:: View topic - EL71-koupeno-zkušenosti
Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 21, 22, 23  Next
bojler
300016.12 SMM
PostPosted: Thu Sep 07, 2006 10:38 am    Post subject: Reply with quote
ja bych jenom este dodal, ze vubec nepozoruju horsi prijem signalu. tam kde sem signal nemel s S65 nemam ani ted, tam kde sem mel, tam mam nadale.
2002 C35i -> 2003 C55v24 -> 2004 S55v20 -> 2005 S65v58 -> 2006 EL71v38 -> 2007 EL71v45 + S65v58 -> 2008 EL71v45 + S65v58 -> 2009 EL71v45 -> 2010 EL71v45 patches revival -> 2013 dualSIM a konec Siemensu
hsngr
PostPosted: Thu Sep 07, 2006 4:59 pm    Post subject: Help with SIEMENS EL71 Reply with quote
HELLO:
I come from China.And I buy a siemens el71 mobilephone.But it's language is English,I want to change it into Chinese.But I had to crack it first. Would I use any Java tools to crack it,like the X65,X75? And where can I find it? Can you tell me? Or can you tell me the way how to carck it in order to connect with V-Klay tools
Thany you Very Happy Very Happy
alkaba
10903.00 SMM
PostPosted: Thu Sep 07, 2006 6:00 pm    Post subject: Reply with quote
You must download a firmware from benq-siemens site. I think chinese langpack is caled 8...If you want to connect your EL71 with V_Klay-you must to do a testpoint, but its very difficult Exclamation
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
Diamondking
1262.50 SMM
PostPosted: Wed Sep 13, 2006 10:48 am    Post subject: Reply with quote
Nevím jestli jste zaregistrovali fw 36 A 400-což by mělo být v češtině i slovenčině. Link je tady:
Code:
http://www.benq-siemens.com/cds/frontdoor/0,2241,hq_en_0_130289_0_xcs%253A130989_xcp%253A140777_pd154373%253A154374_pde154373%253A159834,00.html#anchor154373
N3o21
5892.50 SMM
PostPosted: Wed Sep 13, 2006 10:52 am    Post subject: Reply with quote
dik za info Wink vecer jestli mi pojede net, tak ho tam hodim Smile
N3o21
5892.50 SMM
PostPosted: Wed Sep 13, 2006 5:49 pm    Post subject: Reply with quote
tak ten fw36 podle me razantne zrychlil reakce telefonu, ale porad chybi to smazat vse Crying or Very sad Crying or Very sad Crying or Very sad
to co mi nejvic vadi...
Diamondking
1262.50 SMM
PostPosted: Wed Sep 13, 2006 6:34 pm    Post subject: Reply with quote
Tak na to ti neodpovím protože já mám EF81 a tam to nejni taky:-((
MatkoGin
PostPosted: Thu Sep 14, 2006 9:27 pm    Post subject: Reply with quote
Ja som si tento unikát /EL71/ kupil v orangi a mam teraz problém nejako sa neviem dostať k tomu aby som spravil foto s rámčekom jednoducho mi tam tá možnosť chýba a čo teraz???
MatkoGin
PostPosted: Thu Sep 14, 2006 9:28 pm    Post subject: Reply with quote
alkaba
10903.00 SMM
PostPosted: Thu Sep 14, 2006 9:56 pm    Post subject: Reply with quote
Tato funkce nefunguje na plné rozlišení... wink jenom na "Vysoké" 640x480 wink
»Siemens C65
branoi
PostPosted: Thu Sep 14, 2006 10:03 pm    Post subject: Reply with quote
Shocked to sa ako da?? pokial viem len vo fotoeditore... teda v mojom od TM to nieje ani v manuale, ani v moznostiach Sad fw12
Seehank
PostPosted: Mon Sep 18, 2006 1:35 am    Post subject: .vpk + EL71 Reply with quote
Mozno pisem uplnu absurditu, ale nejak som unaveny na citanie celeho fora... Mam BT a spojenie ako serial cez port COM 4 je nejaky sposob ako presvedcit EL71 aby sa kamosila s V_KLay resp iny sposob ako roychodit .vpk ??? Shocked
neveceral
PostPosted: Wed Sep 27, 2006 8:09 am    Post subject: Reply with quote
Ahoj, chtěl jsem se zeptat, zda někdo nemáte zkušenosti se synchronizací kalendáře s počítačem. Mám pod WXP kalendář, který umí SyncML, EL71 má podporu SyncML, tudíž šlo by je tedy synchronizovat "nějak" na přímo přes kabel nebo BT nebo tam pořád musí být nějaký externí SW, který to zařídí? Díky za radu.
yoyanec
PostPosted: Wed Sep 27, 2006 10:38 am    Post subject: Reply with quote
povedz aky kalendar mash a ja ti to otestujem...
Ericsson GA-628 -> 688 -> T10 -> Nokia 5110 -> 3210 -> 3310 -> 6510 -> 3510i+cable + Siemens A50 -> CX65@CX70 + DCA-510 ->EL71+1GB Kingstone + DCA-510@DCA-110
neveceral
PostPosted: Wed Sep 27, 2006 11:17 am    Post subject: Reply with quote
Velmi děkuji za nabídku, je to Mozilla Calendar, což je nyní již neaktualizované rozšření do Mozilla Thunderbird, pak se jenom dodá další rozšíření o SyncML. Odkazy (aby se nemuselo zbytečně instalovat a ohrožovat windows tak jenom zip či xpi) PortableThunderbird http://mesh.dl.sourceforge.net/sourceforge/portabletbird/Thunderbird_Portable_1.5.0.5_en-us.zip
Calendar rozšíření do TB http://ftp.mozilla.org/pub/mozilla.org/calendar/xpi/windows/calendar_windows_latest.xpi
a SyncML do něj http://mesh.dl.sourceforge.net/sourceforge/sync4jmozilla/sync4j_mozilla_calendar-0.2.0.20060116-fx+tb-windows.xpi
Calendar se sice již nevyvíjí, ale dá se očekávat že SyncML rozšíření bude přepracováno pro nový Sunbird (samostatná aplikace) či Lightning (nástupce Calendar)
Ještě jednou velmi děkuji a těším se na výsledek, Daniel.
Page 12 of 23
