:: View topic - patch CF62
patch CF62
krtek1
PostPosted: Sat Oct 15, 2005 5:03 pm    Post subject: patch CF62 Reply with quote
Můžete mi poradit jak ty *.vkp nahrát do CF62.Mám USB kabel ,ale pořád mi to hlásí: Typ souboru není podporován
PostPosted: Sat Oct 15, 2005 6:09 pm    Post subject: Reply with quote
Pomocou programu V_Klay
Drobcek9056
7860.92 SMM
PostPosted: Sat Oct 15, 2005 10:09 pm    Post subject: Reply with quote
Ale najprv by si si mal vygenerovat kody a precitat si vsetky clanky na Siemensmanii o patchovani a generovani kodov a taktiez o pouzivani VKlay. Think Inac s tym ani nepohnes,a ty co ti vravia,ze treba robit testpoint,tak je na to jednoduchsia metoda a to je to vygenerovanie kodov,ale viac mas v clankoch.
momentalne SL55 Smile
PostPosted: Sat Oct 15, 2005 10:40 pm    Post subject: Reply with quote
Na CF62 sa nic negeneruje..u nizsich verzii ide V_Klay s nastavenim Bootcore Bug, u novsich je potrebne patchnut bootcore,popripade urobit testpoint
krtek1
PostPosted: Sun Oct 16, 2005 9:45 am    Post subject: Reply with quote
Pořád se snažim prosťe se nech ce spojit s mobilem. Neexistuje jiná cesta? Embarassed Brick wall
PostPosted: Sun Oct 16, 2005 11:05 am    Post subject: Reply with quote
Nie, toto je jedina.
Skus skontrolovat ovladac, nastavenie portu,...
krtek1
PostPosted: Wed Oct 19, 2005 3:58 pm    Post subject: Reply with quote
Hlásí mi to pořád: A hardware I/O error was reported while accessmy COM3 - Loader:Open:No answer from boot Goboot_Bootcore Bug.bin Nevíte co to znamená?Do mobilu už jsem si taky nahrál pmx55amd ale to mi zase hlásí: Neznamý profil! Embarassed Brick wall
krtek1
PostPosted: Mon Oct 24, 2005 7:18 pm    Post subject: Reply with quote
No a nakonec jsem musel ze Simensmanie stáhnout *.bin a pomocí Steleromu ho pustit a už se mi to podařlo Very Happy Laughing
duky
PostPosted: Mon Oct 24, 2005 10:46 pm    Post subject: Reply with quote
prosim nemozes napisat co presne si stiahol a postup ako si pokracoval? plus firmware aky si mal povodny....tiez by som chcel do founu nejake patche...dik
krtek1
PostPosted: Tue Oct 25, 2005 1:35 pm    Post subject: Reply with quote
1.stáhni si program Smelter který najdeš na Simensmanii.
2.stáhni si taky ze Siemensmanie v sekci servis - zálohy paměti a stáhni si na CF62
3.nejdřív si Language vyber Czech
4.V menu Fulflash vyber Otevřít a vyber zálohu paměti kterou jsi předtím stáhl
5.Listuj pomocí písmen až se dostaneš k potřebné složce
6.bude se to ukládat do složky, kde máš zálohu.
