:: View topic - s65 a fw58 winswup
s65 a fw58 winswup
jumper89
PostPosted: Thu Jun 08, 2006 1:03 pm    Post subject: s65 a fw58 winswup Reply with quote
Nejde mi nahrat fw na telefon cez winswup vypise mi chybu Cant connect to Mobile with BootstrapLoader on Com 3 alebo Could not open Comport for BFC-Lib, maybe Comport is in use
Moj telefon:
S65
fw50
A 420
°°° C45>CX65>S65 (FW53) Very Happy °°°
siemensM55
postrach fóra
postrach fóra
15.00 SMM
PostPosted: Thu Jun 08, 2006 1:19 pm    Post subject: Reply with quote
mne to tiez nejde
http://www.siemensmania.cz/forum/viewtopic.php?t=23299
M55 vymeneny za S55
CX70---(FW54)---DCA510--- + PATCHE
new-FW56 - pokazil som ho
BenQ Siemens EL71 fw45- waaaaw Smile + microSD kingston 1GB + DCA-140 a DCA110
www.cool-mobil.wgz.cz
johnygrass
PostPosted: Thu Jun 08, 2006 3:36 pm    Post subject: Reply with quote
nemáš vybitou baterku?? Neutral
C65>>S65>>S75>>SXG75
jumper89
PostPosted: Thu Jun 08, 2006 4:36 pm    Post subject: Reply with quote
nie
132978.34 SMM
PostPosted: Thu Jun 08, 2006 4:38 pm    Post subject: Reply with quote
skus restartovat PC, pravděpodobně jiný program používá Comport na kterym máš tlf.
johnygrass
tak zkus snížit rychlost v tom Winswupu Arrow
jumper89
PostPosted: Thu Jun 08, 2006 4:54 pm    Post subject: Reply with quote
ked sa snazim zmenit rychlost a nasledne chcem potvrdit vypise:
This speed not possible on this ComPort..
2pip@: ok skusim ale neviem uz ani ako sa restartuje pc som ho nevypinal ani nepamätam totiz fici non-stop
jumper89
PostPosted: Thu Jun 08, 2006 5:00 pm    Post subject: Reply with quote
nic nepomaha
johnygrass
PostPosted: Thu Jun 08, 2006 5:02 pm    Post subject: Reply with quote
Ale to by mělo psát jenom když tu rychlost zvýšíš Exclamation
jumper89
PostPosted: Thu Jun 08, 2006 8:00 pm    Post subject: Reply with quote
ale pise aj ked spravim co chcem
CRAZYTAN 666
PostPosted: Sat Jun 10, 2006 10:34 pm    Post subject: Reply with quote
A NEMAS TAK NAHODOU ZAPLE NABIJENI NA KABELU,??
jumper89
PostPosted: Sun Jun 11, 2006 8:57 am    Post subject: Reply with quote
nemam servisny kabel toto je 500
johnygrass
PostPosted: Sun Jun 11, 2006 7:00 pm    Post subject: Reply with quote
no vídíš tak si ho předělej a máš to
whitewash
0.00 SMM
PostPosted: Sun Jun 11, 2006 7:34 pm    Post subject: Reply with quote
No moment... S 500kou ide prehrať FW len cez originál updatera. Na winswup potrebuješ 510.
