gfmnb začátečník
Posted: Fri Feb 17, 2006 4:24 pm Post subject: |
Gwin wrote: | Já to reším kombinací prvního a některého z posledních patchů. |
Mohl bys tady tu tvoji kombinaci postnout? Vyzkoušel už jsem všechno možné a nic:-(.
Dík |
Gwin čestný člen
0.84 SMM
Posted: Fri Feb 17, 2006 4:50 pm Post subject: |
Code: | ;Patch No. 51
; SX1 overclock patch v1.0
; v1.0
; changes bootcore of Z1 firmware image
; by Vovan888 (vovan@oslik.ru) 08.01.2006
; oslik.ru
; dedicated to Z-team and overclockers.ru
; !!! DANGER !!! CPU can overheat and overburn !
;168 Mghz
replace:303A00000010FEFF00102000FFFFFEFFEFFFFFD1:B03D
; multipliers table: (cpu_freq = 12 * mult / 2)
; mult
;"11 xxxxx 01 10000" when xxxxx is multiplier in binnary
;if you have 01010 (=10) it will be 11 01010 0110000 bin= 3530 hex
;3530hex must be 3035 in patch. you must change last two and firt two numbers
;xxyy will be yyxx in patch
;01101 = 13 = 78M = 11011010110000=36B0
;10100 = 20 = 120M = 11101000110000=3A30
;10101 = 21 = 126M = 11101010110000=3AB0
;10110 = 22 = 132M = 11101100110000=3B30
;10111 = 23 = 138M = 11101110110000=3BB0
;11000 = 24 = 144M = 11110000110000=3C30
;11001 = 25 = 150M = 11110010110000=3CB0
;11010 = 26 = 156M = 11110100110000=3D30
;11011 = 27 = 162M = 11110110110000=3DB0
;11100 = 28 = 168M = 11111000110000=3E30
;11101 = 29 = 174M = 11111010110000=3EB0
;11110 = 30 = 180M = 11111100110000=3F30 !!NOT TESTED!!
; *** SX1Speed 2.2 ***
; Author: vovan888 , vovan@oslik.ru
; Author: fca00000 , fca00000-at-yahoo-dot-es
; Date: 2006.02.07
; Firmware: Siemens-SX1 Possibly all versions. Tested on Iberia15.2 and O2-14
; Omap: Core-Img (Z1)
; File: c:\system\apps\SX1Speed\*
; This program is the counterpart for patch "SX1 overclock patch v2.1" made by vovan888
; The patch allows to dinamically set the SX1Speed for SX1.
; The program provides a graphical interface to it.
; Info from vovan888 :
; allows changing of freq on-the-fly
; changes ekern.exe
; by Vovan888 (vovan@oslik.ru) 27.01.2006
; oslik.ru
; If you have version 15-russian then
; read and apply the included patch overclock_omap_v2.sxp made by vovan888
; If not, apply this: (also made by vovan888)
;User::SetDebugMask(unsigned long)
;5016653C
replace:930000EF9700C0EF9800C0EF990000EF9A0000EF:EB0000EF
;SWI EB handler
;5001B8C4
replace:0500E0E30EF0A0E10400E0E30EF0A0E1:0500E0E30EF0A0E11F402DE940108FE2000181E0B010D0E1020080E2B000D0E16C209FE56C309FE5100080E3B010C3E1B000C2E1024BA0E3014044E2000054E3FCFFFF1AB040D2E1010014E3FCFFFF0A1F80BDE80500103205001033050010340A0110350A0190350A0110360A01B03C0A01303D0A01B03D0F0110370F01B03E0F0190370F01B03F0F0110380F0290380F02103900EF005800EE0058
;Clock Arg Group
; 48 0 0
; 72 1 0
; 96 2 0
; 120 3 1
; 132 4 1
; 144 5 1
; 150 6 1
; 156 7 1
; 162 8 1
; 168 9 2
; 174 A 2
; 180 B 2
; 186 C 2
; 192 D 2
; 204 E 3
; 216 F 3
; Recommendations by chencho:
; If your mobile crashes after trying some speed, it is probably too fast. Trying again will not make it better.
