:: View topic - Kompletní návod Papua Utils 0.1.6
Goto page Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
lososs
PostPosted: Fri Aug 19, 2005 5:30 pm    Post subject: Reply with quote
muco wrote:
Loader pre V-klay mam uz s X65flasheru a aj FF. Uz som aj patch vyskusal ale ja potrbujem skor FREIA LOG. lebo s SST sa neda odblokovat ako ta prva S65 Very Happy Nepomohlo ani ked som dal kody rucne. Asi pockam na ten navod d'oh!
ja mam ten samy problem s SST,jinak vse chodi bez problemu Rolling Eyes
muco
PostPosted: Fri Aug 19, 2005 5:35 pm    Post subject: Reply with quote
lososs: Vygenerovalo ti vsetky kody v Papua utils? Ako si to robil? Question
+ 512 MB HAMA
PostPosted: Fri Aug 19, 2005 5:44 pm    Post subject: Reply with quote
A zratal si si v Papua SKey a zaviedol do telefonu?Pouzi starsi navod od Krokodyla,tam mas ukazane,ako zratat vsetky kody a aj loader,config a log do Freia.
muco
PostPosted: Fri Aug 19, 2005 5:59 pm    Post subject: Reply with quote
Pozrel som vsetky navody. Ale SKEY nechce vobec vypocitat. Shame on you
+ 512 MB HAMA
PostPosted: Fri Aug 19, 2005 7:24 pm    Post subject: Reply with quote
Ako to?
Najprv vypises okienka IMEI, ESN, a HASH.Potom zratas SKey a BKey,zapises SKey do telefonu a vygenerujes log....musi to ist.
muco
PostPosted: Fri Aug 19, 2005 7:50 pm    Post subject: Reply with quote
Skusil som to na mojom S a islo to hned. Ale na tom bratovom ani za B... Question
toto mi napise :Đŕń÷ĺň ęëţ÷ĺé...
Ęëţ÷ íĺ íŕéäĺí!
+ 512 MB HAMA
PostPosted: Fri Aug 19, 2005 9:27 pm    Post subject: Reply with quote
Tak to skus na inom compe...
PostPosted: Fri Aug 19, 2005 9:34 pm    Post subject: Reply with quote
Ęëţ÷ íĺ íŕéäĺí!
:Đŕń÷ĺň ęëţ÷ĺé... - Výpočet klíče
Ęëţ÷ íĺ íŕéäĺí! - Klíč nenalezen
Vypadá to že některá ze zadaných hodnot je špatně buď vypočítaná, nebo špatně opsaná.
tomasxxxx
PostPosted: Fri Aug 19, 2005 11:00 pm    Post subject: px64v4 z x65flasher-a 1072 nejde... Reply with quote
Tak ako napisal zdatan, ten java programik mi nesiel ako mal(cx70 fw54). Nekomunikoval ani s x65 flasherom ani s papuou a u papui nepomohlo ani rucne prepisanie kodov z displeja(ESN bolo uplne ine a vypocet nefungoval).Mohli by ste na stranku vlozit link na original px64v4 z 1071 flashera, s nim to totiz ide vsetko tak jak ma(presne ako v navode a na tom vasom videu). THX. Rolling Eyes
CX70 fw41 dca-540 ->fw43 dca510-> FW 54 zaloha ff->patche->umrtvenie->ozivenie Smile ELFPACK 2.3
PostPosted: Sat Aug 20, 2005 7:44 am    Post subject: Reply with quote
Na tom moze byt kus pravdy...ked som porovnal ESN vypocitane tou aplikaciou a ESN vypocitane v Papua Util,boli to uplne ine cisla...aspon u mna Rolling Eyes
zdatan
PostPosted: Sat Aug 20, 2005 9:13 am    Post subject: Reply with quote
jo presne tak...ESN kod kterej dostanu Papuou pri pouz.java apl.(px65v4) 1071 je jinej , nez ty kterej mi java apl 1072 ukaze na displayi!!! (hash je stejnej.jen esn nesedi)
este hani,krokodyle, v tom navodu je bod 6zapsat skey do tel, bod 7 odstranit...coz sem v tomhle poradi udelal:) takze co sem ted pochopil ten Skye mamm do tel.zapsat natrvalo, jo?Smile k cemu to tam je? btw: kdyz sem asi vygeneroval kody pro Vklay a potom stahnu FF bez zapsanyho Skeye...pokazil sem neco? na to je ten skey,co tam dela? diky moc.
M65 fw44res -> fw50cz
PostPosted: Sat Aug 20, 2005 9:42 am    Post subject: Reply with quote
Skey nech zapsaný v telefonu, je to systémová brána a servisní funkce ti bez něj nebudou chodit. V tom návodu není postup co máš udělat, ale co které tlačítko dělá.
zdatan
PostPosted: Sat Aug 20, 2005 9:56 am    Post subject: Reply with quote
ja vim..prave ten postup mi chybel:) oki...zapisu to tam,ale FF co sem z tel.vytahnul je v poradku ikdyz sem skey nemel zapsanej ne?
PostPosted: Sat Aug 20, 2005 10:01 am    Post subject: Reply with quote
ja vim..prave ten postup mi chybel:) oki...zapisu to tam,ale FF co sem z tel.vytahnul je v poradku ikdyz sem skey nemel zapsanej ne?[/quote]
Jo to je v pohodě, ale některé funkce bez zapsaného Skey /Factory mode/ nejdou, třeba obnova bloků eeprom atd...
zdatan
PostPosted: Sat Aug 20, 2005 12:55 pm    Post subject: Reply with quote
ja vim ze uz asi sem otravnej..ale proste bojim se abych neco ne***ral,takze dalsi..uz posl.otazka;) sem v servisnim modu, zapisu SKey..a hotovo?zapnu telefon? nebo Prejdu zpet do Normalniho modu??? jak clovek vlastne nevi co dela,proc co macka,tak tezko se dovtipit:(
Page 8 of 11
