:: View topic - Obnova IMEI u Siemensů x65
Goto page Previous  1, 2, 3, 4, 5
Sh@dy
PostPosted: Sun Aug 28, 2005 2:01 pm    Post subject: Reply with quote
ivanko wrote:
to by nemal nech si kazdy precita forum Laughing
Zatial neviem o nikom, komu by to islo na CX65 podla navodu. Asi posledny krok musi byt cez V_Klay. Staci ak da do navodu na koniec poznamku...
mremen
PostPosted: Thu May 18, 2006 9:00 pm    Post subject: Reply with quote
Prosim vas poradtemi ako pokracovat. Vsetko som spravil presne podla navodu a pocas vsetkeho mi nespravilo jedinu chybu a nakoniec sa mi fon nezapne a len pipne. mam CX65 SW25. skusal som ten posleny krok spravit aj cez v-klan a stale nic.
Sh@dy
PostPosted: Fri May 19, 2006 11:02 am    Post subject: Reply with quote
Robil si posledny krok aj cez x65 flasher aj cez v_klay? Ak ano, tak to moze byt tym... Nahraj si FF a sprav to znovu, ale posledny krok rob len cez v_klay a generate2_patched nahraj na adresu odkial si vytiahol generate2.
steve83
PostPosted: Sat Oct 07, 2006 2:58 pm    Post subject: Nieco podobne? Reply with quote
Našiel som to náhodne na jednom fore
Preliminar:
- This works on phone versions <36
- After this you can´t upgrade with WSUP/Update, you´ll lose your new imei.
- After this you can´t unlock with any soft, you´ll lose your new imei.
- After this you can change ffs.
Correct way.
1 - Downgrade with any way to <36 version.
2 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode"
3 - Go to "Codes" and press "Auto Open All"
4 - Go to "Flash", mark "Pause" and "New BCore V22"
5 - Press "Do Job" and wait for finish.
6 - Turn Off mobile if not auto off.
7 - Go to "Settings" and press "Service Mode"
8 - Go to "Flash" and mark "Recalculate Keys in Flash" (two more options will be auto mark, all it´s ok)
If any advice of Wrong entry appear return to codes section and fill Skey and Bkey with any numbers.
9 - Press "Do Job" and wait for finish.
10 - Go to "Settings" and press "Service Mode"
11 - Go to "Codes" and press "Auto Open All"
12 - Press "Freia.log" and save file with any name, but remember this name later Smile
13 - Press "x65flasher.ini" and save file in x65flasher dir.
14 - Open x65flasher.exe and Press "Connect"
15 - Change "Leght" to 40000 and Press "Read Flash", save file
16 - Open SSWx65.exe and write your ESN, calculated by Papuas, Inverted in "Phone Id"
EX: In codes section of Papuas you get ESN: A1B2C3D4, then write in "Phone Id" of
SSWx65.exe in this way: D4C3B2A1.
17 - Write new imei in "New phone Imei" and Press "Dissable OTP", select file saved in step 15.
18 - Save file.
19 - Open x65flasher, select Leght to 40000 and Press "Write Flash", select file saved in step 18.
20 - Press OK to Skip Write BCore confirmation.
21 - Open mapper.exe, select log file saved in step 12, write imei of step 17, MUST TO BE THE SAME!
22 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode", Go to "Codes" and press "Enter Skey in Phone"
23 - In right window must see "Telephone in Factory Mode"
24 - Open Siemens EEPROM tool.exe, Press "Init", Press "Load" and select map file saved in step 21, Press "Select All" in left side, Press Right Arrow, Press "Select All" in right side, Press "Save Selected".
25 - Turn OFF your mobile, and turn ON again for confirmation of new Imei.
Page 5 of 5