; Trying too many times can make your phone stop. Then try this: remove the battery and let the phone
; rest for 1 hour. Put the battery again. If still doesn't switches-on, start recharging the battery
; and load for 12 hours. Then try to switch-on again. If doesn't work, take it to the Repair center. Sorry.
; Info from FCA00000 :
; First of all, thanks to vovan888 for his great patch. He is the master!
; And to chencho, for making the icon. I still have problems with AIFTool.
; Dedicado a www.comunidad-siemens.com
; Use keys joystick-up/down to increase/decrease the SX1Speed
; Changes apply inmediatly, but are lost when you restart the phone.
; You can close the program: the speed it stored.
; Starting the program again sets the speed to the default 120 Mhz, unless you have
; applied overclock_omap_v2.sxp ; in this case it will show the right speed.
; Source code is provided. Change if you want, but please inform me.
; There is a problem: the icon shows 2 times in the task list. No idea why.
_________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
gfmnb začátečník
Posted: Fri Feb 17, 2006 5:11 pm Post subject: |
A zobrazuje ti spmark správně takt, nebo tam máš pořád 120Mhz?
Verze 2.2 to snad ani neměla umět. |
Gwin čestný člen
0.84 SMM
Posted: Fri Feb 17, 2006 10:07 pm Post subject: |
gfmnb wrote: | A zobrazuje ti spmark správně takt, nebo tam máš pořád 120Mhz?
Verze 2.2 to snad ani neměla umět. | Pořád 120. Verze 2.3 mě nejela, verzi 2.4 sem zatím nezkoušel. _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
darth začátečník
Posted: Sun Feb 19, 2006 1:28 am Post subject: |
2.4 z oslika mi bezi nadherne; jen nevite jestli jde ten program nastavit tak, aby zacinal na defaultni hodnote dane patchem predchazejicim na overclock ? |
darnel badatel
Posted: Mon Feb 20, 2006 2:46 pm Post subject: |
Asi tim Gwinovym kombinovanym patchem, ne? Jestli jsem to dobre pochopil.
Verze 2.2 a 2.4 mi funguji, ale spravnou nastavenou frekvenci neukazuje zadny program. SX1Speed po spusteni taky ukazuje vzdycky 120 i kdyz je nastaveno vic (testoval jsem SPMarkem) |
PekabOo začátečník
Posted: Mon Feb 20, 2006 5:22 pm Post subject: |
je tam dulezitej tenhle radek..pak to de...
Code: | ; SX1 overclock patch v2.4
; Allows changing of freq on-the-fly with special program
; Now programs display real CPU clock :
replace:8CB5015000000000000000000000000094B5015098B50150:C4B80150
replace:0500E0E30EF0A0E10400E0E30EF0A0E1:0500E0E30EF0A0E11E402DE92
02CA0E1FF04C0E3020052E302F19F97160000EAE4B8015034B9015050108FE20
02181E0B010D2E1B200D2E11623A0E30230A0E1EF2C82E3EE3C83E3100080E3
3FCFFFF0A0000A0E3000000EA29ABFFEB1E80BDE805001022050010230500102
3E0F0190370F01B03F0F0110380F0290380F02103910402DE90240A0E10104A0E
3334805EB000084E50000A0E31040BDE81EFF2FE1
replace:0000000088170650F817065000000000:7CB90150
gfmnb začátečník
Posted: Mon Feb 20, 2006 6:47 pm Post subject: |
PekabOo wrote: | je tam dulezitej tenhle radek..pak to de... |
To cos tu dal je overclock_omap_v2_4 ořezaný o dodatečné informace, které pro patch nejsou relevantní, takže sis to mohl klidně odpustit. Nemyslím to ve zlém jenom je to prostě zbytečné.
Ostatně v přibližně takové podobě jsem ho už dříve aplikoval a stejně nefungoval (přetaktování ano ale zobrazování v žádném případě).
