:: View topic - Patch 94 - poradite? nejak tomu poradne nerozumim
Xmax88
1271.42 SMM
PostPosted: Sat Sep 23, 2006 6:00 pm    Post subject: Patch 94 - poradite? nejak tomu poradne nerozumim Reply with quote
k cemu je tenhle patch dobrej?
, vim jen ze upravuje funkce joy, ale vubec nechapu jak a proc? muzete mi nekdo poradit? to si jako muzu nastavit ze po stisknutí joy, mob. skoci do menu?
Code:
Patch 94
; *** EnhanceMenuJoyStick ***
; Author: Bryan
; Date: 2006.09.18
; Firmware: Siemens-SX1 Possibly all versions. Tested on SX1_2_RUSSIA-RETAIL-uk-de-ru_15_0001
; Modified Omap(Z1) phone.app
; This patch is the enhancement of patch N0.30 and patch No.75
; With this patch you can set JoyStick LEFT,RIGHT,UP,DOWN and JoyStick_OK as shortcut of any application.
replace:814214D10648006806490968064A1268064BEFF702FF012030E0:814214D10648006806490968064A1268064BEFF702FF012026E0
; The last 40 numbers is UIDs for the shortcuts.Each one marked with a different color
; The order of these UIDs is JoyStick_LEFT,JoyStick_RIGHT,JoyStick_UP,JoyStick_DOWN,JoyStick_OK
; The UID in the patch must reversed like in patch No.30
; For Example: UID for BlueTooth is 10005951, then in the patch it should be 51590010
replace:1168054881420BD1186C044909680022:5B38814201D10E4912E00130814201D10C490DE00130814201D10B4908E00130814201D1094903E03B30814204D10849186C0022EFF77EFE002002BC08470000JoyStick_LEFTJoyStick_RIGHTJoyStick_UPJoyStick_DOWNJoyStick_OK
; you should change the last string in the above code to 40 numbers(5 UIDs)
; End of Patch
SIE C35i - FW M35i --> SE T100 -->SIE M55 - FW91+patche -->
Siemens SX1- na ND [momentalne funkcni]
xXxTRA^^
5896.92 SMM
PostPosted: Sat Sep 23, 2006 7:54 pm    Post subject: Reply with quote
jo v podstate to je tak, ale musis znat id prislusne akce... Precti so to v download/patche, je to v patchi 30 popsane, nebo 75 (aspon tam sou nejaka id)
IMG Hosting | iProtebe
Gwin
0.84 SMM
PostPosted: Sun Sep 24, 2006 1:46 pm    Post subject: Reply with quote
Prostě si nastavíš co se má spustit po stisknutí joye, posunutí doprava,...
dps
676.28 SMM
PostPosted: Mon Sep 25, 2006 9:23 am    Post subject: Reply with quote
Já sem si dal:
UP: filemanger
DOWN: kontakty
LEFT: AppMan
RIGHT: Repligo
OK: Smartmaps
xXxTRA^^
5896.92 SMM
PostPosted: Mon Sep 25, 2006 9:26 am    Post subject: Reply with quote
to zakezi jen na uzivateli co tam hodi Shhh
