:: View topic - C65 vs. CT65
C65 vs. CT65
Goto page 1, 2  Next
Guest15
Location: Frýdek-Místek (malé velkoměsto kousek od Ostravy :)
PostPosted: Wed Jan 12, 2005 9:17 pm    Post subject: C65 vs. CT65 Reply with quote
Zdarec Lidi, mam problem da se nejak u Siemensu CT65 docilit toho abych mel stejne menu ja u C65 tj. ze kdyz vejdete do menu a joystickem posunete doleva tak mate moznost fotoaparatu jenze u CT65 je to vstup do slozky Downloads, a ja se ptam esli se to da nejak zmenit a taky esli se da zmenit to ze u CT65 budete moct vstoupit do slozej jako treba Animace, MMS, Screensavery atd. proste jak u C65?!? Jde to nejak tim, ze nahraji novy firmfare?Nebo spis firmware urceny pro C65?diky za odpoved Pray Crying or Very sad
JenaM
5904.88 SMM
PostPosted: Wed Jan 12, 2005 9:24 pm    Post subject: Reply with quote
mozna FW ale neco na to je ted si presne nevzpomenu co ale hledej nekde to tu urcite je!!!
Dieg0
19990.28 SMM
PostPosted: Wed Jan 12, 2005 9:29 pm    Post subject: Reply with quote
Original zaloha pisal o tom clanok krokodil hodis si to tam a mas.Dieg0
Guest15
PostPosted: Wed Jan 12, 2005 9:36 pm    Post subject: Reply with quote
Diky moc lidi...me uz to od T-Mobile stvalo
Guest15
PostPosted: Wed Jan 12, 2005 9:37 pm    Post subject: Reply with quote
Jo a nevite nahodou jak se ten clanek jmenuje?
diablo
PostPosted: Wed Jan 12, 2005 10:13 pm    Post subject: Reply with quote
2 Guest15: Na uvodnej stranke Siemensmanie si daj vyhladavat http://www.siemensmania.cz/search.php typ telefonu a zobrazia sa ti vsetky clanky s nim suvisiace, tam ho uz lahko najdes. je to odstranenie reklam z mobilu.
M35 upravena -> MT50 tuned-> MC60 -> M55 fw10 ->fw11 ->fw91 (+patche) ->dead -> SX1 fw13 ->fw15 uk-de-ru ->fw15 uk-cz-sk + themes +1GB Pretec
For Blood is Life...
No11
PostPosted: Wed Jan 12, 2005 10:14 pm    Post subject: Reply with quote
Applause
mot m3888=>mot t2288R => N3310=>N3330=>N3410=>N6310i =>CT65 fw12, FW25,Clear T-mobile, FW33,=>M65 FW12,FW25 patched,FW33 patched, FW41 patched, FW 43 PAtched
Guest15
PostPosted: Wed Jan 12, 2005 10:19 pm    Post subject: Reply with quote
Jasne, vpoho ja hledam dal, neco sem nasel ale nic co by bylo presne coz je na hovno. No ale potreboval bych neco jak udelam z CT65 C65......nikde nic presneho Sad Sad
Dieg0
19990.28 SMM
PostPosted: Wed Jan 12, 2005 10:27 pm    Post subject: Reply with quote
Prekrytuj si ji a odstran reklamy Smile
No11
PostPosted: Wed Jan 12, 2005 10:30 pm    Post subject: Reply with quote
jj nejlépe FFSInit_C65_2_ru-RussianRetail_12_0239.exe ale nezapomeň si zálohovat celý telefon. a pak si tam nahrát českou T9 a adresář... wink
diablo
PostPosted: Wed Jan 12, 2005 10:36 pm    Post subject: Reply with quote
A co takto dat mu nejake linky Question Exclamation
No11
PostPosted: Wed Jan 12, 2005 10:41 pm    Post subject: Reply with quote
nejsem připojen nějakou zavratnou rychlostí, respektive GPRS... nemohu dovolit otevírat další okna navíc. A navíc jde to najít na SM ale tam to je v zipu.. Od2.2 budu mít stabilní připojení pak to nebude problem 8)
taii
PostPosted: Mon Aug 08, 2005 10:16 pm    Post subject: Reply with quote
kdyby neco tak C65 a CT65 sou UPLNE SOFTWAROVE STEJNY, jedinej rozdil je ze CT je delanej pro T-mobile a ma jinej dessign a kapku jinyovladani... ja tam mam FW na c65 a ssemm f poho... Dancing
A 50-> CT65-> CSLT65-FW53-DCA-510
Máme odpověď na všechny vaše otázky...
více na http://www.brambory.xf.cz ... wink
szkepek
PostPosted: Tue Aug 09, 2005 7:42 am    Post subject: Reply with quote
jj, mel by stacit nahrat novy FW pro C65 ku. Mozna bude zapotrebi zmenit typ telefonu, pomoci x65flasheru verze 1.0.35. Das tam aby se ukazoval jako C65 a pak nahrajes WinSwup...
Vita Circulus ést !!!
HenX
PostPosted: Tue Aug 09, 2005 7:51 am    Post subject: Reply with quote
Stačí jak si nahraješ zálohu disku config z c65 a pomocí DSE si změníš nastavení tlačítek My-C60
***Sony Ericsson K750i*** The best mobile!!!
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
Goto page 1, 2  Next
Page 1 of 2
