:: View topic - S65v58 -> S75 tuning
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
Reply to topic     Forum Index -> Tuning
Měli by jste zájem o S75 tuning?
Ano
86%
 86%  [ 59 ]
Ne
13%
 13%  [ 9 ]
Total Votes : 68
Laachta
PostPosted: Thu Jun 22, 2006 3:59 pm    Post subject: Reply with quote
pochopil som spravne? zhrniem to:
hodnota A0 (v decimalkach 160) je uplne dole
hodnota 13 (v decimalkach 19) je skoro hore
tojest ak zadam 50 (v decimalkach 80) bude v strede?
dakujem za objasnenie Smile
ccd98
8031.04 SMM
PostPosted: Thu Jun 22, 2006 4:03 pm    Post subject: Reply with quote
Asi to tak bude... mno vyzkoušej to a uvidíš... wink
S LXXV
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Thu Jun 22, 2006 6:08 pm    Post subject: Reply with quote
dakujem za objasnenie Smile))
presne tak wink to Y znamena posun po ose Y Smile takze kdyz tam zadas treba FF tak hodiny a datum neuvidis vubec Whistle
-> Nokia Lumia 800
Laachta
PostPosted: Fri Jun 23, 2006 2:54 pm    Post subject: Reply with quote
este chvilku budem otravovat Razz
aku adresu mam zmenit aby som presunul providera?
bo teraz sa mi prekryvaju Sad
(a dal by sa takto presunut aj riadok "signal inkonky baterka" ?)
proste moj zamer je takyto: hodiny uplne hore a pod nim baterka 8) wink
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Fri Jun 23, 2006 2:58 pm    Post subject: Reply with quote
najdi si patch mainscreen changer Wink
-> Nokia Lumia 800
radek78
PostPosted: Mon Jul 24, 2006 11:09 am    Post subject: update S65 na S75 nejde, graf a systemove patche taky ne :-( Reply with quote
Nazdar lidi,
tak ja nevim, zkousel sem to nekolikrat, vcetne toho zapnuti service mode a slus ... stale Only secure update is allowed ... muzu to opakovat treba 100x a za tuhle hlasku se nikdy nedostanu ... Podobnej problem mam s patchovanim.O tom, ze bych do telefonu dostal graficky nebo systemovy patch si muzu nechat jedine zdat ... Pise to nakou neshodu adres ci dat a slus.Pokud v VKlay posl verze v menu rozsirene dam nekontrolovat ci co, tak to tam dostanu, ale telefon se treba nezapne apod...Program na opravui patchu je starej jak metuzalem a temer 90% patchu neotevre s chybou, pravdepodobne ani nezmeni adresy kam se patch ma nahrat jak bylo v navodu.Napada vas nejake bezpecnejsi reseni, nez to zkouset pres fullflash apod , do cehoz bych se velice nerad poustel ?...
maxpower
PostPosted: Thu Oct 12, 2006 11:29 am    Post subject: Reply with quote
ten firmware 58 je k tomuto tuningu nutnost?
na firmware 53 by to neslo?
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Thu Oct 12, 2006 1:00 pm    Post subject: Reply with quote
to neni FW k tuningu... to je tuningovy FW wink
-> Nokia Lumia 800
Reply to topic     Forum Index -> Tuning All times are GMT + 1 Hour
Page 9 of 9
