:: View topic - S65 Nejde zapnout po vypadku proudu pri flashovani
Goto page 1, 2, 3, 4, 5, 6, 7  Next
jakubmildner
PostPosted: Mon Jun 20, 2005 6:55 pm    Post subject: S65 Nejde zapnout po vypadku proudu pri flashovani Reply with quote
Prosim o radu, jsem bez zalohy a telefon se mi ani nespoji s PC, mam kabel COM...telefon jen pipne :(Diky vsem za pomoc
Smeli
PostPosted: Mon Jun 20, 2005 7:03 pm    Post subject: Re: S65 Nejde zapnout po vypadku proudu pri flashovani Reply with quote
Zkus znovu přehrát fw, u WinSwup ale zaškrtni políčka pre a post check
SIEMENS S65 fw. 58
jakubmildner
PostPosted: Mon Jun 20, 2005 7:53 pm    Post subject: Reply with quote
Ok, jdu to vyzkouset...snad to zabere
jakubmildner
PostPosted: Mon Jun 20, 2005 7:57 pm    Post subject: Reply with quote
Hmm tak to pise, "couldn`t ping mobile" tak co ted? Crying or Very sad
jakubmildner
PostPosted: Mon Jun 20, 2005 8:10 pm    Post subject: Reply with quote
Nemate Nekdo Full Flash ve formatu BIN?
PostPosted: Mon Jun 20, 2005 8:17 pm    Post subject: RE: S65 Nejde zapnout Reply with quote
A spoji sa Ti s V-klayom?
jakubmildner
PostPosted: Mon Jun 20, 2005 8:31 pm    Post subject: Reply with quote
S Klayem se mi taky nespoji, fakt uz nevim co s tim, jen pipne nic vic Sad
PostPosted: Mon Jun 20, 2005 8:36 pm    Post subject: Re: S65 Nejde zapnout po vypadku proudu pri flashovani Reply with quote
Hmm tak to je zaujimave. A skusal si nahrat ff cez x65flasher? Alebo sa ani s tym nespoji?
jakubmildner
PostPosted: Mon Jun 20, 2005 8:40 pm    Post subject: Reply with quote
s tim se taky nespoji...fakt netusim Sad(((((
Guest
PostPosted: Mon Jun 20, 2005 8:42 pm    Post subject: Reply with quote
a zaskrtnul jsi ve WinSwupu u pre-check vpravo skip? potom zmackni cervene tlacitko. Pozor na spravne nastaveni COM portu.
jakubmildner
PostPosted: Mon Jun 20, 2005 8:43 pm    Post subject: Reply with quote
To jsem zkusil a nic ... nemohla se treba vymazat Epromka?
PostPosted: Mon Jun 20, 2005 8:44 pm    Post subject: Re: S65 Nejde zapnout po vypadku proudu pri flashovani Reply with quote
Hmm. Zaujimave. A naco si xcel zalohu ff?
jakubmildner
PostPosted: Mon Jun 20, 2005 8:45 pm    Post subject: Reply with quote
Kamos mi rikal ze se mu jednou stalo neco podobnyho, ze nabijel telefon, a pak vypadl proud a mel prej smazanou Epromku nebo tak neco a navic nemam servisni kabel Sad(
jakubmildner
PostPosted: Mon Jun 20, 2005 8:47 pm    Post subject: Reply with quote
ted jsem jeste zkousel ten winswup a napsalo mi to tohle "Error on waiting for Ack EOT"
PostPosted: Mon Jun 20, 2005 8:49 pm    Post subject: Re: S65 Nejde zapnout po vypadku proudu pri flashovani Reply with quote
Hmm. A aky si mal Fw a aky tam davas teraz?
Page 1 of 7
