:: View topic - x65, x75 unlocking
x65, x75 unlocking
Goto page 1, 2  Next
Reply to topic     Forum Index -> Non Czech Languages Here
PostPosted: Sun Feb 05, 2006 11:44 am    Post subject: x65, x75 unlocking Reply with quote
Papua Utils075
px75v1
For newer phones (C72, C75, ME75, S75 a SL75) use PapuaUtils077.
1. Connect your phone
2. Put px71v1 to your phone using MPM, SiMoCo or something similar (Java/Jam/Applications/px75v1).
3. Run px75v1 (Menu -> Surf & fun -> Applications -> px65v4).
4. "Local connection?" - choose "For session" and OK.
5. "Allow Java to access data cable?" - Yes.
6. Wait for displaying codes.
7. When the codes are shown, don't close the application and run Papua.
8. Choose correct COM in Settings.
9. Go to the Codes.
10. Push Px75v1. Papua should read IMEI, ESN and HASH.
11. Click Calculate SKEY and BootKEY - Papua will calculate SKEY and BOOTKEY.
12. In the phone close the application and go to the main screen. Don't turn off the phone!
13. Enter correct HWID (if you don't know what is your phone HWID, you can read it from the list near the HWID field).
14. Click Enter SKEY in phone. Papua will write SKEY to the phone.
15. After SKEY writting, click Freia.log.
16. DON'T SAVE *.log file! You must choose CANCEL.
17. Confirm next question (choose Yes).
18. Turn off and turn on your mobile. Simlock or phone code shouldn't exist.
Wyshniukas
PostPosted: Tue Feb 28, 2006 7:55 pm    Post subject: Reply with quote
Is this solution really works? Wil it with ME75/C75?
At the moment I don't have any phone to try this solution Smile
PostPosted: Tue Feb 28, 2006 8:01 pm    Post subject: Reply with quote
Sure that works. Smile
Siemensxp
Phone: 123456
8.28 SMM
PostPosted: Sun Mar 26, 2006 11:05 am    Post subject: Using this with A65 Reply with quote
Hi,
I tried using px65v4 and px65v5 on my A65 but when I run the application, it just says Please Wait... and nothing more happens.
I let it run for a few hours, still nothing happens.
Can you please tell me what I do wrong?
PostPosted: Sun Mar 26, 2006 11:08 am    Post subject: Reply with quote
This is only for SGOLD phones. A65 is a EGOLD.
For unlock A65 use joker without java application.
Siemensxp
Phone: 123456
8.28 SMM
PostPosted: Sun Mar 26, 2006 4:06 pm    Post subject: Reply with quote
Thank you Lasky! Is it necessary to make a test-point if I use Joker? I've searched, but I can't find a good manual/FAQ for the use of Joker and unlocking an A65 Sad
PostPosted: Sun Mar 26, 2006 7:56 pm    Post subject: Reply with quote
Follow the numbers.
In the last step (number 8 ) you need to click on the red button.
TP is necessary.
lunasicc
PostPosted: Fri Aug 18, 2006 5:39 am    Post subject: Reply with quote
I have a DCA-540 cable; will I be able to use it with this program??
Also, I transfered the px75v5 to my siemens S66(S65) and got all neccessary codes. But when I start up Papua Utilis 0.7.9c and click on px75v5 I get this error:
Awaiting answer from Chaos midlet...
No answer from midlet!
1) Neglected to run midlet px65v5 in phone...
2) At request "Connect Accessory" press button "Px65v5" and connect cable to phone.
3) Wait for the midlet to finish and again press button "Px65v5"...
*Midlet can be found at http://chaos.allsiemens.com/download/px65v5.rar
I followed all your instructions and nothing? What am I doing wrong?
adigehalil
PostPosted: Sat Sep 30, 2006 12:39 pm    Post subject: Reply with quote
you can't do that with a dca-540.. you need a serial cable.. dca-540 is a usb cable..
View user's profile Send private message Yahoo Messenger MSN Messenger
AK74
Phone: me45i & m_cx70sw56_elfpac2.3russianretail
110.64 SMM
PostPosted: Wed May 25, 2011 8:42 am    Post subject: Reply with quote
carefully read:
http://forum.allsiemens.com/viewtopic.php?p=890788#890788
http://translate.google.ru/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2Fforum.allsiemens.com%2Fviewtopic.php%3Fp%3D890788%23890788
my home: http://forum.allsiemens.com
AK74
110.64 SMM
PostPosted: Wed May 25, 2011 8:51 am    Post subject: Reply with quote
you are very mistaken Very Happy Mr. Green
vdragoslav
Phone: C75, E71
170.64 SMM
PostPosted: Thu Mar 22, 2012 8:52 am    Post subject: Reply with quote
What's the procedure for getting rid of the last attempt of entering the phonecode that I don't know, please!?.. :-?
(I used to unlock a C75 using the method above. Of course it worked just fine! :> )
View user's profile Send private message Send e-mail Yahoo Messenger
AK74
110.64 SMM
PostPosted: Thu Mar 22, 2012 11:58 am    Post subject: Reply with quote
no doubt.
everything worked until the phones were still alive.
much time has passed.
siemens
ps: 71y edit box eeprom 53bit
remove restrictions on three attempts to enter the phone code
vdragoslav
Phone: C75, E71
170.64 SMM
PostPosted: Tue Apr 17, 2012 1:02 pm    Post subject: S68... Reply with quote
Sorry, but I didn't get the info!.. :-?
I have a DCA-140 that only helps me charging the battery... :-<
EF81 (when it worked) did managge to connect to PC via the same cable.., but this S68 I'm asking you to help me to fix is unable to be connected.
May be the nano-Lumberg's connector pins different compared to EF81?..?
Could it be that the data pins at phone's connector are missing or oxidized?
144510.50 SMM
PostPosted: Tue Apr 17, 2012 2:16 pm    Post subject: Reply with quote
EF81 and S68 are different phones, EF81 is BREW and S68 is new sgold platform. DCA-540 works as a service cable (for fw flashing, applying patches etc.) only for EF81. To be able to unlock phonecode on S68 you will probably need a DCA-100 (COM) or DCA-110 (USB) cable Think .
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
