:: View topic - DCA 540 od Fy KORACELL - driver
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Hardware
LIKO
PostPosted: Thu May 19, 2005 5:02 pm    Post subject: DCA 540 od Fy KORACELL - driver Reply with quote
Mám USB kabel DCA 540 od Fy Koracell a při instalaci s CD od výrobce to vypíše, že systém windows nemohl dokončit instalaci. Nevíte někdo o jiném driveru, nebo jak kabel zprovoznit ? WinXP, C65
LIKO
PostPosted: Sat May 21, 2005 7:21 am    Post subject: Reply with quote
Tak už je to vyřešeno - vadný kabel
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Hardware All times are GMT + 1 Hour
