metink kolemjdoucí
Posted: Tue Jul 13, 2004 3:27 pm Post subject: Which programme creates LanguagePacks in .bin format? |
Hello guys
Sorry, but I can't speak your language..
I have a question:
Whith which programme can I create languagaePacks in .bin Format?
I only have languages in .lgp format, but they don't work with this patch:
http://www.mobilmania.cz/hosting/siemensmania/dir_upravy/m55-3,75MB.htm
I need a german language pack!!
Please help me!  |
Little_S čestný člen
Joined: 29 May 2004 Posts: 733 Location: 48° 45'N 18° 36'E
Posted: Tue Jul 13, 2004 5:01 pm Post subject: |
Siemens Language Editor can do that
i can send you german langpack in .bin format if you want
EDIT: but I need to know your FW version |
metink kolemjdoucí
Posted: Tue Jul 13, 2004 6:57 pm Post subject: |
thank you!
I have got fw11.
please send it to metink@gmx.at
PS: could you please send me the pack for v10 too?
EDIT: I thought that the Siemens Language Editor (1.4) can only make .lgp files?
Please tell me how you convert them into .bin!  |
Posted: Tue Jul 13, 2004 7:40 pm Post subject: |
I've sent you both LGPs |
metink kolemjdoucí
Posted: Thu Jul 15, 2004 12:59 pm Post subject: The patch works, but not correctly! :cry: |
thx Little_s for your e-mail!
Yesterday I tried the patch, but it did not work correctly!
All animations, pictures, texts, .... have disappeared.... (I don't mean the files in the card explorer ;-))
Take a look at these screenshots, please:
Phone in standby mode (where are the battery and antenna symbols?)
Menu (at Messages)
Card Explorer
Card Explorer Options (everything seems to be alright)
When I press some numbers in standby mode
My Menu
And here the proof that the patch worked
Do you know what has happened?
Today I'm going to try it again with the Czech languagepack.
Yours sincerely
metink
PS: This hapenned although I strictly followed these http://www.mobilmania.cz/hosting/siemensmania/dir_upravy/m55-3,75MB.htm instructions
(I used the german langpack that you have sent me) |
Posted: Thu Jul 15, 2004 1:24 pm Post subject: |
you have made something wrong
write you FuBu backup and patch it again
maybe you wrote langpack on wrong adress or size (don't change the size!!!) |
metink kolemjdoucí
Posted: Thu Jul 15, 2004 1:34 pm Post subject: |
Start adress: 0x9C0000
Are these values incorrect?
(I didn't change the size ) |
Posted: Thu Jul 15, 2004 1:40 pm Post subject: Re: The patch works, but not correctly! :cry: |
there is nothing wrong with the size ofthe disk, if you mean that 3 932 160 B = 3 840 kB = 3,75 MB
the LGP is ok, you can test in Smelter...if you don't trust me  |
metink kolemjdoucí
Posted: Thu Jul 15, 2004 1:43 pm Post subject: |
I mentioned the size of the German langpack in v_klay
So, what shall I do next after writing the fubu back to phone?
Shall I try it with the Czech langpack, like in the guidance? _________________ MT50 --> M55 fw11 3,625 MB |
Posted: Thu Jul 15, 2004 1:51 pm Post subject: |
V-klay should set size:
LGP FW10: D5F5
and FW11: D65F |
Posted: Thu Jul 15, 2004 1:56 pm Post subject: |
try it again with german langpack
aplly patch, turn on the phone, let it formate memory, after that turn it off and write g. langpack... |
metink kolemjdoucí
Posted: Thu Jul 15, 2004 1:59 pm Post subject: |
Look here:
(This is your german langpack for v11)
(I changed the start adress) _________________ MT50 --> M55 fw11 3,625 MB |
metink kolemjdoucí
Posted: Thu Jul 15, 2004 2:46 pm Post subject: |
Little_S wrote: |
aplly patch,
turn on the phone,
That's it!
I think I know now what I have done wrong
First I apllied the patch and then, without turning on the phone, I wrote the langpack to it!
I'm sure that this was my mistake...
Do you agree with me?
See you!
Posted: Thu Jul 15, 2004 3:10 pm Post subject: |
i dont know if is it a mistake but i do it like i wrote everytime (hope you understood ) |
metink kolemjdoucí
Posted: Fri Jul 16, 2004 3:04 pm Post subject: |
It has worked!!
Big thanks for your help, Little_S !!
PS: Of course I understand you  _________________ MT50 --> M55 fw11 3,625 MB |
