kicco_79 kolemjdoucí
Založen: 23. 10. 2005 Příspěvky: 27
Zaslal: ne duben 30, 2006 1:58 pm Předmět: M75 Internal speaker spare-part |
Hello,
I need to buy the internal speaker for my Siemens M75. I only find an item on mobiltec34.de that's apparently the same but it's for Siemens M55/S55. Somenone can give me where I can buy an item online or if the speaker for M55/S55 is compatible on my M75??
Here another site that have the same speaker.. look at here:
http://www.handyersatzteilshop.de/prod/a-311742-Siemens_M55_S55_C65_CX65_CX70_M65_Lautsprecher_Hoerkapsel.html
Does it work on M75??!
Best Regards,
Federico |
Zaslal: so květen 06, 2006 8:01 pm Předmět: |
Yes it works.. I've buyed 1 from mobiltec24.de if someone need a spare parts I confirm that is identical spare parts!
I've another little question.. there's a procedure for charging a NEW lithium battery? So i hear that the first 5-10 initial charge must be of 12 hours.. it's right? |
Vladimir Curcic badatel
 Založen: 30. 04. 2005 Příspěvky: 127 Bydliště: Serbia
Zaslal: po květen 08, 2006 2:38 am Předmět: |
kicco_79 napsal: |
WRONG!
LithiumIon, LithiumPolymer... batteries do NOT need to be "formed"!
"Forming" means first 3 chargings for 12 hours each, and to let battery exhaust completely - this technique was used with older types of batteries.
So you should charge new Lithium battery same as you charge the used one: for 2 - 2,5 hours.
You can check the detailed explanation here:
http://www.batteryuniversity.com/index.htm _________________ S65(FW58) | IFL-600 (External flash) | DCA500
MY CURRENT COLLECTION: ME45 | S45i | CX65-LtdEd | S65 | SL75 |
Zaslal: po květen 08, 2006 2:49 pm Předmět: |
Thank You a lot for tips!  |
Zaslal: po květen 08, 2006 5:03 pm Předmět: |
You 're welcome!
The best link for DOs and NOT TO DOs with batteries:
http://www.batteryuniversity.com/partone-21.htm _________________ S65(FW58) | IFL-600 (External flash) | DCA500
