:: View topic - co s nabiječkou z mt50?
Wildfire
PostPosted: Thu Nov 09, 2006 9:08 pm    Post subject: co s nabiječkou z mt50? Reply with quote
da se z toho konektoru vyrobit něco na cx75?mam na mysli to že mt50 ma tlustči konektor nez cx75
xXxTRA^^
5896.92 SMM
PostPosted: Thu Nov 09, 2006 9:24 pm    Post subject: Reply with quote
neda
IMG Hosting | iProtebe
Tomas250
PostPosted: Thu Nov 09, 2006 9:38 pm    Post subject: Reply with quote
Tak dalo ale musel by si ten konektor upilovat třeba redukce 3,5mm jackhttp://www.siemensmania.cz/content.php?id=827 nebo takovou tu lampičku s led diodou http://www.siemensmania.cz/content.php?vote=5&id=241 ale musel by si dopájet piny
Siemens S75 ,RS-MMC 128MB,KABEL DCA-510,FIRWARE 40,REDUKCE 3,5 JACK
PostPosted: Thu Nov 09, 2006 9:42 pm    Post subject: Reply with quote
Citaj temu ma nabijacku s MT50.
Moja rada: Zahod ju. Chyt ju za konektor, roztoc a skus ako daleko doleti. Ale nie, ja by som ju niekomu dal. 8)
xXxTRA^^
5896.92 SMM
nemas pravdu, ten konektor tam nesedi na sirku
Tomas250
PostPosted: Thu Nov 09, 2006 9:47 pm    Post subject: Reply with quote
je tam jedno slovíčko upilovat
39.00 SMM
když se to upiluje tak aby to tam pevne drzelo tak ten konektor na sirku sedi mam to doma upilovany Shame on you
xXxTRA^^
5896.92 SMM
PostPosted: Fri Nov 10, 2006 7:17 am    Post subject: Reply with quote
sorry, jen se z toho nepoblbnete Brick wall mate pravdu, vyzkousel jsem to taky a uz vim ze to jde Angel Angel Angel
