:: View topic - Irda
Irda
wosa
PostPosted: Tue May 24, 2005 8:22 pm    Post subject: Irda Reply with quote
Nevíte někdo jak bych na notebooku IBM s infra prohlížel obsah MMC karty u SX1? Soft nebo něco podobného přes infra...dík
AndyS
670.00 SMM
PostPosted: Tue May 24, 2005 8:29 pm    Post subject: Reply with quote
1) nainstalovany original SW od siemense - kvuli ovladacum (SDS nebo MPM)
2) pouzit kuprikladu TENTO navod
(r)evolution:
Philips Savvy > Motorola V100 > Sony Ericsson Z200 > Siemens SX1 FW15CZ skinned + 512 PQI
Dafko
3061.00 SMM
PostPosted: Tue May 24, 2005 8:37 pm    Post subject: Re: Irda Reply with quote
Ziaden extra soft ti na to netreba, zapnes IrDA na SX1 a das ju k notebooku 15-20cm od jeho IrDA portu. Notebook SX1 sam detekuje a prideli ju ako vymenitelny disk. V zlozke najdes cely obsah SX1 vratane MMC karty.
† I-Am-Lost
Nokia 3510i -> Siemens SX1 FW13 -> Siemens SX1 FW15 -> Nokia 7710
Sirus
7910.50 SMM
PostPosted: Wed May 25, 2005 6:41 am    Post subject: Re: Irda Reply with quote
Toto urcite nefunguje na prehliadanie suborov na MMC. Pomocou tohto navodu sa daju posielat a prijimat jednotlive subory, ale nie prehliadat MMC.
Dafko
3061.00 SMM
PostPosted: Wed May 25, 2005 8:09 am    Post subject: Re: Irda Reply with quote
Aha to ma nenapadlo mas pravud ta sa tak odosielat na SX1 ako pomocou BT.. mrkem na web mozno existuje nejake utilitka..
† I-Am-Lost
jan.bartl
PostPosted: Wed May 25, 2005 9:15 am    Post subject: Reply with quote
staci spojit telefon na m router a pak pouzit plugin do total comanderu, a muzes prohlizet obsah celeho telefonu. ale nikda sem to nezkousel pres IR, ale tipuju ze kdyz to jde via kabel i BT, tak ir nebude vyjimkou
DOWNLOAD
Dafko
3061.00 SMM
PostPosted: Wed May 25, 2005 9:20 am    Post subject: Reply with quote
DOWNLOAD
Cez kabel to pochopitelne ide no uvidime ci to pojde aj cez IrDA, kazdopadne musis mat naistalovany mRouter, teraz vysla nova verzia a je ovela stabilnejsia!
† I-Am-Lost
jan.bartl
PostPosted: Wed May 25, 2005 9:21 am    Post subject: Reply with quote
no jde to i pres BT, a zatim vim o posledni verzi m router 3, ten pouzivam tak pul roku, je neco novsiho?
Dafko
3061.00 SMM
PostPosted: Wed May 25, 2005 9:23 am    Post subject: Reply with quote
3.0 je posledna ak dobre viem ale mam ete dajaku naviac podla vsetkeho Developer Edition, dajaku Betu Smile No nic hlavne to vyskusal a povedz ci to funguje
† I-Am-Lost
duuri
5874.50 SMM
PostPosted: Wed May 25, 2005 10:23 am    Post subject: Reply with quote
posle mi niekto prosim mrouter3 alebo aj tu betu alebo to dajte na sexyone
Dafko
3061.00 SMM
PostPosted: Wed May 25, 2005 10:29 am    Post subject: Reply with quote
Odoslane, ale ma to cez 7MB takze to chvilku potrva dokial to prijde na sexyone Exclamation
EDIT: Uz je tam, adresar Progs
† I-Am-Lost
jan.bartl
PostPosted: Wed May 25, 2005 12:00 pm    Post subject: Reply with quote
http://developer.intuwave.com/Downloads
novakl
PostPosted: Wed May 25, 2005 1:02 pm    Post subject: Reply with quote
Určitě to funguje ! Někdy to používám. Stačí mít nainstalovaný SDS+mRouter z CD, který bylo u SX1. Pak 2xkliknout na ikonu v liště a zatrhnout infračervený port. Zapneš IrDa na SX1, dáš k notebooku, mRouter ho detekuje a spustíš Tento počítač->Siemens SX1->MultiMedia Card
Alcatel 302 -> Nokia 3310 -> SonyErricson T310 -> Siemens M55 -> Siemens SX1 FW15 + 1Gb -> Přešel jsem na Nokii - Nokia N73 Music Edition
