:: View topic - wrong sof a 57
wrong sof a 57
papa
PostPosted: Sun Jun 04, 2006 5:54 pm    Post subject: wrong sof a 57 Reply with quote
opravdu už nevim,mam na stole po dlouhe dobe a57 klasika wrong soft,jde ale o to ze nejde pripojit(nereaguje a kdyz tak naskoci wrong)
a pokud bych chtel udelat testpoint tak jeji zakl. deska je mimo ukazane (vyfocene zde na mobilmanii) prijde mi ze je to neco mezi obema ...
tak a ted porad te co s tim nez s tou a57 trisknu o zed dekuji
PostPosted: Sun Jun 04, 2006 7:56 pm    Post subject: Reply with quote
Skus odfotit tu dosku a hod to sem.
papa
PostPosted: Mon Jun 05, 2006 7:04 pm    Post subject: Reply with quote
fotak bude az o vikendu tak to pak poslu (bohuzel driv mi ho segra nevrati Evil or Very Mad )
papa
PostPosted: Mon Jun 26, 2006 6:34 pm    Post subject: Reply with quote
tak se vsem omlouvam za placnuti do vody Embarassed Brick wall deska je klasika a take se omlouvam za tak pozdni reakci ale opravdu nejak nestiham nic, jinak mam prosbu podarilo se mi udelat testpoint (tedy doufam ale stale mi hlasi toto :
Start...
Loading BootsModel(A55)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com5 115200 BAUD: Ok.
SIEMENS A57 lg7 Sw03
Soft FlashID: 002C/0017 (FF7F/FF7F)
FlashID: 0080/0080
Flash Size: 8Mb
Region(1): Blocks 64, Size 128Kb
EEPROM segments not found!
FSN: 20008000 -> PhoneID: 00800020
OTP IMEI: 000000000000000
Warning: The software of the telephone does not correspond to FlashID!
HASH: 26ED58DD3A5D1A2469F86D9A021D50D5
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
WriteFlash CRC Error (0x00000000<>0x33A853D8)! (Block at 0x800000).
co s tim? kdyz jsem chtel prehrat sw tak me nepusti
d'oh! Crying or Very sad Crying or Very sad
PostPosted: Tue Jun 27, 2006 8:54 am    Post subject: Reply with quote
Na 99% fyzicky vadná flash na desce. U tohoto modelu se to už opravdu nevyplatí opravovat. Levnější je od někoho získat za stovku dobitou A55 bez displeje a vyměnit desku.
papa
PostPosted: Wed Jun 28, 2006 5:32 pm    Post subject: Reply with quote
ok ,udelam to asi tak Sad no pokud nahodou nekdo mate Laughing Laughing vemu klidne na dobirku
Sirus
7910.50 SMM
PostPosted: Thu Jun 29, 2006 6:46 am    Post subject: Reply with quote
Skus to este dat aj sem: http://www.siemensmania.cz/inzerce/index.php
papa
PostPosted: Thu Jun 29, 2006 8:35 pm    Post subject: Reply with quote
inzerce, ja vim ,ale tohle je ciste jen kdyz nahodou.... po pravde je mi jedno jestli ji nekdo proda nebo ne kdyz ano tak ji vemu kdyz ne nic se nedeje... jinak zlata me 45
presto diky
