hotter badatel
 Joined: 04 Dec 2004 Posts: 141 Location: Lithuanian Phone: M55 47266.46 SMM
Posted: Sat Dec 10, 2005 5:56 pm Post subject: downloading java error |
When i am trying to download java with phone from wap (*.jad file) I have error:
How to fix it? maybe it is from patches? I applied develop menu patch but i changed in it only enable menu ###. _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
lacibogi čestný člen
Posted: Sat Dec 10, 2005 6:03 pm Post subject: |
You have writed there what´s your problem. You need to setup wap configurations. _________________ C(ME)75
Lasky |
hotter badatel
Posted: Sat Dec 10, 2005 6:35 pm Post subject: |
befour applying system patches it worked!!!!
And i check the settings it is good. _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
Posted: Sat Dec 10, 2005 6:37 pm Post subject: |
So just try to remove patches.  _________________ C(ME)75
Lasky |
hotter badatel
Posted: Sat Dec 10, 2005 6:48 pm Post subject: |
I dont know why but removing patches this proble dont disappear. After puting backup ff it disappear... its something with eeprom and develop menu. maybe the after enabling menu-->### that bug appear.  _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
hotter badatel
Posted: Sun Dec 11, 2005 10:59 am Post subject: |
I tryed to put eeprom backup but nothing changed
Where the problem could be? maybe the patch CX70 to SX70 have done that? _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
Posted: Sun Dec 11, 2005 11:29 am Post subject: |
Look, all the time you writes that maybe it is in some patch. So reflash FW, you will have clear phone and check it than. _________________ C(ME)75
Lasky |
hotter badatel
Posted: Sun Dec 11, 2005 5:51 pm Post subject: |
I understood what is bad!!!!!
Every patches are good!
The bad thing is that i put mystuff.xml only with a, b, c disk and i didnt add game and application folders and when i want to download java program, phone looks in mystuff for game and application folders if he didnt find it, the error appear
P.S. for every one! dont forget to put game and application folders in mystuff!!!  _________________ N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb |
