:: View topic - MPM - Czech
MPM - Czech
Goto page 1, 2  Next
Reply to topic     Forum Index -> Třída S
TomasX
PostPosted: Fri Dec 01, 2006 4:11 pm    Post subject: MPM - Czech Reply with quote
Tak jsem koupil datový kabel, a asi mě bude na nic. Nejde stáhnout MPM, stránky výrobce stojí opravdu za hovno Embarassed Bohužel nemám u sebe ani CD co bylo k telefonu. Nevíte někdo kde by se to dalo ještě stáhnout? Rád bych konečně přehrál můj FW 22. Nebo třeba nějak poslat, ale jak jsem se díval tak to má 68 MB. Rolling Eyes
Drobcek9056
7860.92 SMM
PostPosted: Fri Dec 01, 2006 4:12 pm    Post subject: Reply with quote
naco ti je MPM na prehranie FW?pokial chces zalohovat tak plne vyhovuje SiMoCo.
momentalne SL55 Smile
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Fri Dec 01, 2006 4:20 pm    Post subject: Re: MPM - Czech Reply with quote
Mne to ide stiahnut v pohode z oficialnej stranky: MPMSetup4.06.17.31.0.1_SmartSync_cs-CZ
TomasX
PostPosted: Fri Dec 01, 2006 4:56 pm    Post subject: Re: MPM - Czech Reply with quote
Mě to nejde, vyskočí mě toto-
Oops! You see this page because you had problems downloading Or you see this page because you came from a non BenQ Mobile website.
If you are trying to download any firmware, software or manuals from our servers, please disable your firewall before downloading. The use of firewalls or home firewall software can cause access problems. Please disable your firewall to continue downloading from our server temporarily. After downloading the file, be sure to re-enable your firewall.
Learn more about Benq Mobile on the corporate portal. Find detailed information about the company, its global presence and much more by clicking on the link below.
www.BenQMobile.com
If you are looking for mobile phones, mobile accessories or applications please go to:
www.BenQ-Siemens.com
If you are looking for information about the Siemens AG please go to:
www.siemens.com
Tak jak mám ten FW přehrát? ještě jsem to nedělal, kabel mám DCA-140
Drobcek9056
7860.92 SMM
PostPosted: Fri Dec 01, 2006 5:01 pm    Post subject: Reply with quote
pokial mas na mysli zalohovanie adresara,SMS a tak,tak pouzi uz spominany SiMoCo. A MPM ti aj tak na nahratie noveho FW netreba,treba ti stiahnut originalny FW a to nieje MPM.
napis este aky mas mobil
alfah4ns
PostPosted: Fri Dec 01, 2006 5:04 pm    Post subject: Reply with quote
zkus vypnout na chvili ten firewal, u mne to pomohlo (mel sem Kerio a nepustil me tam)
C35 --> M35i --> ME45 --> nokia 3510i (blééé) --> S55 + DCA-510 + 1,58MB+patche --> S68 + DCA-140 + DCA-110
TomasX
PostPosted: Fri Dec 01, 2006 5:18 pm    Post subject: Reply with quote
Mám S68, lze použít FW z těchto stránek?
TomasX
PostPosted: Fri Dec 01, 2006 5:24 pm    Post subject: Reply with quote
Díky, pomohlo to Embarassed ,nejsu moc velkej počítačovej expert Applause .Můžete mě sem dát nějakej stručnej návod jak přehrát FW a na co si dát bacha? Pray
Moucha
60.08 SMM
PostPosted: Fri Dec 01, 2006 5:28 pm    Post subject: Reply with quote
aby ti nevypadl proud, no proste stahnes si FW winswupovou verzi, zaskrtnes oba dva skipy, nastavis porty a das start a macknes cervene tlacitko na telefonu
wmmania.cz
Podpořte SiemensManii
Koukněte co zrovna poslouchám
Drobcek9056
7860.92 SMM
potrebujes si stiahnut FW pre svoj mobil bud z oficialnej stranky,alebo tu niekto pisal,kde su momentalne presunute FW zo SM,ale nepamatam stranku.
Moucha
60.08 SMM
PostPosted: Fri Dec 01, 2006 5:30 pm    Post subject: Reply with quote
Tady mas nektere:
http://dl.orpheusweb.sk/firmware/
http://allsiemens.com/flash/
http://orpheusweb.sk/sirob/
wmmania.cz
TomasX
PostPosted: Fri Dec 01, 2006 5:47 pm    Post subject: Reply with quote
Na ofic. stránkách jsem stáhl A400 vers.47, doufám že je to správnej, někde jsem tady četl že A400 je čeština? CO DÁL?
TomasX
PostPosted: Fri Dec 01, 2006 5:50 pm    Post subject: Reply with quote
Tu winswupovou verzi jsem zde našel FW 38 CZ a FW 42.
alfah4ns
PostPosted: Fri Dec 01, 2006 6:24 pm    Post subject: Reply with quote
co dal? tak vem ten original (FW47 je novejsi), pripoj si mobil kablem k pc a rozjed ten soubor co si stahl....samo te to povede...
edit: ale nabij si radsi predtim baterku...nemusi byt uplne, ale aby nebyla skoro vybita
TomasX
PostPosted: Fri Dec 01, 2006 9:29 pm    Post subject: Reply with quote
Díky všem, tak už mě to jede s FW 47 Applause Dancing
Reply to topic     Forum Index -> Třída S All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
