:: View topic - How to change the icons of the menu
Reply to topic     Forum Index -> Non Czech Languages Here
Xfen
PostPosted: Sat Nov 11, 2006 4:48 pm    Post subject: How to change the icons of the menu Reply with quote
Hi how I can to change te menu icons? I have download manu difrent icons... but I don't have an idea how to change it... in which folder must be it?
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Sat Nov 11, 2006 5:02 pm    Post subject: Reply with quote
2:\japp\Flexmenu\
You must make the disc 2:\ visible with e.g. Total Comander VSOFS (in options check "open hidden discs at startup")plugin before.
Xfen
PostPosted: Sat Nov 11, 2006 5:16 pm    Post subject: I have one more question... Reply with quote
Thank u for ur answer... i have download the total comander.. but there isn't any exe or other execute file?! how to install the program?
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Sat Nov 11, 2006 5:20 pm    Post subject: Reply with quote
It is wfx plugin so move it to TOTALCMDDIRECTORY\plugins\wfx\
Xfen
PostPosted: Sat Nov 11, 2006 5:22 pm    Post subject: Reply with quote
but i don't have a TOTALCOMANDER program:(
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Sat Nov 11, 2006 5:25 pm    Post subject: Reply with quote
so install it Brick wall
Note:and you have to copy also main.fs file to 2:\japp\Flexmenu
Xfen
PostPosted: Sat Nov 11, 2006 5:26 pm    Post subject: Reply with quote
dude... but were can i find it!?
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Sat Nov 11, 2006 5:27 pm    Post subject: Reply with quote
www.ghisler.com/
( http://www.google.com/search?client=opera&rls=cs&q=TOTAL+commander&sourceid=opera&ie=utf-8&oe=utf-8 )
Xfen
PostPosted: Sat Nov 11, 2006 5:36 pm    Post subject: Reply with quote
sorry for my stupidety but i isntall the total commander and i have only one subdirectory- LANGUAGE?!
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Sat Nov 11, 2006 5:39 pm    Post subject: Reply with quote
So create the subsubsubdirectory \plugins\wfx\vsofs
132978.34 SMM
PostPosted: Sat Nov 11, 2006 9:55 pm    Post subject: Reply with quote
If you haven´t got Total Commander, try VNavigator SFE.
It´s simpliest filemanager and it have open disk function too.
Doxxik
4285.00 SMM
PostPosted: Sat Nov 11, 2006 10:16 pm    Post subject: Reply with quote
You can use SiMoCo, too. But you must applied patch for view secred disc Rolling Eyes
// deleted some posts in czech lang.; jenda.69
Doxxik
http://www.youtube.com/watch?v=ZapMq2cDyZM
Xfen
PostPosted: Sun Nov 12, 2006 8:14 pm    Post subject: Reply with quote
finaly I've reacjhed the menu with icons.. but i have one more question.. there is some files that i don't know hat to do it... the files are:
extras.fs,filemenu.proparites,main.propartes,etras.fs,organasier.,setup.fs,ruf_fun.fs...so /.... what to do? do delete them or not?
132978.34 SMM
PostPosted: Sun Nov 12, 2006 8:26 pm    Post subject: Reply with quote
not delete, only rewrite Exclamation
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
