:: View topic - Diskusia k funkcnosti patchov x65,CX70
Goto page Previous  1, 2, 3 ... 33, 34, 35 ... 43, 44, 45  Next
FFFranta
PostPosted: Fri Nov 11, 2005 9:59 pm    Post subject: Reply with quote
Lb01 wrote:
Ak mas tovarensky FW50 menis do telefonu nedostanes.
Vygeneruj kody podla tohto navodu:
Arrow http://siemensmania.cz/content.php?id=524
...no a pokud to dobre chapu, tak si tim vytvorim loader pro v_klay a potom se mi to spojis telefonem a muzu tam normalne rvat patche...
Jeste se chci zeptat, muzu teda na CX70 pouzit V-Klay 3.2 a pouzit u vyberu telefonu CX65 (Password boot)? Nebo ma nejakej novej V-klay i primo CX70?
No a jeste mam jeden problem. Pri spusteni px65v4 mi to prvne (spravne, podle toho navodu) napise "Local connection? (com0)" Tak to povolim a potom to napise "Please connect accessory" a ceka. Jakmile zapojim svuj kabel, tak to na sekundu zmizi, objevi se jenom please wait, a pak zase hlaska "Please connect accessory" a zase a takle se to strida... Je to asi spatnym kabelem a melo by tam stacit podle toho navodu na SM dodelat to napajeni, ze?
emil12
Location: Prešov-Slovensko Telefon:CX65@50 Kábel:DCA-510
4264.00 SMM
PostPosted: Sat Nov 12, 2005 8:36 am    Post subject: Reply with quote
Lb01 wrote:
No, vies ked prispevok len editujes nezobrazi sa to ako nieco nove a nik sem potom ani nepride.
Inak je to tato cast:
Code:
1654610: 08 12 ;Y - Provider name
Uz to facha dikes Applause
Simens CX65-->FW50+patche+DCA510=Super puper mobil Dancing
Môj E-Mail Arrow neviem nanho heslo Smile
Môj Web Arrow Smile
PostPosted: Sat Nov 12, 2005 6:21 pm    Post subject: Reply with quote
@FFFranta:
Ano , pochopil si to spravne. Po vygenerovani loaderov uzmes veselo patchovat. Nezabudaj ale na zalohu FF.
CX70 v ponuke hladat nemusis, ked budes mat loader (v tvare x65tvojimei.vkd alebo x65.vkd) nastavis ten.
Vyzera to tak, ze mas ozaj problem s kablom. Ale este predtym by som vyskusal prv zapojit kabel az potom spustit aplikaciu.
Az potom pripadne dorabat kablik.
PostPosted: Thu Nov 17, 2005 1:48 pm    Post subject: Reply with quote
Funguje niekomu tento patch CX65fw50 Ikona nabíjení na mainscreen?
Mne po zastrceni nabijacky telefon pipne a vypne sa. Rolling Eyes
dava
PostPosted: Fri Nov 18, 2005 11:48 am    Post subject: Re: Zvětšení paměti u CX70 Reply with quote
simp wrote:
Lb01 wrote:
Ano, balicek existuje aj pre CX70v50.
Arrow http://www.asterix.com.ru/download.php?X65/IncFlex_CX70v5003.rar
A je i na Siemensmanii? A postup bude stejný jako u CX65??? Můžu teda použít návod pro CX65 Question Question Question
Zvětšení paměti na CX70. Na Siemensmanii zatím návod není, ikdyž to bude určitě obdobný jako na CX65. Ale stejně si myslím, že takový pěkný telefon, který se poměrně rychle rozšiřuje a nahrazuje CX65, by si zasloužil svůj vlastní návod pro méně zkušené.
Určitě nejsem sám, kdo by si tento návod na Siemensmanii přál vidět. (doufám)
maxviper
PostPosted: Wed Nov 30, 2005 3:23 pm    Post subject: Reply with quote
Mám dotaz, aplioval jsem patch 384 (CX70 fw56) kromě teploty baterie, síly signálu, napětí a stavu baterie se mi tam objevuje ještě jeden údaj, ktertý nevím co znamená. Stránky autora jsou rusky tak ,že tam se moc nedozvím. Podle zdrojáku toho patche je to zřejmě profil, buď mi to ukazuje 1 nebo 6. Víte někdo co to znamená?
PostPosted: Wed Nov 30, 2005 4:28 pm    Post subject: Reply with quote
Daj screen displeja.
maxviper
PostPosted: Wed Nov 30, 2005 5:02 pm    Post subject: Reply with quote
svůj screen udělat neumim, tohle je screen toho co ten patch vyrobil, je to de facto to samý.
je to ta 6 vlevo skororouprostřed:)
PostPosted: Wed Nov 30, 2005 5:06 pm    Post subject: Reply with quote
Je to čislo profilu.
patchi si môžeš odkomentovať riadok a miesto čísel tam budú obrázky.
PostPosted: Wed Nov 30, 2005 5:13 pm    Post subject: Reply with quote
aha,jasne..to je verzia 4.1,ktora uz zobrazuje aj cislo prifilu...ak ho tam nechces mat,tuto veriu daj prec a nainstaluj starsiu verziu 3 alebo uprav tento riadok:
Code:
14: 00,24,80 00,24,C0 ;Profile
maxviper
PostPosted: Thu Dec 01, 2005 7:03 pm    Post subject: Reply with quote
hm a co je ten profil?
PostPosted: Thu Dec 01, 2005 7:05 pm    Post subject: Reply with quote
Stlač hviezdičku a pravé kontextové tlačidlo.
maxviper
PostPosted: Thu Dec 01, 2005 7:29 pm    Post subject: Reply with quote
jo aha d'oh! ani ve snu by mě nenapadlo ,že jde o tenhle profil..
maxviper
PostPosted: Fri Dec 02, 2005 12:16 am    Post subject: Reply with quote
no tak starší verzi tohohle patche jsem nesehnal, tam kde jsem koukal už měli tu novou
Brick wall chtěl bych si jednotlivé ukazatele rozmístit jinak a chtěl bych odstranit ten profil, ale vůbec se nevyznám v souřadnicích... už jsem s tím něco zkoušel ale v_klay to nevzal Anxious Mohl by mi někdo vysvětlit, jak to s těmi souřadnicemi je?
BEZY
81.16 SMM
PostPosted: Fri Dec 02, 2005 5:05 pm    Post subject: Reply with quote
nemáte někdo namluvenej čas pro Talking phone v.2? Ruštině sice trochu rozumim, ale česky je česky...
http://www.bezysoftware.net
Brew Mobile Commander 2.0
Page 34 of 45
