honza29292929 kolemjdoucí
Posted: Mon Aug 28, 2006 8:24 pm Post subject: ME75 a T9 |
Omylem sem si smáznul T9 s mobilu tim ze sem si obnovil pamet telefonu . procitam sem tady ty fora a nasel sem ze se to da ty soubory t9 skopirovat do data/system/t9 ale ja pro pripojeni pres kabel nemam ani v jedny ze slozek to t9 kam to mam u svoji ME75 skopirovat ja ? poradte prosim |
serzino rozumbrada
Posted: Mon Aug 28, 2006 8:28 pm Post subject: |
Chod do Data,system a vytvor si novu zlozku premenuj ju na T9 a do nej to skopiruj.Vypni a zapni fon.  _________________ E628 ,N1611,E688 ,N5110,N3210 ,N3310 ,N6210 ,Mot V66i ,C35 ,S35 ,S45 ,S55 ,6230,K700 ,S65 fw43,fw50,fw58,S75fw47,K610i, N70,E50,M65,S75,N6120c |
Posted: Mon Aug 28, 2006 8:33 pm Post subject: |
a kde mam vzit ty data a system? to jako po´pripojeni pres kabel k telefonu? tam mam sice slozku data ale v ni neni slozka system |
Posted: Mon Aug 28, 2006 8:44 pm Post subject: |
tak kam s tim? |
serzino rozumbrada
Posted: Mon Aug 28, 2006 8:56 pm Post subject: |
Podla vsetkeho pouzivas MPM.Ked mas polozku DATA tak v hornrj liste klikni na nastroje,moznosti zlozky a povol zobrazovanie skrytych suborov.Potom sa ti zlozka system objavi  _________________ E628 ,N1611,E688 ,N5110,N3210 ,N3310 ,N6210 ,Mot V66i ,C35 ,S35 ,S45 ,S55 ,6230,K700 ,S65 fw43,fw50,fw58,S75fw47,K610i, N70,E50,M65,S75,N6120c |
Posted: Mon Aug 28, 2006 9:08 pm Post subject: |
pozivam program penPower worldphone for cabel a tan neni nabidka nastroje ani nic kde by se dalo povolit zobrazovani skrytych slozek:( |
serzino rozumbrada
Posted: Mon Aug 28, 2006 9:13 pm Post subject: |
To neni v programe To je v hornej liste windowsu. _________________ E628 ,N1611,E688 ,N5110,N3210 ,N3310 ,N6210 ,Mot V66i ,C35 ,S35 ,S45 ,S55 ,6230,K700 ,S65 fw43,fw50,fw58,S75fw47,K610i, N70,E50,M65,S75,N6120c |
serzino rozumbrada
Posted: Mon Aug 28, 2006 9:16 pm Post subject: |
Alebo,daj v dolnej liste start,ovladaci panel,moznosti zlozky,zobrazenie.POVOLIT ZOBRAZOVANIE SKRTYCH SUBOROV. _________________ E628 ,N1611,E688 ,N5110,N3210 ,N3310 ,N6210 ,Mot V66i ,C35 ,S35 ,S45 ,S55 ,6230,K700 ,S65 fw43,fw50,fw58,S75fw47,K610i, N70,E50,M65,S75,N6120c |
Posted: Mon Aug 28, 2006 9:54 pm Post subject: |
tak sem to nechal povolit ale vůbec nic se neděje ta složka system se vůbec neukáže jinak to nejde udělat? |
serzino rozumbrada
Posted: Mon Aug 28, 2006 9:56 pm Post subject: |
stiahni si program simoco,alebo MPM tam to funguje bezproblemu.  _________________ E628 ,N1611,E688 ,N5110,N3210 ,N3310 ,N6210 ,Mot V66i ,C35 ,S35 ,S45 ,S55 ,6230,K700 ,S65 fw43,fw50,fw58,S75fw47,K610i, N70,E50,M65,S75,N6120c |
dec kolemjdoucí
Posted: Sun Sep 17, 2006 2:15 pm Post subject: Zdravím |
Nechtěl jsem zakládat nové téma, tak to píšu do tohoto, protože se to toho vlastně taký týká.
Popis mého problému: mám tel cf110 (není můj, o to je to horší). Nemám zálohu fullflashe, protože jsem nechtěl řezat TP. Telefon měl původní FW verzi 11cz, ale protože je trochu pomalejší (hlavně při psaní sms), chtěl jsem vyzkoušet, jestli to nový fw verze 14 nezlepší. Nezlepšil a navíc není český. Takže jsem chtěl vrátit zpět verzi 11cz, což jsem provedl tak, že jsem nejdříve nahrál verzi 07winswup, abych pak mohl nahrát 11cz. To všechno proběhlo bez problémů, ale zmizela mi česká t9 a nevím, jak ji do telefonu dostat. Zkoušel jsem vytvořit vlastní userswup verzi z fullflashe, která je k dispozici tady na serveru, jenže z ní se mi nedaří nic vygenerovat (z jiných to jde, ale z týhle to nejde, píše to nějakou chybovou hlášku, která není navíc přeložená, takže místo ní vidím jen otazníky a různý další znaky).
Neví někdo, jak tam tu t9 dostat? Díky moc. |
