:: View topic - Je mozne dostat do cx75 ikonky menu iba cez bluetooth?
Goto page Previous  1, 2
jumper89
PostPosted: Sun Feb 19, 2006 1:30 am    Post subject: Reply with quote
mne to absolutne nejde mam zicany bt, normalne fici ale neviem na akom come je alebo co
°°° C45>CX65>S65 (FW53) Very Happy °°°
daniel78
PostPosted: Sun Feb 19, 2006 7:41 pm    Post subject: Reply with quote
Ten isty problem.Tiez mam Bluetooth a nejde mi to(skor neviem ako s tym robit) a este nikto mi neporadil.
beardie
7865.50 SMM
PostPosted: Sun Feb 19, 2006 7:54 pm    Post subject: Reply with quote
BT musis mat spravne naemulovany na comport
kex
PostPosted: Mon Feb 20, 2006 2:00 pm    Post subject: Reply with quote
mne to tiez nejde... a to sa snazim vsetkymi vnavigatormi a odtoolmi a neviem cim... Crying or Very sad a com sa zapina automaticky... toto ide bez problemov, aj telefon najde aj browsujem po priecinkoch, ale akonahle dam otvorit skryte disky, tak vyhodi ten obex error, potom sa uz v programe neda pohybovat, alebo mi pipne fon a vypne... a dalej s tym nepohnem... tak tot vsio... ak niekto viete kde robim chybu, tak piste Wink
kex
PostPosted: Mon Feb 20, 2006 2:04 pm    Post subject: Reply with quote
takze sa hlasim zas, podarilo sa mi to cez vnavigator, ale nie cez bt, ale cez irda... uz to pekne ide... Wink
gorgeous007
PostPosted: Mon Feb 20, 2006 5:26 pm    Post subject: Reply with quote
Zlata volba Arrow kupit si najlepsi kabel DCA-510 Exclamation Exclamation Exclamation
Page 2 of 2
