madmax kolemjdoucí
Založen: 25. 08. 2005 Příspěvky: 6
Zaslal: po prosinec 05, 2005 12:32 pm Předmět: Datum dole na hlavním displeji - verze 8 for cx70fw56 |
sorry, cannot read czech
the above patch in the patch section for cx70 in linked to the master patch,
maybe someone can fix the link ?
greetz  |
lacibogi čestný člen
Zaslal: po prosinec 05, 2005 5:21 pm Předmět: |
Fixed... _________________ C(ME)75
Lasky |
madmax kolemjdoucí
Zaslal: pá březen 17, 2006 8:40 pm Předmět: |
sorry, me again...
patch 458 Master Patch v3 RC2 #114 is linked with fw50 version instead of fw56 version
here are the entrys for fw56 if unknown :
kód: | 083C238: 000050E30B00001A60408FE2 04E08FE204F01FE5,0xA0FC12C5 ;entry for java
08D1868: 041C56F7E6EC082C0CD2 004B9847,0xA0FC1081,C046 ;entry for SetProfile
0943A78: DBF98EA0 510CFCA0
0943A84: 2908000019080000 BD0A0000BD0A0000
0943A90: B9 BD
0B8AC18: 0C4C00921823201C 004B9847,0xA0FC1151 ;entry for Loader
0CB6C44: A080022020706070 004DA847,0xA0FC1189 ;entry for Initializer
0CB75A8: 192189014018C068 00490847,0xA0FC10F1 ;entry for PIT
1559A0C: 0D1CFFF7A5FE6E1C 004FB847,0xA0FC10C1 ;entry for GetLP |
Zaslal: pá březen 17, 2006 8:47 pm Předmět: |
Where´s the problem? I don´t understand you.  _________________ C(ME)75
Lasky |
madmax kolemjdoucí
Zaslal: pá březen 17, 2006 10:02 pm Předmět: |
Patch 458 should be the master patch v3 rc2 for cx70fw56, shouldn't it?
The download file is also named fw56.
When i download, it comes out to be for cx70fw50.
So i told you the right entrys to fix the download or patch. |
Zaslal: so březen 18, 2006 11:03 am Předmět: |
Aha, it will be fixed. _________________ C(ME)75
Lasky |
