,25k,10k a 10k - letecká) + Evropa
Orpheus čestný člen
Joined: 25 Dec 2004 Posts: 3637 Location: Bratislava(SK)
14900.34 SMM
Posted: Wed Mar 23, 2005 3:07 pm Post subject: |
Odkial ho mas? Co je to zac? Je to orig? |
egro badatel
Posted: Wed Mar 23, 2005 4:33 pm Post subject: |
Ten kabel som kupil uz davnejsie. Daju sa cez neho posielat data...
Ale ked ho chcem spojit napr. z V-Klay tak sa nespoji.
Da sa bez zasahu do kabla nieco urobit aby sa mi s V-Klay-em spojil? _________________ Ericsson A2628 -> Siemens C25 -> Siemens C45 -> Siemend MC60 fw.10 3,5MB + patche -> Siemens CXT65 (fw.16>50) 30 servisnych + kopec grafickych patchov
MLB všeználek
Posted: Wed Mar 23, 2005 5:09 pm Post subject: |
egro wrote: | Ten kabel som kupil uz davnejsie. Daju sa cez neho posielat data...
Da sa bez zasahu do kabla nieco urobit aby sa mi s V-Klay-em spojil? |
Urcite sa nespoji? Mas loader alebo patch bootcore?
Inac, ak sa skutocne nespoji, tak bez zasahu do kabla to nepojde - a pokial je to klon 540, tak ani so zasahom..... _________________ CX70 fw56 |
egro badatel
Posted: Wed Mar 23, 2005 5:18 pm Post subject: |
Nemam ani loader a ani patch bootcore.
Co to je ten loader a patch bootcore?  _________________ Ericsson A2628 -> Siemens C25 -> Siemens C45 -> Siemend MC60 fw.10 3,5MB + patche -> Siemens CXT65 (fw.16>50) 30 servisnych + kopec grafickych patchov
skyjet začátečník
Posted: Wed Mar 23, 2005 5:34 pm Post subject: |
Len telefóny rady x65 a novšie vedia vypísať presne typ kábla (ako DCA-500, DCA-510, ...). Keď staršie telefóny rady x55 a x60 nájdu "orginálny" kábel od Siemensu, tak vypisujú len DCA-5 (aspoň čo ja viem - ak sa mýlim, tak ma opravte). _________________ C35i -> C60v27 + 4.14MB + strašná kopa patchov |
MLB všeználek
Posted: Wed Mar 23, 2005 5:43 pm Post subject: |
egro wrote: | Nemam ani loader a ani patch bootcore.
Co to je ten loader a patch bootcore?  |
No, mobil sa ti normalne nespoji, preto potrebujes bud vygenerovat laoder (tj. subor s kodmi, ktore ked sa poslu telefonu, tak sa spoji) alebo urobit cez Java aplikaciu v mobile patch bootcore, cim sa trochu upravi oblast pamati telefonu vdaka ktorej mobil komunikuje cez rozhranie, takze sa potom da spojit.
Bez patchu alebo laoderu to nepojde (akurat u x55 existuje chyba v bootcore vdaka ktorej sa spoji aj bez toho, ale je to len u starsich modelov).
Najdi si tu na SiemensManii clanok o patchovani..... _________________ CX70 fw56 |
egro badatel
Posted: Wed Mar 23, 2005 6:07 pm Post subject: |
A nie je ten patch bootcore nebezpecni?
Nerad by som si zabil mobil. Uz sa mi to raz podarilo...
Hod sem pls ten ten link. _________________ Ericsson A2628 -> Siemens C25 -> Siemens C45 -> Siemend MC60 fw.10 3,5MB + patche -> Siemens CXT65 (fw.16>50) 30 servisnych + kopec grafickych patchov
jenda^^ čestný člen
Posted: Wed Mar 23, 2005 6:09 pm Post subject: |
egro wrote: | A nie je ten patch bootcore nebezpecni?
Hod sem pls ten ten link. |
lepší je loader.  _________________ Teď mám: Nexus S
egro badatel
Posted: Wed Mar 23, 2005 6:12 pm Post subject: |
A ako vygenerujem ten loader resp. co mam urobit?
Ako to funguje?
DIK za odpoved.  _________________ Ericsson A2628 -> Siemens C25 -> Siemens C45 -> Siemend MC60 fw.10 3,5MB + patche -> Siemens CXT65 (fw.16>50) 30 servisnych + kopec grafickych patchov
jenda^^ čestný člen
Posted: Wed Mar 23, 2005 6:14 pm Post subject: |
Myslim, že by to mělo být tohle _________________ Teď mám: Nexus S
egro badatel
Posted: Wed Mar 23, 2005 6:15 pm Post subject: |
ok kuknem _________________ Ericsson A2628 -> Siemens C25 -> Siemens C45 -> Siemend MC60 fw.10 3,5MB + patche -> Siemens CXT65 (fw.16>50) 30 servisnych + kopec grafickych patchov
kesu čestný člen
14913.56 SMM
mrkni tady na tzy návody a hned ti bude vše jasný
http://www.siemensmania.cz/content.php?id=259
http://www.siemensmania.cz/content.php?id=333 _________________ http://www.gpsmaps.ic.cz - 50 GB zkalibrovanych map pro TrekBuddy a OziExplorer CE (Celá ČR - 1:100k,50k,25k,10k a 10k - letecká) + Evropa
egro badatel
Posted: Wed Mar 23, 2005 6:16 pm Post subject: |
Sa hlavne bojim aby som si mobil nezabil. _________________ Ericsson A2628 -> Siemens C25 -> Siemens C45 -> Siemend MC60 fw.10 3,5MB + patche -> Siemens CXT65 (fw.16>50) 30 servisnych + kopec grafickych patchov
