:: View topic - Mrtvej foun?
Mrtvej foun?
Johny007
PostPosted: Mon Jul 25, 2005 11:15 pm    Post subject: Reply with quote
forseti wrote:
Mi uz nehelpne co? Naky napady Pls Pray
Asi ne .. v tom pripade prodam super mobila M55 s FW91.. rozsirenej disk na 3,6MB s T9. Rok pouzivany,neopotrebeny,Iridium + USB kabel k tomu, bohuzel bez zaruky. Bohuzel mi odesla nabijecka a baterka je vybita takze nejde zapnout ale staci jenom "nabit" Whistle Angel Pri rychlem jednani bonus Siemens C25 nebo C35i =))
Za kolik? Ja si ho opravim.
M55 Iridium - TestPoint , FW11 + mojepatche.txt HP iPAQ 514 WM6
forseti
PostPosted: Tue Jul 26, 2005 12:36 am    Post subject: Reply with quote
Kolik das? =) Spis bych ho vymenil muj + money za nakou funkcni M55. Nejlepsi by bylo kdyby nekdo dostal nakej dalsi napad abych to zkusil rozchodit =)
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
Johny007
PostPosted: Tue Jul 26, 2005 11:47 am    Post subject: Reply with quote
Udelej testpoint a je to.
PostPosted: Tue Jul 26, 2005 11:55 am    Post subject: Reply with quote
U neho je testpoint zbytocny...telefon sa spojis so vsetkymi flashermi,ide nahrat zaloha,odblokovat....len telefon je napriek tomu mrtvy.
forseti
PostPosted: Tue Jul 26, 2005 12:56 pm    Post subject: Reply with quote
Takze testpoint mi nepomuze =/ No spoji se ale nejde nic nahrat. Este jak sem zkousel ten x65 Flasher tak guest15 rikal ze mam vytvorit/vyjmout loader z V klay .. ale nevim jak =)
PostPosted: Tue Jul 26, 2005 1:03 pm    Post subject: Reply with quote
x65Flasher je urceny specialne pre modely x65,x70...ten Ti je na x55 uplne k nicomu.
forseti
PostPosted: Tue Jul 26, 2005 2:07 pm    Post subject: Reply with quote
Hale jestli chces toho founa tak mi napis na ICQ =) Nak se domluvime, kupuju novyho potrebuju penny..
forseti
PostPosted: Tue Jul 26, 2005 2:20 pm    Post subject: Reply with quote
Este abych v tom mel jasno.. Co mam/nemam priste udelat aby se mi to nestalo?? Cemu se mam vyvarovat? =) Dik
Johny007
PostPosted: Wed Jul 27, 2005 12:19 am    Post subject: Reply with quote
Dobra otazka kdyz nevim co jsi udelal
Johny007
PostPosted: Wed Jul 27, 2005 12:20 am    Post subject: Reply with quote
TO se mi zda jako blbost, kdyz vezmes ze se sice spoje ale bootcore je poskozeny takze nedokaze zapisovat a navic NENI co ztratit takze hura na testpoint.
PostPosted: Wed Jul 27, 2005 7:27 am    Post subject: Reply with quote
bootcore je oblast telefonu,ktora sluzi na spojenie telefonu s programom...so zapisovanim nema nic spolocne.FF zapisuje uz potom program po blokoch do pamati.Praveze bootcore by sa malo pri tomto zapisovani obist.Ale su na nete repair baliky pre flashovanie aj bootcore s nastavenim BOOT...a tam sa prepisuje bootcore.
pIFKO
258.52 SMM
PostPosted: Wed Jul 27, 2005 3:35 pm    Post subject: Reply with quote
1. jakej mas v-klay? ja sem mel podobny problemy uz sem se chtel toho chudaka zbavit a sehnat nahradu a pak sem si poridil v-klay 3.3 a bylo po starostech. taky sem mel posahanou bootcore (chcipl proud pri zapisovani ff-zrovna v nepravou chvili) a ten v-klay me to nak spravil...a funguje v poho.
2. a co tam nahrat naky ty loadery..nekde je tady o tom clanek
presne tady:
http://www.siemensmania.cz/content.php?id=109
forseti
PostPosted: Thu Jul 28, 2005 8:41 pm    Post subject: Reply with quote
2 Johnny 007: Dit sem to tady psal =)) Uz sem chtel jit na bootcore.. ale nevim kde mam sehnat ten sroubovak, no hlavne sem se k tomu este nedostal snad po vikendu budu mit cas a zkusim to..
Edit: Nakej sroubovak torx5 ale nevim, neda se to otevrit i necim jinym nebo nak jinak?? ale zadnej extrem Hand
2 pIFKO: Dik zkusim...
forseti
PostPosted: Thu Jul 28, 2005 8:49 pm    Post subject: Reply with quote
presne tady:
Jo! Ted sem si to poradne precetl... Vklay 3.3 mam,pouzivam a ty flashery nenahraju protoze ten navod je jenom pro funkcni founy a ten muj je mrtvej, nic tam nenahraju... takze este naky navrhy? Ale dik za snahu wink Neutral Pray
forseti
PostPosted: Thu Jul 28, 2005 9:20 pm    Post subject: Reply with quote
?? A co zkusit ty repair baliky? =) A kdyz fakt nevim jestli by mi to pomohlo =)
Page 2 of 3
