:: View topic - 12-ti ikonkové menu poradit
Palica
PostPosted: Thu May 11, 2006 4:57 pm    Post subject: 12-ti ikonkové menu poradit Reply with quote
potrebujem poradit ako si dam do mobilu 12-ti ikonkové menu?? a ako to mam spustit aby to frčalo dakujem
EidzEm
VIP
VIP
5862.50 SMM
PostPosted: Thu May 11, 2006 5:01 pm    Post subject: Reply with quote
Tak isto ako v tomto clanku Arrow http://www.siemensmania.cz/content.php?id=202
Palica
PostPosted: Thu May 11, 2006 8:20 pm    Post subject: Reply with quote
Ale nemam kabel ib BT hmm
EidzEm
VIP
VIP
5862.50 SMM
PostPosted: Thu May 11, 2006 8:25 pm    Post subject: Reply with quote
Hm, tak to bude asi problematicke. Mozes sa pokusit otvorit skryte disky programom vnavigator, ktory najdes tu na stranach. Ale nezarucujem ti, ze sa ti to podari. Niekomu sa to podarilo, niekomu nie. Vyskusaj, uvidis.
Palica
PostPosted: Thu May 11, 2006 8:35 pm    Post subject: Reply with quote
OKi idem to skusit
DavidT
PostPosted: Thu May 11, 2006 8:49 pm    Post subject: Reply with quote
No všechno záleží na tom jestli ty disky otevřeš taky doporučuju program Vissie http://www.7soft.de/download/VisSie275c_setup.exe s tim by to taky mohlo jít jinak dále postupuj podle tohohle návodu: http://www.siemensmania.cz/content.php?id=614
S: C65>M75 >Sony Ericsson P1i
Firmware:13
Operátor: Vodafone
Kabel: DCA-510
Stav telefonu: OK
Karta: RS-MMC DV 1024 MB
