sonix badatel
314.02 SMM
Posted: Fri May 20, 2005 12:27 pm Post subject: Jenom obnova? |
Jestli jsem to dobře pochopil, tak by se timto způsobem dalo nastavit v mobilu jakékoliv IMEI?
Orpheus čestný člen
Joined: 25 Dec 2004 Posts: 3637 Location: Bratislava(SK)
14900.34 SMM
Posted: Fri May 20, 2005 1:15 pm Post subject: |
fesak417 kolemjdoucí
Posted: Wed Jun 15, 2005 9:51 pm Post subject: |
Orpheus wrote: | No, ak budes postupovat podla navodu, to zapisovanie ti mobil nepokazi.. Urcite |
ale ked by si spravil zalohu bc co sa moze stat ??? To sa uz neda dat spat ????
i am baby with x65 |
Sh@dy táta fóra
Posted: Wed Jul 13, 2005 11:52 am Post subject: |
Pri zapisovani do BC mi V_Klay vyhodi: An unknown error occured when accesing COM3 - Loader: WriteMemory: Protected area. Acces danied.
Co teraz??? _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
Sh@dy táta fóra
Posted: Sat Jul 16, 2005 1:06 am Post subject: |
Vsetko mi uz poslo, ale telefon len pipne a nic nespravi... Co teraz???  _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
Sh@dy táta fóra
Posted: Sat Jul 16, 2005 1:22 am Post subject: |
Pomohlo by mi nahrat zalohu vratane bootcore? Asi hej, ale pockam radsej na rady od skusenejsich... Nie je to moj telefon, tak radsej nic neskusam. Ale bol by som radsej, keby to poslo spravit aj inak, aby ostalo IMEI zmenene. _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
Krokodýl čestný člen
Posted: Sat Jul 16, 2005 11:47 am Post subject: |
Sh@dy wrote: | Pomohlo by mi nahrat zalohu vratane bootcore? Asi hej, ale pockam radsej na rady od skusenejsich... Nie je to moj telefon, tak radsej nic neskusam. Ale bol by som radsej, keby to poslo spravit aj inak, aby ostalo IMEI zmenene. |
Pokud máš původní zálohu FF z toho telefonu, tak se nemusíš obávat povolit zápis do bootcore a mělo by být vše OK.
Musí se ti samozřejmě spojit s V-Klay, x65flasher má automaticky nastavené přeskakování zápisu do bootcore. _________________ Zálohovat, zálohovat, zálohovat!!!
Sh@dy táta fóra
Posted: Sat Jul 16, 2005 11:55 am Post subject: |
Spoji sa mi aj s V_Klay... Ale asi viem kde som spravil chybu. ESN kod v PapuaUtils ma byt aj po prepisani bootcore taky isty ako pred prepisanim? _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
Posted: Sat Jul 16, 2005 12:19 pm Post subject: |
Sh@dy wrote: | Spoji sa mi aj s V_Klay... Ale asi viem kde som spravil chybu. ESN kod v PapuaUtils ma byt aj po prepisani bootcore taky isty ako pred prepisanim? |
No mělo by to být vše původní. Pokud je jiné, doporučuji přepočet v PapuaUtils a nové generování. /zálohuj si ale původní, pro jistotu/ _________________ Zálohovat, zálohovat, zálohovat!!!
Sh@dy táta fóra
Posted: Sat Jul 16, 2005 12:20 pm Post subject: |
Nahravam zalohu... Vo V_Klay sa mi podarilo prepisat bootcore tym povodnym, ale potom mi vyhodilo chybu. Tak teraz nahravam zvysok cez x65flasher _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
Sh@dy táta fóra
Posted: Sat Jul 16, 2005 12:34 pm Post subject: |
Vsetko je OK Ale mne to neda pokoj a idem to este raz vyskusat... _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
Sh@dy táta fóra
Posted: Sat Jul 16, 2005 12:50 pm Post subject: |
Stale to neide... Zmenim IMEI a mobil sa potom nezapne. Len pipne a nic viac. _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
Posted: Sat Jul 16, 2005 1:12 pm Post subject: |
Sh@dy wrote: | Stale to neide... Zmenim IMEI a mobil sa potom nezapne. Len pipne a nic viac. |
Smůla, ale návod je 100% funkční. _________________ Zálohovat, zálohovat, zálohovat!!!
Sh@dy táta fóra
Posted: Sat Jul 16, 2005 1:17 pm Post subject: |
Nepomohlo by mi po zmene imei prehrat fw? Pise sa v navode, ze to ide pri fw 25 a nizsom, ale skusane to bolo asi pri fw 25. Je mozne, ze mi to neide preto, ze mam fw 16? _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
Sh@dy táta fóra
Posted: Sat Jul 16, 2005 4:07 pm Post subject: |
Spravil som to pri fw 25 a ide to! Takze asi to ide len pri fw25, alebo som mal nejaky specialny mobil _________________ A35 -> C35i -> M35i -> C60 +4.14MB+patche -> C62 -> C65 - CsL65 +patche+elf - novy displej //DEAD CPU -> C75 fw22+elf -> nokia 6300 + SIEMENS C65 |
