:: View topic - Problem u smart movie
bennys
PostPosted: Wed Apr 20, 2005 3:42 pm    Post subject: Problem u smart movie Reply with quote
Normalne si prekonvertuju video, po prekonvertovani ma asi 84mb, a pak si ho hodim do mobilu a v prehravaci mi to napise video je prilis velke pro zobrazeni. Nevite co s tim? Dik.
guiksilver
1262.50 SMM
PostPosted: Wed Apr 20, 2005 7:33 pm    Post subject: Reply with quote
Zaregistroval sis to? jinak ti to bude psát pořád!
bennys
PostPosted: Thu Apr 21, 2005 2:25 pm    Post subject: .. Reply with quote
prave ze mi to nejde.. mam verzi 2.72 dam request kod do playeru tam mi to vygeneruje kod, napisu ho do convertoru a napise to invalid key.a jiny verze mi nejdou, napise mi to program crash.
bennys
PostPosted: Thu Apr 21, 2005 6:18 pm    Post subject: .. Reply with quote
nevite nekdo jak se odemyka smart movie v 2.72 ?? hledal sem vsude a nikde sem nenasel licencni kod..
Guest
PostPosted: Tue May 24, 2005 3:40 pm    Post subject: Reply with quote
mam stejný problém!!!
jan.bartl
PostPosted: Tue May 24, 2005 4:05 pm    Post subject: Reply with quote
co tak si na irc stahnout KEY, vas nenapadlo
Dafko
3061.00 SMM
PostPosted: Tue May 24, 2005 4:06 pm    Post subject: Re: Problem u smart movie Reply with quote
U verzii 2.72 som s tym mal rovnaký problém no odkedy používam 2.73 ide bez problémov! Hodil som ju na spoločný mejl sexyone Wink
† I-Am-Lost
Nokia 3510i -> Siemens SX1 FW13 -> Siemens SX1 FW15 -> Nokia 7710
AndyS
670.00 SMM
PostPosted: Tue May 24, 2005 4:06 pm    Post subject: Reply with quote
co takle dat key na sexyone pro ty, kteri nemaji IRC nebo jim nejede?
(r)evolution:
Philips Savvy > Motorola V100 > Sony Ericsson Z200 > Siemens SX1 FW15CZ skinned + 512 PQI
AndyS
670.00 SMM
PostPosted: Tue May 24, 2005 4:27 pm    Post subject: Reply with quote
jinak k tomu problemu - taky mi to nefungovalo. Proto sem zvolil na prehravani 2.42 a kodovani VirtualDub. 2.42 mi funguje bez sebemensich problemu.
upravene - Sirus
(r)evolution:
Dafko
3061.00 SMM
PostPosted: Tue May 24, 2005 4:28 pm    Post subject: Reply with quote
2.42 je dobra ale to uz je klasika Smile Treba nieco novsie Smile
upravene - Sirus
† I-Am-Lost
AndyS
670.00 SMM
PostPosted: Tue May 24, 2005 4:31 pm    Post subject: Reply with quote
me se ta 272 taky libila, mela moznost nastavit kvalitnejsi zvuk a taky mela batch. kdyby mela jas / kontrast / saturaci, tak je perfektni Smile
(r)evolution:
Dafko
3061.00 SMM
PostPosted: Tue May 24, 2005 4:33 pm    Post subject: Reply with quote
ale ved to ma priamo implementovane v SM v SX1cke a ked tak pouzi FFDShow ako filter kde si nastavis jas a pod..
† I-Am-Lost
AndyS
670.00 SMM
PostPosted: Tue May 24, 2005 4:34 pm    Post subject: Reply with quote
jas ano, kontrast a saturaci uz ne. FFDShow mi nikdy nejel kvuli problemum s grafikou, nemuzu soudit.
(r)evolution:
Sirus
7910.50 SMM
PostPosted: Wed May 25, 2005 6:31 am    Post subject: Reply with quote
Trocha som to premazal a poupravoval. Nechceme na fore ziadny flameware a preto este raz upozornujem, precitajte si pravidla fora.
