5874.50 SMM
ZeeRaX všeználek
Posted: Tue Nov 01, 2005 9:41 pm Post subject: Re: Emulator Scummvm aj na SX1 |
Hmm.. zajimava zkratka "SCUMM" - Script Creation Utility for Maniacs Mansion Virtual MAchine
cummVM lets you run these adventures: Adventure Soft's Simon the Sorcerer 1 and 2; Revolution's Beneath A Steel Sky, Broken Sword 1 and Broken Sword 2; Flight of the Amazon Queen; Wyrmkeep's Inherit the Earth; Coktel Vision's Gobliiins and games based on LucasArts' SCUMM (Script Creation Utility for Maniac Mansion) system. SCUMM is used for many games, including Monkey Island, Day of the Tentacle, Sam and Max and more. Compatibility with supported games is continually improving, so check back often.
Jeezisi to jsou stary hry By me zajimalo jak to na SXku vypada, vzdyt tam nemuze byt moc videt, i kdyz rozliseni je celkem blizko, ale porad to neni ono.
Pochopil jsem spravne, ze to je emu platformy PC (DOS) ? Nebo neco na ten zpusob.
Jo a diky Duuri za info , jsem o takovem emu neslysel..  _________________ Sagem RC 825-->Sony CMD-J5-->M55 FW 91 +novej kryt(od vyroby seka)-->SX1 FW: SMO_VII-->15CZ_patched->N70MOD
5874.50 SMM
Posted: Tue Nov 01, 2005 9:46 pm Post subject: |
jj asi tak nejak ale len starych lucas art adventur:) |
huncut pisatel
Posted: Tue Nov 01, 2005 9:51 pm Post subject: |
Tak to je paráda, jdu to hned otestovat, dík za info. |
Lewa táta fóra
 Joined: 30 Dec 2004 Posts: 1037 Location: ČR -> České Budějovice
Posted: Wed Nov 02, 2005 3:13 pm Post subject: |
Hmmm, nevím, co dělám blbě, ale ten emulátor mi nějak nechce jít. Ještě na to budu muset líp kouknout. _________________
Gwin čestný člen
0.84 SMM
Posted: Wed Nov 02, 2005 5:07 pm Post subject: Re: Emulator Scummvm aj na SX1 |
už sem to tu kdysi dávno psal  _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
5874.50 SMM
Posted: Wed Nov 02, 2005 8:46 pm Post subject: Re: Emulator Scummvm aj na SX1 |
Gwin wrote: | už sem to tu kdysi dávno psal  |
ale vtedy tusim nesiel:) |
Silencer badatel
Posted: Thu Nov 03, 2005 1:34 pm Post subject: |
Tu hru tam musim nahrat celou a pak to pres ten emulator spustit nebo jak to funguje? |
huncut pisatel
Posted: Thu Nov 03, 2005 6:37 pm Post subject: |
Hry spouštíš přímo z emulátoru, který si je sám detekuje podle toho, jestli je máš nahrané na disku.
Zkoušel jsem tu jednu hru, která je ke stažení z té stránky toho emulátoru (Queen něco) a hra na malém rozlišení vypadá opravdu nádherně. Jwn titulky jsou špatně čitelné - snad to u jiné hry bude lepší. |
5874.50 SMM
HDS rozumbrada
Posted: Fri Nov 04, 2005 3:21 pm Post subject: |
jj je to celkem stare akorat to bezelo jen na PDAckach.. ael jestli to bezi i na SXu taxi konecne zaparim FUll Throtla a Simmon the sorrcerer  _________________
Boris911 začátečník
Posted: Fri Nov 04, 2005 7:58 pm Post subject: |
To je zdarec!Me to nejde nainstalovat!
"Nedostatek pameti.
Prosim smazte nektere soubory!"
A to mam na
C: volne misto 2.5MB
E:300MB
RAM:6,95MB!
To me toci!!!!!
Uz jsem odinstaloval 5 programu a porad nic! |
huncut pisatel
Posted: Sat Nov 05, 2005 9:30 am Post subject: |
Mas malo mista na C. Zkus si neco smazat nebo presunout na E.
Pripadne existuje program na rozbaleni sis souboru, ktery pak nahrajes rovnou na E a C neni k instalaci tak vubec potreba, ted si ale nejak nemuzu vzpomenout jak se to jmenuje. |
ZeeRaX všeználek
Posted: Sat Nov 05, 2005 10:04 am Post subject: |
huncut wrote: | Mas malo mista na C. Zkus si neco smazat nebo presunout na E.
Treba UnMakeSis.. _________________ Sagem RC 825-->Sony CMD-J5-->M55 FW 91 +novej kryt(od vyroby seka)-->SX1 FW: SMO_VII-->15CZ_patched->N70MOD
Boris911 začátečník
Posted: Sat Nov 05, 2005 10:47 am Post subject: |
No, tak ja to zkusim.Pro Total Commander aje na to plug-in do skupiny archivy pro koncovku SIS.
http://ghisler.fileburst.com/plugins/pdunsis.zip
Ale stejne to vyresi nejlepe, az trojhmat #+*+cervene sluchatko.Asi budu Symbiana zase reinstalovat (trojhmat + prehrati sw pres WinSwUp). |
