:: View topic - Zmena C65 na SL65
Zmena C65 na SL65
Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 30, 31, 32  Next
DavidT
PostPosted: Tue Nov 08, 2005 10:31 am    Post subject: Reply with quote
Darth PZ wrote:
Anebo patch na zrychlení javy taky něco takové dělal.. wink
jj patch na javu dělá to,že ti nejde spustit identita přístroje musíš přes:menu-9-6-4 . wink
S: C65>M75 >Sony Ericsson P1i
Firmware:13
Operátor: Vodafone
Kabel: DCA-510
Stav telefonu: OK
Karta: RS-MMC DV 1024 MB
Pavel Cakl
PostPosted: Tue Nov 08, 2005 8:42 pm    Post subject: Reply with quote
Mobil se mě nechce spojit s V-Klayem :-( a tak tam nemůžu nahrát ty patche. HELP ME Hand
taii
PostPosted: Tue Nov 08, 2005 10:09 pm    Post subject: Reply with quote
ja sem si vygeneroval kody(doufam ze spravne podle navodu Rolling Eyes ) a porad V_klay rika jakobych je nemel... takovy to ze chaoskey2 neodpovida nebo co... poradi nekdo Question Crying or Very sad Crying or Very sad
A 50-> CT65-> CSLT65-FW53-DCA-510
Máme odpověď na všechny vaše otázky...
více na http://www.brambory.xf.cz ... wink
Xpert
PostPosted: Wed Nov 09, 2005 8:38 am    Post subject: Reply with quote
one question, this tunning from C65 to CSL65 doesn't change the SAR value? Is it safe for healt?
Michal Jerabek
Phone: N97
245.72 SMM
PostPosted: Wed Nov 09, 2005 1:40 pm    Post subject: Reply with quote
Lb01 wrote:
Ano loader *.ini nahraj do adresara, kde mas rozbaleny x65flasher. Zapni nastav port a rychlost. Stlac connect a na vyzvu kratko stlac cerv. tlac. Hned by sa mal pripojit. Pripajaj vypnuty telefon.
P.S. Citaj navod, je to v nom velmi podrobne popisane. wink
Nejde Crying or Very sad
PostPosted: Wed Nov 09, 2005 6:08 pm    Post subject: Reply with quote
@Xpert:
PLS can you explain SAR? Maybe than we can help you.
@Michal Jerabek:
Co nejaka chyba, hlaska? Nevypise nic? Mas loader (kod) z PapuaUtils?
Xpert
PostPosted: Wed Nov 09, 2005 9:51 pm    Post subject: Reply with quote
it is the level of radiation, every phone has his own SAR- Specific Absorption Rate , see the phone manual or specification, for C65 - The highest SAR value for this model phone when tested for use at the ear is 0,73W/kg ; CX65 - The highest SAR value for this model phone when tested for use at the ear is 0.59W/kg ; SL65- The highest SAR value for this model phone when tested for use at the ear is 0.58W/kg .
I don't know if using other soft for specific hardware makes deference.
PostPosted: Wed Nov 09, 2005 9:54 pm    Post subject: Reply with quote
I think this depends on hardware parts not on software. Think
szkepek
PostPosted: Thu Nov 10, 2005 8:19 pm    Post subject: Reply with quote
ee, tady je to jeste neco jinyho, proste telefon kixne, dela to asi MiniGPS, ale na tuty to nevim, po cistym FW mi to jelo, s patchema uz ne Sad
Vita Circulus ést !!!
jakaka
PostPosted: Thu Nov 10, 2005 9:36 pm    Post subject: Update firmware C65-CSL65 Reply with quote
Zdravim, neda se ten upgrade provest jenom nahranim jine verze firmware?
PostPosted: Thu Nov 10, 2005 10:41 pm    Post subject: Re: Update firmware C65-CSL65 Reply with quote
Nie.
Premenovanie je potrebne, aby ti telefon prijal update a potom patche su potrebne pre nastartovanie telefonu.
taii
PostPosted: Fri Nov 11, 2005 5:28 pm    Post subject: Re: Update firmware C65-CSL65 Reply with quote
Lb01 wrote:
Nie.
Takze by to TEORETICKY slo predelat na cokoliv, s tema patchema??
PostPosted: Fri Nov 11, 2005 5:40 pm    Post subject: Re: Update firmware C65-CSL65 Reply with quote
taii wrote:
Lb01 wrote:
Nie.
Ale naozaj len teoreticky. Tie patch totiz musi niekto vytvorit a otazka je ci sa mu to podari a ci to vobec je mozne prerobit. Ci to hardware povoli.
P.S. Nepytaj sa na ziadne ine prerabky ako co su popisane vo fore. Zatial nic ine neexistuje. Ked bude, bude o tom vediet kazdy.
taii
PostPosted: Fri Nov 11, 2005 5:43 pm    Post subject: Re: Update firmware C65-CSL65 Reply with quote
Jasne jen me to napadlo wink
jaby
PostPosted: Fri Nov 11, 2005 7:56 pm    Post subject: Reply with quote
a když už se mi nebude líbit csl65 tak si budu chtit udělat zpět c65 přehrát FW ale co ty patche (blbá otázka že)
CSL65 rozbitej-> mám K750i- CSL65 FW53+ ELF pack+ MP3.elf
Page 12 of 32
