:: View topic - CX65 MPM ve win XP x64bit
chcimatikar
PostPosted: Tue Jan 17, 2006 10:05 pm    Post subject: CX65 MPM ve win XP x64bit Reply with quote
Nevite pres co mam nahrat do cx65 napr. javu? nejde me v ve win XP 64bit spustit MPM .... pise to nejak 'the patch(nejaka adresa ciselna) does no exist or is not directory.... jestli existuje jinej program pres kterej si tam muzu nakopat data tak hodte pls link.. moc dik
EidzEm
VIP
VIP
5862.50 SMM
PostPosted: Tue Jan 17, 2006 10:07 pm    Post subject: Reply with quote
Ja upresne pouzivam SiMoCo a zatial som s nim nemal ziaden preblem.
Najskor si pozri http://www.siemensmania.cz/simoco.php
a stiahnes ho na http://www.siemensmania.cz/download.php?file=/software/SiMoCoSetup226.zip
kwash
303.22 SMM
PostPosted: Tue Jan 17, 2006 10:55 pm    Post subject: Re: CX65 MPM ve win XP x64bit Reply with quote
hm, neviem ci nestrelim ale nechcelo bi to 64bitove ovladace v MPMku predsa len adresuje neake porty a tak...
CX70fw56+switxing cable DCA-510<->DCA-500,S75 black,N95 8gb
m@rko
PostPosted: Tue Jan 17, 2006 11:05 pm    Post subject: CX65 MPM ve win XP x64bit Reply with quote
Pre 64bitove procaky sa uz pouzivaju dll aj exe napisane pre 64bit. Ak je napisana pre 32bit tak by sa nemala dat spustit. Ale windows a myslim ze aj samotny procak sa vie vysporiadat aj z 32 bitmi. Otazkou je ci dll ktora je napisana pre 32bit vie potom 100% pracovat z vsetkymi I/O velicinami. Myslim ze dll ktora obsluhuje kabel (usb/com) a aj dll pre samotny program sa nevedia zo 64 bitmi vysporiadat.
Vyskusaj TotalCommander a plugin pre x65 alebo skus zohnat programy a drivery na 64bit. Tot vse.
64bit nieje to iste ako 32bit !!!!!!!
..:: m@rko ::..
- - C55 full tunning > M65@CX70 fw56 Linux tuning, volny pad z 2. poschodia, doteraz funguje a neodvrava. Nepoznam lepsi telefon - -
