:: View topic - Jak nastavit u S75 GPRS, MMS, E-MAIL a CSD u Vodafone?
Goto page 1, 2  Next
Freestyler
PostPosted: Sun Feb 05, 2006 7:49 pm    Post subject: Jak nastavit u S75 GPRS, MMS, E-MAIL a CSD u Vodafone? Reply with quote
Nevite nekdo jak nastavit u S75 GPRS, MMS, E-MAIL ,CSD u Vodafone? Protoze ja se v tom fakt nevyznam mohl byste mi s tim nekdo pomoct ale potreboval bych podrobnejsi navod jak to nastavit. Dik
Siemens CX65 FW 50 > Siemens S65 FW 53 > Siemens S75 FW35
SMIKEE
(člen klubu SM)<br>táta fóra
Location: Prague,mother of every cities! Telefon:Ukradnut:-(
57422.50 SMM
PostPosted: Sun Feb 05, 2006 7:52 pm    Post subject: Reply with quote
Mno,zavolej na Vodafone a on by ti měl poslat konfigurační datovou sms wink
Bylo:S65-FW50+RS-MMC-32MB+DCA-510---hafo patchů+VodafoneCZ 8) ----11.5.2006-ukradnut!!
Mar3x
PostPosted: Sun Feb 05, 2006 9:46 pm    Post subject: Reply with quote
tos mu teda pomoh ;-)
zkus to tu plz nekde jeste jednou shrnout
C25->MT50 FW18->S65 FW58-> >>>SXG75 FW22 + 1GB SanDisc<<< (a dalsi co mam v rodine M35i, ME45@S45i, CF62, CX65@CX70)
Debian GNU/Linux 3.1r1 + dalsi repozitare (KDE3.5.0; Linux 2.6.16-rc2-mm1)
beardie
7865.50 SMM
PostPosted: Sun Feb 05, 2006 11:02 pm    Post subject: Reply with quote
freestyler : Arrow http://www.siemensmania.cz/forum/viewtopic.php?t=5436&sid=3c03eef6af3bdf7dbd0fd1208e2ab13c
mar3x: smikee je tu taky nas spammer, ale snazi sa wink
biggeorge
PostPosted: Mon Feb 06, 2006 10:34 am    Post subject: Reply with quote
jj, podle toho jsem nastavoval T-Mobile a vse funguje jak ma...
Nokia 3310 -> Siemens MT50 -> M55 -> S75 FW47+FFS+MAP
Mar3x
PostPosted: Mon Feb 06, 2006 3:23 pm    Post subject: Reply with quote
beardie ...snaha se ceni Smile mozna se casem vypracuje
btw. ja jsem ted taky zacal nejak vic odpovidat do fora...snazim se prestat byt pasivni konzument Razz
SMIKEE
57422.50 SMM
PostPosted: Mon Feb 06, 2006 3:39 pm    Post subject: Reply with quote
Hele hoši to nebyl spam Evil or Very Mad .Já jsem si taky zavolal na operátora a on mi to poslal.JE to ta nejjednodušší věc Hand Evil or Very Mad Embarassed
pkotab
PostPosted: Mon Feb 06, 2006 3:45 pm    Post subject: S75 a MMS, WAP u ETCZ Reply with quote
Já ten samej problém řešim u eurotelu. Oni nemaj S75 v nabídce a tak mi nepomohli. Jde o to, že S75 má jinou strukturu menu než řady 65 a i některý telefony řady 75 a tak i přes podrobný údaje nevím co kde nastavit. Odkazy jak tu třeba beardie vkládal, jsou běžnýmu uživateli na nic. Ani rada od smikee zavolat operátorovi nemusí vyjít.
Za rady jak na to budu vděčný.
_________________________________________________
S25, S35, S55, S65-F1, S75 doma C55, SL55, CF62, CL75
busch
27.84 SMM
PostPosted: Mon Feb 06, 2006 4:07 pm    Post subject: Reply with quote
Pokud mate spravny udaje, tak by nemel byt problem tohle zprovoznit:o) To si dovolim tvrdit,ikdyz sem v ruce S75 neměl Smile
Pro oskara:
U MMS je IMHO duležitý:
APN mms (popř. uživatel a heslo mms)
Gateway IP: 010.011.010.111
Gateway port: 9201
adresa serveru http://mms
U WAPu přes GPRS:
APN wap (přip owap u oskarty)
Uživatel: wap
Heslo: wap
IP adresa: 010.011.010.011
Protokol HTTP (nebo wap) pak jiny port
port: 80 (9201 u protokou wap)
u profilu pro java aplikace:
APN internet (popř ointernet pro oskarty)
proxy deaktivovaná...
Nokia 6234, Ericsson T65
biggeorge
PostPosted: Mon Feb 06, 2006 7:11 pm    Post subject: Reply with quote
jak jiz bylo receno vyse, nastaveni uvedene zde http://www.siemensmania.cz/forum/viewtopic.php?t=5436&sid=3c03eef6af3bdf7dbd0fd1208e2ab13c funguje (sam jsem podle toho nastavil svou s75) a jsou tam vsichni operatori... jinak jde udelat napr to, ze si poslete konfiguracni sms napr pro m75 a date je do jednoho profilu...
pkotab
PostPosted: Tue Feb 07, 2006 8:18 am    Post subject: nastavení profilu Reply with quote
-> biggeorge
A to je právě to, kde asi dělám chybu, v menu online nastavení mě mate záložka aplikace Mad . Má tedy být jak wap tak mms pod jedním "contextem"?
Pohanské časy: Motorola > Sagem > Nokia
Nový věk: S25 > S35i > S45i > SL55 > S65-F1(307/999) > S75; v rodině C55, SL65, CF62, CL75
PostPosted: Tue Feb 07, 2006 9:09 am    Post subject: Reply with quote
A nebo použít konfigurátor nastavení přímo ze stránek výrobce http://siemensmania.cz/content.php?id=591
pkotab
PostPosted: Tue Feb 07, 2006 9:15 am    Post subject: konfigurátor Reply with quote
-> krokodýl
Pro S75 tam nastavení zatím nejsou. Zkoušel jsem to nastavit jako S65, pak M75, ale asi dělám něco špatně, nefungovaly mi ani mms ani wap (byly pod dvěma "contexty").
berda
PostPosted: Tue Feb 07, 2006 9:17 am    Post subject: Reply with quote
http://www.siemensmania.cz/forum/viewtopic.php?p=225413#225413 (můj pokus o návod)
Berda
mc920->t10->c35i->s35->me45/me45i->mt50->a55/c55->c65/csl65->lg c2200->s75
pkotab
PostPosted: Tue Feb 07, 2006 9:26 am    Post subject: nastavení Reply with quote
-> berda
To vypadá nadějně, díky moc, já to zatím všechno dával do více "contextů". Vyzkouším a dám vědět zda to u ETCZ funguje.
Goto page 1, 2  Next
Page 1 of 2
