josiip kolemjdoucí
Posted: Tue Sep 12, 2006 6:16 pm Post subject: aky program na prerabanie videa na el71 je najlepsi |
caute ktory program na prerabku videa z avi na 3gp alebo mp4 by bol najlepsi? a kde ho stiahnem? se |
inco10 postrach fóra
Posted: Tue Sep 12, 2006 6:43 pm Post subject: |
Ja pouzivam Pv Author  |
josiip kolemjdoucí
Posted: Tue Sep 12, 2006 6:48 pm Post subject: |
a ako sa to robi lebo to skusam a nejde mi to skus mi poradit aspon tie najzakladnejsie veci please |
Posted: Tue Sep 12, 2006 6:53 pm Post subject: |
Ked to spustis tak tam mas taku tabulku v ktorej musis vybrat video..ale nefunguju vsetky!!! dalej to nastavis podla toho na aky telefon to chces....powedz na aky telefon a poviem ti co tam mas nastavit....... |
josiip kolemjdoucí
Posted: Tue Sep 12, 2006 7:06 pm Post subject: |
na el71 |
Posted: Tue Sep 12, 2006 7:31 pm Post subject: |
Ten mam aj ja.....je super!!!!!!!!§ takze
1) vyberes video
2) hore vyberes ze encoding
3) Das 128 bps
4) dole mas ze codek kliknes na to
5) GSM das 12.20
6) codek das PV mp4
7) video cize das 320x240
8) dalej da dole codek setings
9) A fremerate das 12. 50
10) hore das ze imput a nastavis ze
kde sa to ma ukladat
11) dole das ze OK
12) stlacis START
Potom napis ci sa ti to podarilo!!!! |
josiip kolemjdoucí
Posted: Tue Sep 12, 2006 7:45 pm Post subject: |
Spravil som vsetko presne ako si mi napisal ale aj tak mi nchce prehrat videa na telefone ale dik |
Posted: Tue Sep 12, 2006 7:50 pm Post subject: |
A co ti to ukaze? ide aspon zvuk?
alebo len obraz? |
josiip kolemjdoucí
Posted: Tue Sep 12, 2006 7:54 pm Post subject: |
Neide nic len napise ,ze nemoze video prehrat |
Posted: Tue Sep 12, 2006 8:01 pm Post subject: |
tomu fakt nechapem......aky tam mas fimeware???to das hviezdicka mriezka 06 mriezka.... potom das sipku do prava a tam je ze verzia softweru...tak mi powedz aku mas! |
mmd kolemjdoucí
Posted: Tue Sep 12, 2006 8:06 pm Post subject: |
Ja pouzivam Clone DVD Mobile. Je super na prerabanie priamo z DVD.Mam EL71 a filmy idu perfektne. |
josiip kolemjdoucí
software. ver. 12 a firmware ver. patch 26 audio 2 mobil je z anglicka |
Moucha čestný člen
 Joined: 25 Jan 2006 Posts: 2125 Location: C. Budejovice Telefon: HTC Hero
60.08 SMM
Posted: Tue Sep 12, 2006 8:07 pm Post subject: |
to je tim fimewearom..daj si tam 31...pojde to bez problemov
EDIT: A ten Clone DVD mobile sa da de stiahnut? kolko ma priemerne jeden film? |
josiip kolemjdoucí
Posted: Tue Sep 12, 2006 8:11 pm Post subject: |
ako ten firmware dam do mobilu? kabel mam a cez aky program |
