:: View topic - MC60 a jej smrt (???)
chronos88sk
PostPosted: Sun Apr 30, 2006 5:47 pm    Post subject: MC60 a jej smrt (???) Reply with quote
zdravim.
bratranec mal mc60 blokovanu na T-com. Hovorim si, no problem, mam DCA-510 a podla navodu spravime.
Pokus o odblokovanie cez Joker 3.4.1. cz skoncil vzdy takto:
Start...
Loading BootsModel(MC60)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com9 115200 BAUD: Ok.
SIEMENS MC60 lg95 Sw07
Soft FlashID: 0001/2212
FlashID: 0001/227E-2212-2200
Flash Size: 16Mb, WriteBuffer: 32 bytes
Region(1): Blocks 256, Size 64Kb
Start EEPROM segments at addres 0xFC0000
FSN: 7B0AE3B1 -> PhoneID: B1E30A7B
OTP IMEI: 351995001817176
HASH: 698AFC3B4439DC1FDE2FE1AF7B647D43
Use OTP IMEI: 351995001817176
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
Read BCORE addr: 0x800000 size: 0x010000...
Error Read Flash block 0x800000 size 0x004000!
Tak som si pomyslel, ze to napravim tym, ked nahram poslednu oficialnu verziu FW zo SM pre tento telefon.
FW zahlasil ze "teraz uz nesmiete nic robit" a po 10 sekundach updatovania sa sekol s hlaskou "telefon nenajdeny".
MC60 od tohto momentu sa uz nezapne.
Skusil som teda nahrat FF zo SM:
Start...
Soft FlashID: 0000/0000
Warning: The software of the telephone does not correspond to FlashID!
Read EEP0067 block (ver00), size 20 bytes - Ok.
Read EEP0076 block (ver00), size 10 bytes - Ok.
Read EEP5005 data does not answer!
ReadEEP5007 does not answer!
ReadEEP5008 does not answer!
ReadEEP5009 does not answer!
ReadEEP5012 does not answer!
ReadEEP5077 does not answer!
ReadEEP5093 does not answer!
ReadEEP5121 does not answer!
ReadEEP5122 does not answer!
ReadEEP5123 does not answer!
EEPROM blocks is written in ".\Backup\MC60lg95Sw07_Backup060429002141.eep" file.
USE SKEY: 12345678
WriteFlash block at 0x000000 does not answer!
a hotovo. Skusil som este raz, ale dostal som sa k momentu, kedy Joker caka na stlacenie cerveneho start tlacitka na telefone, ale nic sa neudeje ked ho stlacim.
RXD dioda na kabli blikne kratko a rychle 8x a TXD raz.
Teraz je bratranec bez telefonu celkovo, vtedy mu siel aspon na T-com...
viete mi niekto poradit ako ho nastartovat pls?
Skusal som pozerat na fora tykajuce sa mc60, ale nic podobne som nenasiel.
vdaka vopred za kazdu radu!
pegaz
PostPosted: Mon May 01, 2006 3:48 pm    Post subject: Reply with quote
zkus odstranit testpoint
Dan Kaser
22.60 SMM
PostPosted: Mon May 01, 2006 6:33 pm    Post subject: Reply with quote
asi bych to tak taky videl...pak nahraj fullflash a pokud nemas vlastni odblokni pres freria
Sie S6,Er R310s,Er R310s - jina barva,n 5110,Sie ME45,Sie MC60,Sie SX1
bubo33
PostPosted: Mon May 01, 2006 9:26 pm    Post subject: Reply with quote
no mne sa už pár krát podarilo takýto fon zachrániť, keď som to červené tlačítko rýchlo po sebe stláčal.... Niekedy to zaberie :-))
chronos88sk
PostPosted: Tue May 02, 2006 2:45 pm    Post subject: :) Reply with quote
no to s tym rychlym stlacanim mi cez vikend nevyslo Smile
skusim ten testpoint.... vyzera to byt ako jedina schodna cesta.
pegaz
PostPosted: Fri May 05, 2006 8:14 pm    Post subject: Reply with quote
Měl jsem ten samý problém a udělal jsem to přesně podle návodu od Krokodýla (za což mu upřímně děkuji) Jokerem.Dal do návodu FF udělané v Jokeru,zkoušel jsem nejdřív 10ku,na tu to nešlo ale na 4ku zapnul napoprvé.Bezvadný!
chronos88sk
PostPosted: Tue May 09, 2006 8:43 am    Post subject: Reply with quote
no to som skusal aj ja, ale neprejdem cez bod "stlacit cervene tlactiko"...
teraz sa snazim zohnat/kupit srobovak na rozobratie tej MC60 Smile
chronos88sk
PostPosted: Mon May 15, 2006 7:40 am    Post subject: Reply with quote
no, tak som skusil reznut ten testpoint, ale bez zmeny. Rez som skusal spravit niekolkokrat.
Stale mi po stlaceni "cerveneho tlacitka" zablikaju LEDky na kabli a nic sa neudeje.
nadej ozivit ten phone uz asi zomrela.
alebo mate este niekto nejaky napad?
vdaka vopred.
fadeedi
PostPosted: Fri May 19, 2006 10:27 am    Post subject: Reply with quote
a rezol si ozaj TP? uz som videl paru ludi ktory rezali TP ce 4!!!! cesty. skusil by som to spojit s Vklay nahrat tam nejaku cistu FF a zmenit IMEI. mozno sa podari
JOKER je super ale niektore veci sa mi v nom nepodarilo urobit.
siemens MC60 fw13 + vlastné patche
chronos88sk
PostPosted: Fri May 19, 2006 10:32 am    Post subject: Reply with quote
skusal som to cez JOkera, M55Tool,Freiu...spravanie bolo rovnake. Takze to je telefonom, nie softverom.
Snazil som sa prerezat len tam, kde je ukazane. Ci sa mi podarilo aj nieco viec neviem, nemal som lupu pri sebe Smile
no a nahrat tam nenahram nic, lebo soft caka na stlacenie cerveneho tlacitka a cez to neprejdem.
fadeedi
PostPosted: Fri May 19, 2006 10:41 am    Post subject: Reply with quote
no rezat ten TP takto naslepo bolo celkom riskantne takze je moznost ze si si ten mobil zabil ozaj.
mal som podobny problem ako ty a po prerezani TP som to uplne krasne spojil s Vklay. osobne ho pouzivam najradsej
chronos88sk
PostPosted: Fri May 19, 2006 10:52 am    Post subject: Reply with quote
nemyslim si ze som ho zabil tymto, lebo sa sprava rovnako ako pred rezanim TP.
na slepo som to nerobil, len tie kontakty su dost male na bezne rezacie nastroje doma Smile