I tak ale díky za snahu... |
Gwin čestný člen
0.84 SMM
Posted: Mon Feb 20, 2006 7:55 pm Post subject: |
gfmnb wrote: | PekabOo wrote: | je tam dulezitej tenhle radek..pak to de... |
I tak ale díky za snahu... | Chyba musela být u tebe, poněvadž patch jsou jenom tyto 3 řádky. Navíc fungují. _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
gfmnb začátečník
Posted: Mon Feb 20, 2006 9:12 pm Post subject: |
Gwin wrote: | gfmnb wrote: | PekabOo wrote: | je tam dulezitej tenhle radek..pak to de... |
I tak ale díky za snahu... | Chyba musela být u tebe, poněvadž patch jsou jenom tyto 3 řádky. Navíc fungují. |
Je mi jasné že tyto řádky jsou patch ale to, že je tu PekabOo postnul je naprosto zbytečné a taky to pro někoho může být matoucí. PekabOo vzal jenom overclocking_omap_v2_4 a odstranil informace od autora -> to ale nikomu nepomůže.
Možná budu vypadat jako natvrdlý ale co si představuješ pod pojmem "fungují"? Ptám se proto, že hodně lidí má na funkčnost u tohoto patche dost odlišný názor.
Takže funguje přetaktování (v obou směrech)? Když znovu zapneš SX1Speed je nastavené na frekvenci, na kterou si předtím taktoval? Ukazuje ti spmark reálnou hodnotu taktu?
Pokud je tvá odpověď ano na všechny otázky pak souhlasím, že ti to funguje. U mně je bohužel "ano" odpovědí pouze na první otázku.
Chyba určitě někde je ale rozhodně ne v patchi nebo postupu který jsem použil. Ostatně jsem vyzkoušel všechno možné aplikoval jsem patch i jako jediný a výsledek veškerý žádný. Taky jsem zkusil 2.3 -> bezvýsledně.
Asi by bylo rozumné najít někoho, kdo podobný problém měl taky a nějak ho vyřešil, protože já si s tím fakt nevím rady. |
PekabOo začátečník
Posted: Mon Feb 20, 2006 10:12 pm Post subject: |
ja to psal proto protoze sem nevedel jestli si tohle aplikoval...ale proste po tomhle patchi ti to MUSI fungovat
mas zatrzeny spravny hodnoty core, Z1 atd??
me to pred timhle patchem taky nefungovalo..po jeho aplikaci uz jo.... |
Gwin čestný člen
0.84 SMM
Posted: Mon Feb 20, 2006 10:17 pm Post subject: |
2gfmnb: Na všechny otázky zní moje odpověď ano. Zkus nakombinovat poslední a první patch na oc. _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
gfmnb začátečník
Posted: Tue Feb 21, 2006 10:37 pm Post subject: |
PekabOo wrote: | ja to psal proto protoze sem nevedel jestli si tohle aplikoval...ale proste po tomhle patchi ti to MUSI fungovat
Zatržené jsem měl všechno, takže v tom to nebude. Mi dělá verze 2.3 totéž co 2.4.
Gwin wrote: | 2gfmnb: Na všechny otázky zní moje odpověď ano. Zkus nakombinovat poslední a první patch na oc. |
Zkoušel jsem.
No nic díky za snahu. Zkusím to ještě jednou přefleshovat ale teď nějak nemám čas tak až si ho najdu tak dám vědět, jestli se mi to povedlo. Zatím se mějte... |
darnel badatel
Posted: Wed Feb 22, 2006 7:28 am Post subject: |
Zkousel jsem v.2.2 (ktera frekv.ukazovat neumi) a pretaktovani fungovalo = narust vykonu v SPMarku
Ve v.2.4 se tez projevil narust vykonu, ale frekvence se neukazuje nikde (SXSpeed, SPMark, TaskSpy...)
Aplikoval jsem patch z oslika, predpokladam, ze tu neruskou verzi a zatrzeno jsem mel Z1,Z2.
Takze vse jak popisuje gfmnb. |
Sirus čestný člen
7910.50 SMM
Posted: Wed Feb 22, 2006 7:56 am Post subject: |
Ani mne neukazuje aktualnu frekvenciu, ale pretaktovany je. Pouzil som patch 2.4 a staru verziu SX1Speedu. _________________ C35i>ME45>>S45i>ST55>S55+BT>SX1
